Question about Samsung Televison & Video
I believe the bulb needs replacing in my DLP TV
  • Samsung Master
  • 5,138 Answers
What makes you think the lamp is BAD?
Posted on Aug 04, 2008
SOURCE:
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
Tv shuts off after 1 min and the timer light lamp light and power light flash on and off
Hi, My samsung dlp 46 tv did the same thing, it was the lamp bulb needed to be replaced.
It is easy to replace, we replaced it twice. I paid I believe $85.00 on ebay store, discount tv lamps
hope this works!
Jun 08, 2011 | Samsung HLT6187SAX 61" DLP HDTV
How long do bulbs generally last?
Generally, a DLP bulb lasts about 8,000 hours (if a TV is on 10 hours a day, every day, the bulb will last about two years). A bulb can last longer if it's used less frequently. Typically, a bulb in a DLP TV for household use should last at least three to four years before it starts to flicker and needs to be replaced.
Thanks!
Tim
Oct 02, 2010 | Samsung HL-67A510 67" DLP HDTV
Need help with blub
Try You Tube,type in ur DLP tv model mnuber,and bulb replacement.There will have a tutoring video how to replaced ur DLP tv model of bulb.
Apr 27, 2010 | Samsung HL-P6163W 61" TV
The tv has power , the volume comes on ,but no picture,just black screen. The red change lamp light has been on for some time,and it is still on
I believe this is a DLP set. There is a single high power bulb that shines thru the dlp chip and onto the screen. My old Panasonic 55" (forget the model) had the bulb access on the front left side-1 phillips screw to remoce the door and another to pull the light assembly. Replacement bulbs are available plain or in the assembly-your choice. Just google your make and model plus DLP bulb and you should be good to go- I paid $85 for the bulb alone- order 2 as the life span is much shorter than what panasonic claims- there was even a class action lawsuit over this issue that covered about 10 different set.
Dec 19, 2009 | Panasonic PT-51HX41 51" Rear Projection...
RCA SCENIUM MODEL D44LPW134 IS MY BULB BLOWN?
If this is a DLP, which I believe it is, your bulb is blown. Look for an indicator light on the front of the tv. After you hear the bulb try to warm up two or three times the indicator light should come on and stay on steady.
I own a 57" Mitsubishi DLP and have replaced the bulb three times now. It was the latest and greatest technology when I bought it, but knowing what I know, I dont think I would buy another DLP.
By the way, get the bulb number then check ebay, by far the best prices.
Jun 02, 2009 | RCA Scenium HD50LPW52 Replacement Lamp
Zenith DLP-Projection tv 42"
Try this solution which I found on Fixya
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Zenith dlp projection model z52sz80 turns off randomly
Further advice here. If the bulb is over a year old it is suspect.
LG DLP TV wont power up Red indicator lightjust blinks when
and where I got all this information frlom
zenith dlp projection tv blinking red light Google Search
Jan 09, 2018 | Zenith Televison & Video
Hewitt Packard high definition DLP tv Product #EX543AA#ABA need part, hp no longer carries them.
I have a brand new L2114a lamp for sale. I paid 299 plus shipping on ebay but it turned out to be the wrong one (despite what the manual says). I ordered the correct one I needed from HP. I am willing to part with it for 200. I can send pictures of the lamp and the box and the reciept. This is a BRAND NEW LAMP.
This lamp works in the following televisions and replaces the lamps listed below:
HP Pavilion md5020n 50-inch High Definition DLP TV L1735A
HP Pavilion md5820n 58-inch High Definition DLP TV L1736A
HP Pavilion md6580n 65-inch High Definition DLP TV L1737A
HP Pavilion md5880n 58-inch High Definition DLP TV L1798A
Jan 28, 2008 | Televison & Video
Loud noise
our samsung's bulb needed to be replaced indicated by those front flashing lights
Oct 26, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
22 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
