Skull Candy Double Agent Stereo Headphones in Green Ships in ''24'' Hours Logo
Posted on Jun 22, 2017
When i Try to Turn On I Press(Hold) Play/Pause for 3 seconds and Nothing happens,then when I try to Charge The LED Indicator doesn't go red ,It's turn blue! and nothing happens try to enter the SD card it says:"The Disk Drive G is not formatted. Do you want to format it now?" i press yes and nope then it says:"Windows was Unable to complete format" So anybody has any idea what wrong with it? (sorry for my english if it's wrong).
2 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 31, 2010
SOURCE: batt. does not charge, even after 24 hours
Call up skullcandy and you'll get a replacement. They are really good at that.
Anonymous
  • 149 Answers
  • Posted on Dec 30, 2010
SOURCE: my agents will not play music. I have charged them
Sounds like an internal fault. Take them back to the store, it's a common problem with these sets. I'd reccomend that you get a pair of Ultimate Ears or Shure ear-buds. Don't be afraid to spend $100 or more on a pair, it'll be worth it.
How could I reset a Zanussi zwf580 WM that no matter which program I select, it changes automatically to the drain mode light?
If the START / PAUSE button lights up red, the washing machine detects a malfunction. Now you should count how many times the START / PAUSE button lights up red and tell to us what kind of malfunction is being done.
Try to rapid reading of alarm codes when the appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and the nearest option button for at least two seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
LED indicator START / PAUSE with red light = indicates the first digit of the alarm code (family)
• LED indicator START / PAUSE with green light = indicates the second digit of the alarm code (internal number of the family)
Dado
MY LG TONE HBS-730 stuck on incorrect pin i have samsung mobile
Here are some steps you can try:
Reset the Headset:
Turn off the headset.
Press and hold the REW (rewind) button and the PLAY/PAUSE/STOP button simultaneously for about 5 seconds until the LED indicator flashes purple.
The headset will reset, and you can try pairing it again.
Pairing with Samsung Mobile:
Make sure your Samsung mobile's Bluetooth is turned on.
Slide the power switch on the LG HBS-730 to the "ON" position.
The LED indicator on the headset will be solid blue, indicating it's in pairing mode.
On your Samsung mobile, go to the Bluetooth settings and search for new devices.
Select "LG HBS-730" from the list of devices.
If prompted for a passcode, enter "0000" (four zeros).
Once paired, you'll hear "Your headset paired."
Check Battery Level:
Press and hold the VOLUME DOWN button for 1 second to check the battery status. The audible alert will indicate the battery level (high, medium, or low).
Charge the Headset:
Connect the charger to the headset. While charging, the LED indicator will show a solid red light.
When charging is complete, the LED indicator will turn off.
Remember that the headset will automatically turn off if not paired within 3 minutes.
If these steps don't resolve the issue, refer to the HBS-730 User Manual for more detailed instructions.
How do you connect a charge 3 with a flip 4
To connect a Charge 3 and a Flip 4, you will need to follow these steps:
  1. Make sure that both the Charge 3 and the Flip 4 are turned off.
  2. Connect the Charge 3 to a power source using the supplied micro-USB cable.
  3. Press and hold the Bluetooth button on the Flip 4 for 5 seconds until the LED starts flashing blue.
  4. On the Charge 3, press and hold the volume down and play/pause buttons simultaneously for 5 seconds until the LED starts flashing white.
  5. On your phone or other device, go to the Bluetooth settings and look for the Flip 4 in the list of available devices.
  6. Select the Flip 4 and follow the prompts to pair the two devices.
  7. Once the Charge 3 and the Flip 4 are paired, the LED on the Flip 4 will stop flashing and remain solid blue.
I hope this helps! If you have any further questions or if you are having trouble connecting the Charge 3 and the Flip 4, don't hesitate to ask.
2answers
I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
THERE IS NO CODE SEARCH BUTTON ON MY REMOTE
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Control remote programing
Try these methods.
Direct Code Entry
Code Search
Tv code for symphonic
0053 0189 0227 0456 0024
Direct Code Entry
Code Search
Zanussi ZWF580- after the wash cycle I press the red button to rinse & spin but it just tumbles & rinses again, then the red button comes on again. This could go on all day. I find that to finish...
programme):
Dado
6helpful
My ipod chromatic is completly frozen.
You are doing the reset wrong. Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
2answers
Connection not recognized
I have often had the same problem. Resetting the software enabled me to recover. Press and Hold the Play/Pause (center) button and the Previous Song/Rewind (rear) button•at the same time. I held it for about 5 seconds. Then I released both buttons, then pressed the Play/Pause for about 1-2 seconds, the unit powered up and I was able to connect and charge the unit.
• If the reset procedure does not work, you may need to restore the internal software.See your .pdf users guide, this will erase your song list.
Good luck.
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
ADMIN Andrew
ADMIN Andrew
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
