Question about Canon PIXMA MP170 All-In-One InkJet Printer
Waste ink pad full error message
The error message shows up waste ink absorber full on my canon pixma mp 170 all in one
    Genius:
  • 2,785 Answers
Plz check the website http://www.fixyourownprinter.com/forums/inkjet/50418#1
Posted on Aug 05, 2008
Ink absorber full
There are two possible reasons for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads
. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error.
Reset the Printer using an MP Tool
Mp Tools are utilities designed to clear errors that will appear in an MP160 printer. Download this MP Tools here.
while the printer is on Run this software
1. Click Reset Main (main) to reset the waste ink counter and
2.
Click Reset Platen button (E27).
If errors still persist.
Press and Hold down Reset button and wait until the printer restart.
Release the Reset button and wait until it fully initialize.
Happy printing.
Please comeback and rate this answer.
Thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber is full cannot print
Mp Tools are utilities designed to clear errors that will appear in an MP150 printer. Download this MP Tools here.
2.
Happy printing.
Aug 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber (sponge part)
2.
Happy printing.
My printer shows E 2 7. how can i fix it?
i believe on this model the error code means that the ink tank is full...
http://www.mediafire.com/?s2pa54m5z2wqwru
this is a link to my hosting site where you can download the software reset tool for a the MP models...
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Start with printer on then run this software
  • Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Additional information error codes for the MP models...
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error – USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Aug 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Won't print error message 5b00 on screen. How can
5B00 is the waste ink absorber full message, only a Canon repair shop can reset the error code.
Jul 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
My Canon Pixma MP 170 tells methe waste ink absorber is full...
It is a shop repair since you have to use Canon diagnostics to reset the count and clear the error. The new part is around $10.00 only.
Jul 01, 2009 | Office Equipment & Supplies
Problem absorber full
Here and hope you find it useful. use the mp150 procedure
May 23, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cartridge jammed / Waste Ink absorber almost full
Waste ink pad or pads are full and need changing.
Under your ink carraige cradle it is,
It will be full, bit of a dirty job.
Hope this helps
Ric.
Apr 17, 2009 | Office Equipment & Supplies
CANON PIXMA ERROR 5800
The waste absorber is full ,Replace the pads
then if you still get the error,you can reset it by following the directions below.
(reset without replacing pads can cause damage)
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by pressing <--- or ---> then OK
3)SET ABS-M LEVEL TO 0
4)OK
Jan 20, 2009 | Canon Pixma MP450 All-In-One InkJet...
Waste ink absorber is almost full
Try this:
Resetting overflow error code for Printer Canon Pixma MP110
  1. Turn on the printer.
  2. Click Menu, and then Scan, Copy and Scan again. All - entered the service mode.
  3. Select Counter
  4. Click Copy - everything. Waste dropped to zero.
  5. Turn off the printer POWER button.
Good luck
Oct 14, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP170 All-In-One InkJet Printer Logo
287 people viewed this question
old marine
old marine
