Question about IBM Infoprint 1120 Laser Printer
IBM infoprinter operating manual
How do i find an infoprinter operating manual for the 1125?
  • 32 Answers
You should be able to find it in the support section of this page: http://www-07.ibm.com/printers/sg/products/workgrp_laser/info1125.html
Posted on Jul 24, 2009
Our infoprint 1125 is on a ibm mid range computer system & is accessible to 9 users. when we print an envelope, the printer asks for a manual load of the envelope, how do i change this to automatic...
It's been my experience with these machines that envelopes are always fed through the manual feed tray.
The Tray 2 cassette's pick up assembly is different than the manual feed,
it has 2 rollers that have a wide area they can pick up while the manual feed has just 1 single roller.
If you remove the tray cassette and look under the printer you can see the two rollers, these would probably have a hard time picking up a standard size envelope.
Also the tray would have to path the paper up and would have to bend it through the paper path which can cause problems with the flaps on the envelopes.
Best method is to use the manual feed tray and to also have the back cover open so that the envelopes path straight through the printer without being curled.
(I've seen these in a ton of places ranging from small business to banks and they always have the envelopes in the manual feed)
Jun 08, 2011 | IBM Infoprint 1125 Laser Printer
Pages are smudged and hard to read it looks like the cartridge is putting out too much toner
Smudging means that the "fuser" (which should be using heat to melt the toner into the paper) is not working, leaving the toner "loose" on the surface of the paper.
Take the printer to a qualified technician for repair.
Or, it might be cheaper to replace the printer!
Sep 27, 2010 | IBM Infoprint 1125 Laser Printer
Somebody has a Manual of IBM 1332 infoprint printer?
drivers and owners operating manual are almost always free for download from manufacturer's website. look for support or help sections.
Sep 07, 2010 | IBM Infoprint 1332 Laser Printer
80 maintenance infoprint 1125
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled
Maintenance” message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the Diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
Select Reset Maintenance Count. Pressing Select resets the
maintenance page counter to zero. Reset Maintenance Count
Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count
screen.
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
The tests display on the operator panel in the order shown:
• Print Registration
• Print Tests
• Hardware Tests
• Duplex Tests (If installed)
• Input Tray Tests
• Output Bin Tests
• Base Sensor Test
• Printer Setup
• Error Log
• EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Feb 24, 2010 | IBM Infoprint 1125 Laser Printer
We have IBM Infoprint 1125 printer. The problem is that when You send a document from PC for printing it starts with printing and after a few seconds and several printed pages it starts to print very very...
Check the cassette, on certain printers if the cassette is set for the wrong size paper it will cause the printer to run slow, this happens on HP so it might be worth a try.
Oct 31, 2017 | IBM Infoprint 1125 Laser Printer
I have infoprint 1125 that shows 202 paper jam, but no jam
Usually it is the white roller that is going bad in the tray. These are easy to replace - but fragile. They have a small clip that may break if you push it to hard. If you dont have a replacement - try cleaning them real well. If that doesnt work - you can take it off and remove the "tire" part and put it back on inside out. It fits funny but works if no parts are available.... All the rollers are the same for almost all printer like this.
Aug 05, 2009 | IBM Infoprint 1120 Laser Printer
IBM infoprint 932 service printhead error
go on line and type in
ibm infoprint 1352 laser printer error 932
enter
or
ibm 1352 infoprine error message 932
rod
Feb 06, 2009 | IBM Infoprint 1352 Laser Printer
Invalid Engine Code After Paper Jam
remove the driver of the printer and reinstall...
Apr 01, 2008 | IBM Infoprint 1125 Laser Printer
Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Dec 26, 2007 | Office Equipment & Supplies
IBM Infoprint 1120 Laser Printer Logo
313 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
