Question about GTCO QuikRuler III Module Legacy (without Digitizer) for use with RollUp III? or Super L IV (RDA840033002)
Relocated digitizer and when set up it peeps with message running self test no digitizer
  • 47 Answers
Make sure the Digitizer is set to Superset Code S01, it may also be a bad cable,check all of the cables for wear.
These units do go bad sometimes,so you may have to call GTCO and have them look at it.
They shouldn't charge for an evaluation.
Posted on Oct 24, 2013
Turbochef self test memory
My turbochef tornado gives an message of "Self Test Memory" and sometimes continue to warm up, sometimes no. Sometimes he is running ok and then he shutdown and the message appears again. Any suggestions?
Jun 12, 2013 | TurboChef C3 Single Oven
Natural gas generator starts but surges under load
Install a pressure gauge at the gas inlet regualtor, conform it isn't less than specs normall 11-13" WC pressure. test this when it is surging, it sounds like fuel, or also incorrect governor gain setting
Jan 19, 2013 | Caterpillar CAT 150 KW Natural Gas Standby...
I have aPlasma tv sitting above the fireplace, is it safe to use the fireplace?
Hello; If you add heat to the air where the set is located, you are asking for trouble. Just because it is located above the fireplace does not mean added heat. Try putting your hand on the top of the set after running for 10 minutes. Then check again every 20 minutes. If at any point the top of the set feels fairly hot, you may need to relocate set. Once relocated, do the same test. Plasma TV's run hot after an hour. Give your set a cool down period after every 2-3 hours. This will extend you sets life. If the set is not much hotter away from the fireplace after these tests, you can probably safely put it back at the fireplace. John
Dec 19, 2010 | Televison & Video
Hi there, my Samsung WB500 camera can not get it's lens closed. It stands open all the time and is doing nothing. When I turn the power on, it 3 times makes a hard noise 'peep peep peep', no display and...
This is a common problem with cameras. They can get bumped when the lens is out, and that can jam the gear assembly, or break a gear. I could run down all the things you can try to free it up, but there is a better web page that deals with issues like this. The page deals with error messages for the lens, but the beeping you hear is an error message, also. Follow their suggestions to try to free the lens up- maybe you'll get lucky. They say that, in about 50% of the cases, it can be fixed by trying their suggestions. Here's the site:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If nothing works, make sure you get an estimate before getting the camera repaired. Sometimes the cost of repair justifies going ahead and purchasing a new camera, on sale, and is often less expensive than having it repaired. Good luck! Hope you get it working again!
May 18, 2010 | Cameras
I have a dell computer and printer. We relocated
Greetings,
Does the printer show that it is receiving power?
Can the printer run any self tests?
It is possible that the USB cable is the failure point although I would expect that the port got banged around during the move.
The quickest isolation test is to replace the USB cable.
If that still does not work, then a service call may be an option. One other thought, if your PC has multiple USB ports, try the cable in one of them.
Don
Dec 13, 2009 | Dell 1600n All-In-One Laser Printer
Lexmark x3330 Error message
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier.
Next, try this printer self-test by following the steps given below:
1. Turn off power.
2. Press and hold the "Black Copy" and the "Power" buttons at the same time. Continue holding then until the screen displays "Mfg Menus Enabled."
3. Press the "Menu"(--->) button 2 times.
4. Screen will read "LCD Button Test," press "(-)" button 2 times.
5. Screen will read "Single Test Page," press the "Menu" button once.
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about a 1/2-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
Relocated printer and menu screen displys call service, 0150:0004428 after self test boot. Will not come online.
Sounds like something came loose in the move. Remove and reseat all User Replaceable parts. Check documentation for the reset procedure (usually requires holding certain buttons while powering on) or provide the make and model so I can see what I can find. Also try another outlet.
Dec 07, 2008 | Office Equipment & Supplies
Dll user32.dll problem
Certain programs may not start after you install security update 925902 (MS07-017) and security update 928843 (MS07-008) on a computer that is running Microsoft Windows XP with Service Pack 2 (SP2). Additionally, you may receive an error message that resembles the following: application_executable_name - Illegal System DLL Relocation
The system DLL user32.dll was relocated in memory. The application will not run properly. The relocation occurred because the DLL C:\Windows\System32\Hhctrl.ocx occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL.
Nov 21, 2008 | Dell Dimension 2400 PC Desktop
GTCO QuikRuler III Module Legacy (without Digitizer) for use with RollUp III? or Super L IV (RDA840033002) Logo
73 people viewed this question
Top GTCO Computers & Internet Experts
David Payne
David Payne
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
