I bought this printer because I was having problems with the 430DN transport and feed with cardstock. This printer will not let me print cardstock even though the settings are bypass tray with cardstock it still consistently tells me to change - when I print from pagemaker, it processes, then alerts to change bypass settings, I press start, change to bypass, cardstock, and it will print, have to do this every time. The defaults and the config page show bypass tray priority for cardstock. Help, I can't win. thanx
  • alan_memoria Mar 31, 2011
    That's not the problem, works in Word - It's something in Pagemaker, it needs a new PPD or something. Also works with the PCL Driver just not the Postscirpt Driver which I need as I'm printing files that need quality for customers.
    These printers are a much better category than the link provided - they are meant to print heavier cardstoc than I'm using.
  • 2,427 Answers
Its a simple setting you need to add to the default print setup. Now I'm not sure what version of windows your using so I'll describe the procedure for XP and win 7 / vista..
Windows XP.
  1. click start
  2. click printers and faxes
  3. right click your printer and click properties
  4. set it up as you always do to print the card stock, remember to select the proper feed tray and bypass-settings (as you always have to do from page maker or what ever program)
  5. save the new settings as your default settings.
in win7/vista
  1. click start
  2. devices and printers
or click start. control panel, printer /faxes
follow steps 1 - 3
Posted on Mar 31, 2011
  • Rishi Roshan Ali Mar 31, 2011
    in page maker print settings, turn off all error confirmation notifications.
  • Rishi Roshan Ali Apr 05, 2011
    did you try turning off the confirminations ?? did u get it working ?
  • 12,061 Answers
Hi, well you really do have a little, ahem, problem now don't you. Well from what I understand, any settings for anything else but the default tray, are non-persistent, meaning you only get to set, and do it once, each time, then "It" "Forgets". Unless it specifically states that it will do multiple copies in cardstock from the tray concerned, usually it is a single one shot deal, as "They" expect that usually cardstock, is loaded one sheet at a time, the same thing with envelopes. Of course this doesn't apply to normal paper.
This is simply the way in which the operating system is written, I guess they never figured anyone may wish to print on cardstock more than one at a time, multiple copies? So unfortunately you are stuck, with the way it is.
I have thought on this and can not come to any other conclusion, than to try an get a printer that can and does print cardstock from the default tray, or one that allows multiple copies to be printed on cardstock. I guess multiple cardstock is not all that a common thing, but I am sure that there must be suitable printers out there that will do the job.
You might consider this below, just to get the idea of what i mean.
http://bit.ly/9amuuM
Posted on Mar 30, 2011
Why is my printer printing half of page on cardstock
If you are feeding it through like you would with normal weight paper than you are always going to get this. Most printers have a secondary feed point for heavy stock paper. Usually in the back.
Aug 30, 2014 | HP Photosmart C5280 Printer
Cardstock won't feed
You need to hand feed these things.....one at a time. I sometimes find that I have to "help" it a little bit to get it feed by putting just a bit of pressure on the paper to push it into the feeder. Another trick is to make sure the front edge is turned up just a bit. (I usually take about 10-15 pieces of cardstock and roll them, and then feed them one at a time) that seems to work pretty well, too
Jan 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
Ricoh Aficio CL1000n Print quality very low.... not sure why. Trying to print color and it comes out very stripe-y. I used to use a Ricoh at my former office and it worked great. Everything I've read about...
the post scrip option is option but your printer might nit have installed this option .
But about the print quality you should call service to fix it here is nothing you can do
Jun 16, 2009 | Ricoh Aficio CL1000N Printer
Samsung ML-2510 Laser Printer Jams
printer only supports up 120gsm,anything thicker will jam.
Jun 08, 2009 | Samsung ML-2510 Laser Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Paper too thick?
You will need to use the manual feed and insert the cardstock one page at a time. First look at the rear of the printer for a purple dial. Roll the dial downward. This will allow the printer to exit straight out the back of the machine. Allow enough room at the rear of the printer so the cardstock doesn't hit anything on the way out. Next look at the front of the machine at the **** just above the paper tray. You'll see an envelope icon. Align the cardstock when manual feeding one sheet at a time to the left side of the **** next to the envelope icon. When you hit "file, print" select MANUAL FEED in the print window.
The 4L will only do cardstock by one at a time in the way noted above as the feed system isn't strong enough to make the sharp bend coming out of the tray or in the back to bend it around and into the top tray.
Sep 22, 2008 | HP LaserJet 4L Printer
Paper keeps jamming
To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
Jul 08, 2008 | Brother HL 1440 Laser Printer
HP 2575 Jamming on cardstock paper
most likely that printer would do it if it were brand new, but after a period of time, the mechanism becomes 'tuned' to a certain size paper..
you may need to realign the rollers, etc, to accept the thicker paper.
my recommend..go to a local print shop with paper and images/data on cd, and let them do it.
May 08, 2008 | HP Photosmart 2575 All-In-One InkJet...
Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
Oct 29, 2007 | Dell 924 All-in-One InkJet Printer
46 people viewed this question
k24674
