Question about Vizio E322VL 32 in. LCD TV
Vizio e322vl, vizio logo light flashes and power button is inop while its flashing. this problem is intermittent. i have tried unplugging when this happens but that does not seem to help.
  • 12 Answers
SOURCE: My vizio 32" flat screen keeps shutting off by
sound like the main board is starting to fail
Posted on Mar 07, 2011
phongnv
  • 56 Answers
SOURCE: my vizio vx32l will not turn on. vizio logo will
The main board has failed. Replace the main board will fix the problem.
By the way, where did you buy the TV? If you have bought it from Costco then try to give them a call to see if it still under warranty.
Hope this will help.
Posted on Feb 19, 2009
  • 4 Answers
SOURCE: Vizio m550nv led lcd tv. Problem began a couple
I had same problem. Unplug set for 10minutes then plug it in and let it go thru it's startup routine.
Posted on Jan 27, 2011
  • 8457 Answers
SOURCE: I purchased a Vizio 32'
This tv have the main Tuner signal board have intermitten problems.Return this tv for a refund.Can't return it make a claim with Ebay,Pay PAL or ur credit card if pay by credit cards.
Posted on May 12, 2011
chesterpendi
  • 195 Answers
SOURCE: Vizio E550VL won't turn on. The vizio logo just flashes orange.
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Dec 07, 2011
I have a Vizio tv that the logo light is flashing.
Corrupted firmware. Just try a hard reset. If it do not help; d a firmware update. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail. make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset.
Sep 29, 2016 | Vizio SV470M LCD TV
E322VL has power but will not turn on
its usually a capacitor on the power in circuit board..Little black canasters..you will notice the top of the bad one will be arched or swollen..sometime gell will be oozing from it also. its usually very noticeable when its swollen when compared to the others around it..
Dec 27, 2013 | Vizio E322vl 32-inch Lcd Hdtv With...
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
Vizio sv41xvt flashing logo. won't power up
Sounds like either a power circuit board or mainboard failure. I'm going through same problems, mine is power board failure.
Jan 11, 2013 | Vizio SV471XVT 47 in. LCD TV
List of program codes for vizio
Hello
Four digit Universal remote code to check with Vizio TV is: [ 0081 ]
Five digit codes with RCA RCR 312W remote control are:
11758, 10864, 10885, 11756
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jan 05, 2012 | Vizio E322VL 32 in. LCD TV
VIZIO VX37L --Power surge killed my tv!!
a power surge usually takes out the power supply itself
Nov 05, 2017 | NEC PX-42VM3A 42 in. EDTV-Ready Plasma...
Vizio E322VL 32 in. LCD TV Logo
558 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
