Question about Canon NP 6650II Copier
Error code E001; machines switches itself off after displaying this code. What does this mean?
  • Canon Expert
  • 1,326 Answers
Your in luck, Canon really did not change there error codes from way back then..... A E001 means you have a problem with the fusing unit. You may have a blown thermal fuse or one of the heatting lamps or you may have a bad thermister. It may be one or all of them. Did you try to rest the error code?
Posted on Apr 01, 2011
  • Mohammad Ropshop
    Mohammad Ropshop Apr 22, 2014
    Would you please tell me how can I reset the copier?
  • Mohammad Ropshop
    How can reset the copier/
How can repair an error of canon 2202 E000-0000 error code?
The E000, E001, E002, E003 and E007 are temperature error codes. Fixing these errors are necessory part of every
photocopier and printer. It is usefull to apply high temp and pressure to melt toner into the fibers. follow these steps
to reset E000, E001, E003 and E007.
Enter into service mode by clicking on key "2" and "8" the SSSW will display
Change bit switch 1 to bit 0
Press OK
http://canonprintersupport.us/
Sep 05, 2016 | Canon Office Equipment & Supplies
E001 Error code. Register locked up, Casio TK6500
Mode switch position changed before finalization.
(Return the mode switch to its original setting and
finalize the operation.)
See this link
http://www.calcullus.co.nz/20938423984/CE6000-TKT500.pdf
Aug 17, 2008 | Office Equipment & Supplies
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
Aug 13, 2013 | Canon Office Equipment & Supplies
I am using a SE-S300 and can not clear a E001 error code!! Any ideas??
E001 = Wrong Mode, which means u had did something in another key mode but not yet done.
Solution 1 :
1. Turn the key to another position where the screen do not show E001
2. Press [Subtotal]
3. O.K
Solution 2: Flag Clear the Machine
1. Key turn to OFF
2. Keep Press [FEED]
3. Key turn to PGM
4. Release [FEED]
5. U will see "INIT 0000000000"
6. Press [Subtotal]
7. U will see "FFFFFFFFFF"
8. Wait for 10 seconds, the machine will print
9. OK
Nov 15, 2009 | Casio Parts Cash Register PC Desktop
Canon IR600-550-60. Error code E001.
550 just gave an error code E060, what do I do?
Nov 09, 2009 | Canon imageRUNNER 600 Printer
E001 switch off the machine and on again
E001 is a fixing assy fault you have to clear the error in service mode after correcting the fault of course. I would try clearing the error code in service mode 1st. press *28* function tab clear tab error ok then restart copier
Sep 09, 2009 | Canon imageRUNNER 400S Copier
On copier sow display bord "Swith main power off and on E001
When switch on ImageRUNNER 330s Grayscale Copier then no display on dispaly board. But Copier front yellow led is on. Please solve this problem.
May 29, 2009 | Canon ImageRUNNER 330s Copier
Canon Imageclass D860 - I have a System Error E000 code on the LDC display. No paper jam or other problems evident. Disconnected power for 10 minutes and that didn't help. For this error code I am to...
This is a reprint from another tech, he was right on with this...
okay lets shed some light on the E000 error code on the D680, D880, IR1300 family ( including the 1310,1330,1370,1630,1670)
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used until the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
E002 fuser temp dropout means the fixing assy has cooled below a set point during a copy session
E003 fuser no response means the fixing assy didn't even attempt to warm up at power on
How to fix, most common problem is bad power setting 4 E002's either brown outs of brief power failures.
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arrow buttons to scroll to #4 printer reset press set. press the appropriate arrow key under the YES to clear the error. unplug the copier and reboot. At this time normal function should return if not and it resets a E00 the you can assume either the fixing assy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to research the problem to avoid spending money on excess parts
Hope that helps...
Lbcoaster
Aug 08, 2008 | Canon Office Equipment & Supplies
System Error E000
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used untill the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser overtemp means the fixing assy has exceeded the manufacures maximun temp limits
E003 fuser no responce means the fixing assy didnt even attempt to warm up at power on
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arow buttons to scroll to #4 printer reset press set.press the approprite arrow key under the YES to clear the error. unplg the copier and reboot. At this time normal function should return if not and it resets a E00 the nyou can assume either the fixing asy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to reserch the problem to avoid spending money on excess parts
Jun 05, 2008 | Office Equipment & Supplies
Canon NP 6650II Copier Logo
235 people viewed this question
old marine
old marine
