Question about Rival VS230 Seal A Meal Vacuum Food Sealer
My Seal-a-meal won"t heat up, The motor works and
5 Suggested Answers
  • 3 Answers
SOURCE: Unit will not heat and Hand free light will not
My husband is a fisherman and swears by his vacuum sealer, but he was about to trthrow it through the window last week when it stopped working.
The motor would just run and run, but the vacuum never kicked on.
I found an answer online that solved his problem - apparently, it's all about bag placement.
When you're just trying to seal one end to make a bag cut from a roll, make sure the end of the plastic is just on the front, flat heat seal strip and is NOT touching the black, rubber gasket that lines the vacuum tray, Also, make sure the end is NOT hanging over the gasket and into the vacuum tray.
Apparently, the machine was sucking, but air was constantly come through the other, open end.
Once you've sealed a bottom into your bag and have added your contents, then you put the open end (after making sure it's dry) all the way into the vacuum tray.
Hope this helps, good luck! I was so happy to find an answer online that I figured I'd share it with others.
Here's to fresh fish!
Posted on Mar 10, 2012
  • 14 Answers
SOURCE: where can I find a replacement heat strip,
EBAY. Look for PTFE Teflon Adhesive Tape.
http://www.ebay.com/itm/NEW-PTFE-Teflon-Adhesive-Tape-Nonstick-heat-Sealer-19mmx10m-Impulse-Sealer-/170848027703?pt=LH_DefaultDomain_100&hash=item27c7560437&vxp=mtr
Posted on Aug 15, 2012
pdarrach
SOURCE: When I go to SEAL, it burns a small hole clear thru the bag. One little metal peice on the sealing strip has burned right thru the white heating strip, therefore, it isn't sealing completely.
You need new tape to replace the one presently covering the heat element. You can get a roll of it for just US$7.99. Look at the FixYa question "where [or how maybe] can I get a new tape." I think that you have to be sure that the heat element is flat. I bought a used unit with that problem and the element had somehow gotten bent. Ordered the tape this morning and the cost is worth the hopeful fix.
Posted on Oct 02, 2012
pdarrach
SOURCE: Seal-a-Meal seal has blister on it
I think that you have the same problem that I have. The protective tape over the heating element [a strip in my case] has a hole in it and allows the element to come in direct contact with the bag. Also, the heating strip had a kink in it was was no longer flat. I carefully cleaned the heating strip and flattened it out as best I can. I have ordered some tape from : http://www.ebay.com/itm/170848027703?item=170848027703&viewitem=&sspagename=ADME:X:AAQ:MOTORS:1123&vxp=mtr to replace the defective one. A simple job.
Posted on Oct 03, 2012
After hands-free red light for sealing turns on, why does it take a long time to start sealing?
Seal-a-Meal FSSMSL0160-000 Vacuum Sealer - Amazon.com
www.amazon.com > ... > Vacuum Sealers
Amazon.com, Inc.Handy indicator lights for "Hands-Free" and "Sealing", plus Open/Cancel button. Keep your busy kitchen running smoothly with help from this easy-to-use Seal-a-Meal ... With its sleek, straightforward design, the compact appliance effectively ... After completing the vacuum sealing cycle, both the motor and the "Sealing" ...Missing: red
Amazon.com: Rival Vacuum Sealer: Kitchen & Dining
Amazon.com, Inc.
Rating: 3.6 - ‎233 reviews
Online Shopping for Kitchen Small Appliances from a great selection of ... Rival FSFGSL0150-015 3 Step Vacuum Sealer w/ Bag Starter Kit ... You push down....wait for Hands-Free light & Sealing light to go on....let go....wait for lights to turn off. ...After a couple of bags were done, I started having an issue in which the unit did ...Missing: red
Amazon.com: FoodSaver FSFRSH0051 FreshSaver ...
Dec 25, 2015 | Kitchen Appliances - Others
Where can i get a new heat tape for my seal a meal
Crazy,, I've only used it three times and the heat seal already went out,,, will never buy this product again
Apr 29, 2014 | Rival VS230 Seal A Meal Vacuum Food Sealer
The seal a meal will vaccume but it will not seal. It just keeps running the vaccum process. Do I need to replace my appliance? Or is this a fixable problem
You can fix it yourself for $3 or so if you look for the thermal cutoff (a resister looking device) You can get this at a quality electronics supply. If you just cross the cutoff it will work but could be a fire hazard.
Oct 12, 2013 | Rival Seal-A-Meal VS106 Vacuum Food Sealer
Jul 17, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
Unit will not heat and Hand free light will not come on.
Oct 24, 2011 | Rival VS230 Seal A Meal Vacuum Food Sealer
Need upper and lower sealing gaskets for Rival Seal-A-Meal VS107
I've been told you can order replacement gaskets from Rival, about $6/set 1-800-557-4825 and $8 shipping, so may want to stock up (prices were quoted from 2012)
Sep 02, 2011 | Rival VS107 Seal A Meal Vacuum Food Sealer
My Seal-a-meal won't heat up to seal the bag. The motor works and the ''hands free'' light comes on, but the heating strip is cold to the touch.
just bought mine - how long does it take to heat up? it's been 10 minutes already, I don't feel any heat. no lights coming on, but when I pushed on the lid, the vacuum started, so I know it's "on"
Jan 08, 2010 | Kitchen Appliances - Others
Seal-a-meal won't seal
Take apart and see if wires are connected That is what was wrong w/ mine. Soldered wire now works fine.
Mar 30, 2008 | Vacuums
Rival VS230 Seal A Meal Vacuum Food Sealer Logo
786 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ric Shull
Ric Shull
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
