Question about NetGear ProSafe Wireless-N VPN Firewall SRXN3205 - wireless router
SRXN3205 cannot get decent latency on xbox live says moderate nat
mlake33
  • 427 Answers
SOURCE: nat type
Your router is perfectly fine. The NAT isnt a big concern at all, it wouldnt matter if you has strict, you would still play just fine. The router is a good one so keep it. Your NAT was only moderate because it was a momentary thing. Dont worry about it.
Posted on Apr 05, 2008
shaggyrat
  • 1224 Answers
SOURCE: my NAT type is on moderate so I cant play Xbox Live
your xbox should of had a disk with it to run your network settings and store them on a memmory card the properties as long as you have your network setup disk save the properties to memmory car of xbox and then you shouldnt have no more problems
but if you need to proceed further you need to set router settings manually
in internet explorer search bar type in this code here 192.168.0.1 this is your fixed router ip this will bring up the screen for router protocol
it will ask for name and password unless you changed the password and name it should still be normal
type=admin for name
type=password for password this will give info on your routers and specs
Posted on May 17, 2008
kakee
  • 1268 Answers
SOURCE: Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Posted on Feb 09, 2009
Hardtack
  • 46 Answers
SOURCE: How do i change my NAT connection from moderate to open
This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
Posted on Feb 10, 2009
  • 33 Answers
SOURCE: My NAT type for XBox Live is
Buy a cow... Literally. I did and it worked right when i bought it. My cow's name is Susie.
Posted on Jul 11, 2009
My xbox is telling me that my router's NAT setup is on moderate. what does that mean? and how can i fix it?
Here is Microsoft's definition of a moderate NAT and their suggested fixes.
http://support.xbox.com/en-US/xbox-live/connecting/nat-type-strict
Dec 24, 2011 | Microsoft Xbox 360 Console
Tip
Xbox live NAT
Simple Rules
-if your NAt is strict and cannot connect
try turning your hub off for 30 seconds then turning it back on
if that didnt work.
-try resetting your IP address.
if that didnt work
-take addaptor from xbox to pc out for 30 seconds, then put it back in
if that didnt work
- try opening thies ports
TCP 53
UDP 53
TCP 80
UDP 88
UDP 3074
TCP 3074
Helpfull Info
Sometimes depending on the router brand, it's not possible to open your NAT, this simpily becuase some are not specificly designed for Xbox Live purposes. A good example of this is Belkin routers. These brands are most commonly made for Buissness connection servers. If you are experiencing a STRICT/MODERATE Nat with a Belkin router, the chances are you are going to have to deal with it, but that is not 100% of the time. If you've have attempted several techniques to open your Nat and the changes arnt happening, i'd recommend a 'N' powerd Belkin router, the most majority of these routers work 100% perect for Xbox Live, I myself oned one but changed due to a broadband switch.
How do I change the NAT firewall protection? (Open/Moderate/Strict)
Find your IP address number then type it in on your web browser, this will bring up all your switchable options where several options can be changed to your approval. The NAT firewall is one of these options which can be changed. (like I mentioned before, if you own a Belkin router, the chances are even after changing the fireall level, it will turn back to moderate or strict)
on Feb 17, 2010 | Computers & Internet
I do not know how to change my NAT setting to open on Xbox Live
First of all I would just like to cover the basics of strict and moderate NAT settings. For those interested, NAT stands for Network Address Translation and is used to prevent problems with information being sent over a shared network.
With the XBOX 360, Microsoft have defined three categories of NAT. These are:
1. Strict
2. Moderate
3. Open
You can see the NAT level for your XBOX Live connection by going into your
1. System blade
2. Network Settings
3. Test Xbox Live Connection
For you question on how to open your NAT setting follow the steps below:
1. Type the IP address of your router in a web browser.
2. It will prompt you for a user name and password once connected
3. After logging in you will have a control panel of setting up different settings in your router.
4. The IP address, and default user name/password are different on every route
Note: 192.168.1.1 is a pretty common address for most routers.
5. Check the manual that came with your router for that info.
I also provided a few links below of password lists of different routers.
Click Here
Click Here
I hope this information will be helpful. Thank you for using FixYa!
Your feedback is greatly appreciated.
Feb 24, 2011 | NetGear WNR2000 Wireless Router
NAT on xbox live is moderate! i need it to be open, for best results. What do i need to do?
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Jan 28, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How can i make my NAT open from moderate??? (xbox live)
TO opennthe NAT in your router. you willl need to make some changes on your router.
You will need to reduce the MTU on the router to 1365.
you will need to disable the firewalls on the router.
There are some port numbers that you will also need to open on the router.
For this you will need to open the set up page of the router.
Click Here for more info
Oct 17, 2009 | Zyxel P660HW-D1 Router
Nat Is Moderate Xbox Live
So let me get this straight; you have your XBox plugged in, via ethernet, to the modem, and are testing the connection?
Jun 15, 2009 | Microsoft Xbox 360 Console
Need to know how to open my NAT for Xbox live with a sb5101 cable modem
192.168.1.0 or sometimes 192.168.1.1
in ur search bar
and then go to advanced setup
and it will say nat settings
then you just click on that and open ur nat
May 31, 2009 | Arris SURFboard® SB5101 Cable Modem
Halo 3
make sure the security settings on router is WEP-Personal. I don't know what you have for internet but Dial-up, DSL, and satellite internet will not get NAT 1.
Mar 14, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Switching from moderate NAT connection to an open NAT connection
yo tengo problema co el asistente de conexion del linksys
Feb 10, 2009 | Linksys WRT160N Wireless Router
NetGear ProSafe Wireless-N VPN Firewall SRXN3205 - wireless router Logo
64 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
