Question about Samsung HT-BD1250 Theater System
Just hooked it up and only 2 front speakers work . all speakers work when switched around any tips
    Brigadier General:
  • 8,546 Answers
You don't mention having followed the manual so...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-BD1250T-Home-Theater-Systems-manual/id/23336ag421/t/2/
Did the speaker setup test tones work on all channels?
Posted on Mar 31, 2011
Can you have just 2 channel by hooking up to right & left front speaker posts on 5.1 surround
short answer.....no. If you hook more than one speaker up to a single channel, it will lower the impedence and will damage the amp. You can hook up multiple speakers by using a speaker switch box between the speakers and the amp. This will match the impedence and should keep the amp from blowing.
Dec 21, 2014 | Panasonic Technics SA-G76 AV Control...
Rear speakers are dead, never got them to work. Changed front to back and rears work so speakers and wireing are good. Is it possible that because I did not hook up a center speaker this is the problem?
if its a 5.1 channels it means 2 front speakers,2 rear speakers or either the center speaker or the subwoofer.try to hook up either center speaker or subwoofer.
Jun 05, 2010 | JVC RX-888V Receiver
How ot hook up speakers on this amp/
As far as I know, your sound will drastically improve if you run them +- and +-. Connect the one speaker correctly (+-) and then with the music still playing, try swapping the wires on the other speaker around and see which sounds better + to + or + to -
Hope this helps
May 20, 2010 | Volfenhag ZX-8300 Car Audio Amplifier
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
May 19, 2009 | Sony STR-DE685 Receiver
How to hook up my stereo
I hqave taken the time to look this up, please take a few seconds rate the solution, thanks.
1995 Honda Civic Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Jan 06, 2009 | 1995 Honda Civic
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
Multiple speakers in same outlet
How this reciever is set up is there are left and right A and left and right B Only one 8 ohm speaker should be attached per outlet. if you exceed that your driving the channel at a much lower resistance then the units designed for and the channel will burn up.. Oh it might last a short time but bet your last dollar it will burn up the channel if you over load it. Please dont forget to rate this.
Oct 15, 2006 | Pioneer VSX-454 Receiver
Not getting sound from right speaker
How do you have the audio hooked up from the TV set? If its s video or RCA plugs? If it is switch them around and see if it swaps channels that goes out . If it does then the output cable or the jack is bad. If your using an HDMI ir a scart cable. The cable or connections could be bad. Unplug it and reinsert it or while the units on mover it around and see if the audio comes back on.
Sep 22, 2006 | Yamaha RX-V550 Receiver
Samsung HT-BD1250 Theater System Logo
118 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
