Question about GE 22.3 Cu. Ft. Bottom-Mount Refrigerator - White-on-White
If I put anything in my fresh produce draws it will freeze
  • 132 Answers
Your thermostat has failed.
You need to fit a new thermostat
Posted on Apr 01, 2011
Is a loud noise normal when drawing off hot water for tea?
not if it never did it before
when you draw off hot water , there is normally fresh water let in to keep the unit full
this cold water hitting the boiling water will produce steam which is allowed to escape hence the noise.
May 25, 2015 | Jura Impressa F50 Classic Automatic Coffee...
How to freeze fresh strawberries
Wash. take off stems cut them into halves or quarters , place into zip lock bags or a sealed container. pop into freezer. easy !
you can blend them and put into a ice cube tray as a great way to add flavour to a fruit smoothie - keeps it cold without watering it down.
Mar 25, 2014 | Cooking
.fresh produce is freezing and temp set at 2. what do I need to replace/check
Hi Robert,
I would suggest 2 degrees is too low. Try setting it to 5 and maybe monitor for a few hours. If you feel the produce should be slightly cooler then reduce to 4 degrees. Fresh produce shouldn't be any cooler than this.
I hope this helps
Andy
Nov 13, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
How to freeze runner beans
Stem and snap the beans if you like, or just stem them, and put them in an airtight container and freeze them. Do not wash them before freezing as they will freeze together. This method is generally good for freezing most fresh produce. When you are ready to use them again, just take out however many you need and wash.
Sep 12, 2013 | Camping, Backpacking & Hiking
My vegetables keep freezing in the fridge, how do i get the fridge at the right temp?
Remove the vegetable/ produce/ meat draws and shelving that support them. Look along the rear wall or the left inside wall for vents that are feeding or directing cold air to the draws. First try to shut or close these vents down. Or you can tape over them to restrict the flow . The normal refrig temp is between 37 to 40 deg.
Jan 20, 2013 | Viking VCSB423 Side by Side Refrigerator
Cuccumbers and tomato freezing in the bio-fresh safe draw. this has only recently started to happen - we have had Liebherr for over 12 months and not had this problem. the draw setting is on the high...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 01, 2011 | Liebherr KB4250 Refrigerator
The custom cool bins on my ge profile refrigerator freezes anything i put in it. The rest of the fridge is normal temporarture.
Did you ever find a fix for this? I have the same problem, it even freezes items in the produce bin above the custom cool bin.
Dec 25, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My Jenn-Air JCD2389DE* constantly freezes produce
Hi; Need more info. Does the refridg. cycle on and off during the day. When You say no matter where You set the tstat concerns Me to think that the unit might be
runing all the time. Remember the coldest place in the refridgerator is the bottom. Excluding the freezer compartment. Also are the door gaskets in good condition this will also cause the unit to run more
...alpharome416
Feb 23, 2010 | Refrigerators
Crisper draws are freezing produce. Kenmore Trio 795.77562.600
If you can find the duct work behind the draws you might find an air control, if you have a contract with Sears - you can call them back, the part that was replaced has a Garn.T and or 30 days on service, when you ajust the temps it may sometime act up but has a default and will return to that. Cold air drops down. read the manual that came with the Refrig. Buying a service contract might be the best thing for piece of mind - Sears covers everything, even plactic and paint ( scratches). most everything is plastic in the refrigerators today and are very expensive, 3 doors allow more air into the unit then a 2 door because of the seal between the doors, just 2 pieces of rubber overlapping .
Act on this as fast as you can, 30 days on service goes fast and a service call runs about 75 dollars . Oh ! don't put wet veggies in draw and rap everything with Plastic wrap, veggies only least about 4 /5 days then become soft and lose taste and color.
Jul 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Crisper produce freezing
are they long times between door openings of the doors, this can cause cold air to migrate to the bottom of the fresh foor area and freeze produce
if this is not the issue, then turn down the fresh food control to a lower number monitor for 24 hrs
if this does not help replace the fresh food thermastat
May 20, 2008 | Kenmore 71812 / 71814 / 71819 Bottom...
GE 22.3 Cu. Ft. Bottom-Mount Refrigerator - White-on-White Logo
47 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
