Question about KitchenAid Ovens
How to clean stove racks must I take them out of oven or clean oven with them inside?
  • 2,418 Answers
Best way is to take them out onto the drive way and spray them with oven cleaner and hose them off with a garden hose. If you need to scrub them use a scrubbing pad w/ good gloves and EYE protection. ope this helps Fixya up.
Posted on Mar 30, 2011
How do I use the self cleaning option on my Kenmore stove model# 970C623331. Do I remove oven racks?
that model doesn't come up,that could be the serial number,do you know that when the dryer is in self clean it gets up to 1000 degrees,when it gets this hot it can do damage to the electronics in the oven,from what i've seen on other peoples ovens i will never use the self clean again,but to answer your question remove the racks and clean them in the sink or you can soak them in the tub,whatever is easier for you.i get in there with an sos and scrub,if any spills are big on the floor i wet it and let it sit for a minute or two and scrape it out with a putty knife or you can use a spatula,if it's really bad easy off is made safe for most self clean ovens now,don't put tin foil on the oven floor when you cook,it can damage the floor,so watch out for that.kenmore doesn't make anything so you need the model number to see who made the stove,if you open the drawer under the oven door,look on the left or right side of the frame and you'll see a tag with the model and serial numbers,go here,put your model number in and you can look up the manual for your stove.hope this helps you out.
https://www.searspartsdirect.com/model/search.html?q=970C623331
Feb 27, 2018 | Kenmore Ovens
What can you use to clean oven racks on electrolux stove?
well if it fits in your dishwasher with top rack out then that works great , or if there just too large , try soaking in a home made pan of dishsoap concentrate , I made a pan large enough to fit some from a nasty ole commercial stove out of an ole tarp that I had covering up the wood pile (the wood didn't mind ) and piled a few things laying about under its edge to form a shallow pool in the yard then a bit of water from the ole hose and lots of good strong dish soap , a few hours gone by soaking and it hoses right off , yuk and all !!
Dec 21, 2016 | Electrolux Ovens
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
How do you use the self-cleaning ??? i lost my manual within minutes of getting....
we have a sears kenmore model and this is how we do it. remove everything from stove including the racks, close oven door, slide door lock latch to the right till it locks the door. turn knob to clean. when it is done cleaning it will turn off by itself. on some models the door latch will not slide open when done. just wait for it to cool if this is the case. it should tell on the touch pad on stove the hours that it takes to clean it. good-day !
Jan 20, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
My oven racks don't fit after self cleaning the racks are to narrow or oven is too wide now
No.... the heat warped the sides of the oven and wrecked it......you try and beat the sides back out.... either way you have a junker now....
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 12, 2010 | Ovens
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    How to clean oven
    We called a neighbor who has a similar oven. Thanks for you interest. Utne
    Dec 13, 2008 | Dacor ECD230 Epicure Electric Double Oven
    New fridgidaire self cleaning oven w/ no insturction manual
    its a new oven?? press the clean button the arrow up(the display should read 3:00, press start,the door will automatically lock and your on your way. remember to remove racks first, they will warp and discolor
    Feb 24, 2008 | Ovens
    Self cleaning oven
    pretty much hit clean time will show 3hrs then select start can down load new manual at http://www.frigidaire.com/support/support.asp
    Jan 19, 2008 | Ovens
    Ovens Logo
    70 people viewed this question
    Top KitchenAid Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
