Question about Dishwashers
Dishes not coming out clean. Dish washer 3-4 years old, never serviced
  • 3,740 Answers
The dishes being cloudy and spotty stainless is a symptom of believe it or not in most cases a drain restriction external to the dishwasher. The drain is most likely partially clogged somewhere after the dishwasher. This can be in the area of the sink Air-Gap, the Garbage Disposal Port or if a direct sink connection the sink connection port. You need to pull the cover off of the Air-Gap, unscrew the inner cap then lift off the cap and look inside the Air-Gap for debris. Some installations do not use an Air-Gap but most do. Use a flashlight and look inside at the Air-Gap to sink hose connection port also. Then check the rest of the plumbing connections for restrictions. I am sure you have probably already done the above but you must make sure you check the sink connection ports for obsructions. The most common obstructions are the garbage disposal port and the Air-Gap. Make sure to check for signs of a fold in the drain hose also. If you notice any folds straighten the hose and tape a stick over the outside of the hose like a a splint to keep it from folding again.
There can even be something blocking the pump inlet like soft plastic. Last check is to inspect the motor pump impeller for any looseness or broken blades.
Most wash water systems have the lower spray arm, spray arm base support, tower, a diffuser, the pump which that can have both upper and lower impeller blades along with a macerator. Any one of these can affect your dishwashers performance.
If you are absolutely certain that the drain is clear... you must start looking at the wash system components above "In italics"
Normally of you do all of the above you will resolve your dirty dishes post cycle problem.
If you want details specific to YOUR dishwasher I will need you to provide a COMPLETE model number in you next response.
Thanks for choosing FixYa,
Kelly
Posted on Mar 30, 2011
  • Dishwashers Master
  • 8,404 Answers
The key ... let me say that again ... The Key to clean dishes is hot water in your machine. Second is the cleaning compound you use. I suggest you get hot water in your sink before you turn on the dishwasher. I think you will see a big difference.
Thanks for your interest in FixYa.com
The Dish Washer is Not Hot enough
If an adjustable thermostat is provided adjust the dial. If it is an electronic type, check the sensor with a correct part no.
Refer user guide also for the adjustments.
May 27, 2010 | Jet Tech Systems 24 in. F18DP...
Dish washer 3 1/2 yrs old making a growling/vibrating sound.
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jan 28, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
LG DISH WASHER LE CODE 4th.TIME
Have your service tech remove the door cover and check the wiring harness completely. Especially where it flexes at the bottom. LG had a problem on some of these models with the insulation degrading on the wirw. Replace the wiring harness and the motor again.
Oct 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
How do you fix a noisy whirlpool dish washer DU1100XTP(Q) ?
A hard object has entered the wash module (on some models).
When the object is ground up, the sound should stop. If the
noise persists after a complete cycle, call for service.
Mar 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
MAYTAG DISH WASHER MODEL 41-ESP4-DISH
I suggest calling Maytag and have a tech come out to look at it. Appliances come with a one year parts and labor warranty.Use it before your one year is up.
Nov 17, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Wont clean dishes
Check to see if the Upper and lower spin arms rotate easy .. check to see if there is anything blocking them.. also check the venturi assembly (the tower is in the center of the lower spray arm} As it is what supplies the upper spay arm. let me know if this helps?
Mar 06, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
