Question about Filter Queen Majestic Canister Vacuum
My powerhead on my filterqueen majestic 360 is not working properly. the motor seems fine but when it touches carpet the m otor bogs down and sometimes stops. if you hold it up off of the carpet it runs just fine???
    Problem Solver:
  • 10 Answers
I don't know pandora charms
Posted on Mar 31, 2011
Why is my #two motor not working and #ONE IS
Start with the obvious--a lot of vacuums have a reset button, try that first. It could be a bad switch, or a wire has come loose from the end of the switch that controls that motor. What brand is it? and is it the beater brush that is not working or the vacuum motor?
Sep 22, 2014 | FilterQueen FQ Majestic 360 Degree & 75th...
Decreased suction for filterqueen vacuum
Put a broomstick or such down the hose, something may be stuck. Look inside with the bag out, is there a screen before the motor?
Dec 01, 2013 | Filter Queen Majestic Canister Vacuum
I have a Filter Queen Majestic 360 and am having problems with the powerhead. There is a loud rattling noise in the powerhead, especially when I vacuum thicker carpet. I have replaced the motor, roller...
Hi there, as per your information i guess its a problem of power transformer. He can't supply the proper power in the motor & thats why the noise will come from the transformer. Thanks & waiting for your feedback.
Feb 20, 2010 | Filter Queen Majestic Canister Vacuum
Ihave a filterqueen majastic its about 10-12 years old and last week the motor seems to not work with full power. what seems to be the problem?
Our filter queen experienced a loss in power. Once we replaced all the filters and cleaned it all out, it worked well again. i think a filter kit cost about $80, but that was a while ago.
Nov 01, 2009 | Filter Queen Majestic Canister Vacuum
Where can a person purchase parts to repair the hose of an filter queen majestic model 360.
If you live in Iowa call 888-637-4692 or 800-344-1840 for the the Service Center near you. or online at http://www.filterqueen.com/contact-filterqueen-locate-distributor.html
FQ Master
888-637-4692 in Iowa
Your Filter Queen Authorized Service Center
Mar 03, 2009 | Filter Queen Majestic Canister Vacuum
Motor
Filter ?Queen Majestic Canister Vacuum – Motor
Motor?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
If your Filter Queen Motor is out or not working, the customer can replace the motor if they are mechanically minded and mark the wires as they remove the old motor with the new motor or you can have it serviced by your local vacuum dealer in your area, you can pickup the motor @ a local vacuum cleaner dealer in you area by checking the yellow pages or to contact the Filter Queen factory listed below. It requires a new motor and a new gasket; the biggest problem would be the wiring of the new motor. The factory information is listed below:
http://www.filterqueen.com Filter Queen Canisters Vacuums
Health-Mor World Headquarters
13325 Darice Parkway, Unit A
Strongsville, Ohio 44149
1-440-846-7800 or email @ custserv@filterqueen.com
Apr 18, 2008 | Filter Queen Majestic Canister Vacuum
Power brush motor seems too weak
This machine needs a new belt. The belt is stretched into position and even if it is not used, will fatigue over time. This can occur as the machine is in storage waiting to be sold. If you check the bristle on the roller, you will observe that it extends out the bottom of the powerhead quite far and is very stiff. This causes the brush to engage the carpet very aggressively and puts considerable strain on the belt. A tired belt will fail very quickly under these conditions. You should take it to a warranty depot and have the belt changed.
This machine also has variable speed motor in the main unit. This is so you can adjust how heavily the powerhead brushes the carpet. If it is set too high, on certain carpets, the suction will pull the powerhead down too hard and this will bogg the roller and cause the belt to fail prematurely.
Feb 02, 2008 | Hoover S3765-040 WindTunnel Bagless...
Filterqueen cuts out when warm
You should check the disc filter that is located under the paper cone support. The support is secured with a single screw in the middle at the bottom. This filter is commonly overlooked and when it gets dirty will restrict airflow and cause the motor to overheat. Most motors have a Hi-Limit switch incorporated into the motor to protect against overheating. You should also check the top filter (which is probably foam) and replace if it is clogged.
Jan 11, 2008 | Filter Queen Majestic Canister Vacuum
Need manuel
I've found an online manual in pdf format
Oct 29, 2007 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
262 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
