Question about Electrolux E23CS75DSS Stainless Steel
The temperature in fridge is 53 and the temp in freezer is 52 tried setting fridge at 37 and freezer at 0, but they keep going back to 53 and 52 degrees. keep turning off the alarm tried unplugging unit , followed directions in use and care guide book many times.
    Genius:
  • 1,622 Answers
Hi,The thermostat - that part of your fridge that controls the temperature - may be one of the smallest parts, but of course it is also one of the most important. The thermostat can not easily be repaired - generally speaking, if you have a faulty thermostat you will almost certainly need to have it replaced.
There are several warning signs that the temperature inside the fridge is not what it should be. An obvious sign that the temperature is too cold inside the fridge is when liquids - milk, soda or orange juice, for example - are partly frozen. Similarly, if your freezer or ice compartment is kept too cold, ice will form on the outside of packets of food that are stored in there. The bottom part of your fridge is the coldest part - you can always try putting produce and other sensitive food items on a higher shelf. Ice or frost forming on the inside walls of the fridge also indicates a problem. Food that spoils before it should is also a sign that your fridge may be too warm.
Before you spend the time and money replacing the thermostat, here are some tests you can perform to see if it is the thermostat that is faulty, or some other problem. If you feel the temperature in your fridge is not what it should be, firstly try the obvious: make sure the temperature control is set correctly. The ideal temperature for the fridge should be between 38 and 40 degrees Fahrenheit, and for the freezer temperature between 0 and 8 degrees Fahrenheit. The temperature setting may have arbitrary numbers on it, (for example 1 through 9, warmest to coldest) and simply moving this control to the next setting up or down may solve the problem. Depending on the age and make of your fridge, there may be separate temperature controls for both the fridge and freezer. Check the manufacturer's manual that comes with your fridge to find the suggested setting for the temperature control - or call the manufacturer if you don't have the manual. Most companies have a toll free help or troubleshooting number to call.
If you are technically minded, it is possible to easily unscrew the temperature dial, and then remove the actual temperature control box, taking care not to pull any wires away. You can then test the temperature control using a hand held device called a continuity tester probe. Set the control dial to its coldest setting, and then attach the probe. If it lights up, then this indicates a closed circuit with no obvious problem in the electrical system. Make sure your fridge is unplugged while you do this.
If your fridge temperature is too low and you cannot make it warmer by adjusting the thermostat, it may be one of several other parts that are causing the problem - there may be a leak in the refrigerant system, a defective air damper, or a situation known as cold air migration, which occurs in " side by side' fridge/freezer models. Poor cooling can also be caused by frost building up on the evaporator coils - a vital part of the fridge that you cannot easily see without removing a panel on the inside of the freezer. A sure sign of this is if you see slight icing or frost build up on the inside walls, or floor of the fridge. If your fridge is self-defrosting, it may be a faulty defrosting mechanism that is causing the ice or frost build-up. One way to test this, although it is not particularly convenient, is to take everything out of the fridge, leave the door open and turn the thermostat off for at least 24 hours. Once the ice build up has disappeared, put the thermostat back on its normal setting - if the fridge then cools properly, there is probably a problem with some part of the defrosting system.
There are other ways to test that the thermostat is keeping your fridge as cool as it should. A good method of accurately checking the temp over a period of time is to leave a glass of water in the fridge for 24 hours; or a glass of cooking oil in the freezer. You can also use a thermometer - a meat thermometer is good for this. Also check the door seal and the door catch on your fridge - something as simple as the door not closing fully can cause a slight temperature increase inside the fridge. And leaving the refrigerator door open for long periods of time can also cause the inside temperature to warm up.
If you are lucky though, you may never need to repair your fridge - the average lifespan of a refrigerator is about 15 years, making them one of the most reliable and longest lasting of household appliances.
Posted on Mar 30, 2011
Wat temp is for fridge and freezer to be on plz
What are your recommended temperatures for the fridge-freezers? The default and recommended temperatures for our fridge-freezers are as follows:-
4?c for the fridge compartment, 5?c specifically for the fruit and veg compartment, and -20?c for the freezer.
The ideal temperature setting for a refrigerator is 3?C and for a freezer it's -18?C. The only exceptions are fridge-freezers in the RB*** range, for which we recommend -19°C (as -18?C isn't an available option for these models).
Keep your fridge at the perfect temp with these handy tips
Dec 04, 2016 | Refrigerators
Hiw di I set the temp to the correct temp
turn freezer to mid point and try fridge on 3.5 as a starting point.
Keep the refrigerator temperature at or below 40° F (4° C). Thefreezer temperature should be 0° F (-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these temperatures and are generally inexpensive.
press the helpful button and check link below
Fridge temperature guide Kitchen
Jan 29, 2016 | Refrigerators
Whst temperature do I set LG LFX 31945ST
Hey Rosalie,
The lower the temperature the better but do not operate to the extreme.
  • I would set the freezer between 0 and 7 degree F
  • The fridge between 34 & 37 degree F
  • Adjust Temp if necessary.
Here is a link to the fridge manual.
Good Luck!
JP
LG LFX31945ST Owner Manual
Jul 19, 2015 | LG Refrigerators
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Why does the temperature on my ge fridge keep changing to warmer temp?
Make sure the condenser is clean and clear, and all fans are working as they should. Also check the freezer section for signs of ice build up. A good defrost and a cleanup usually does the trick!
If it's in direct sunlight, try to limit the heat with a blind.
Jun 14, 2014 | Maytag MZD2766GES Side by Side...
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
The freezer is fine, but the refrigerator is too warm (set at 37...now at 52). The temperature control has power (it lights up)
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I can set the temperature at the console in the fridge and it wont set? i can put it on 37 and it will get as cold as 28. I have to bump the freezer up to around 4 or 5 to somewhat maintain a temp of 36 in...
Your ice box uses thermistors to judge temp. The control board measures the resistances changes in these thermistors and acts accordingly. This video shows how to check:
Mar 31, 2011 | GE Refrigerators
GE side x side refridgerator temperature is
unlikely both temp.sensors will be faulty at the same time. Notice how different the internal temps.are compared to the acurate one you are measuring it against. Almost certain board is defective because incorrect info in the processor will tell the compressor/s to switch off before time.(hence not correct temp. all the time.) Suggest replacement.I normally replace probes as well to eliminate problems later..
Sep 17, 2009 | Refrigerators
Refrigerator and freezer temperature control
hi. thanks for te question. since you asked the question. has your fridge settled down and cooling sometimes the fridge will set itself
Sep 24, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Electrolux E23CS75DSS Stainless Steel Logo
134 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
