Question about Samsung Televison & Video
Samsung tv negative image - Samsung Televison & Video
  • marionbagget Mar 30, 2011
    What is the model of the tv ? Which country is it located in ?
  • curtis carter Mar 30, 2011
    LN32A450C1D. USA
  • 718 Answers
LVDS cable from the T-CON
This seems like a problem with the T-CON board or it's connections. This is the low cost method to try.
If this set is under warranty you should return it to get it repaired/replaced by the seller. If not then;
This sounds like the T-CON board or the LVDS cable connection is bad. Turning on and off the set will cause the connection to heat and cool and not make good contact.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(board replacing ) or have a friend with knowledge/skill you can fix it.
>Unplug the set and disconnect any cables.
>Lay on a flat surface covered with a cloth.
>Remove the back cover.
>The board is located near the middle of the set underneath metal shielding.
> Re-seat the cable by disconnecting and re-connecting the flat cable(s) connected to this board. See if the picture corrects.
You can try this several times.
If this does not correct the problem you may have to replace the T-CON board.
>Replace the shield and back cover.
You can search for replacement boards from places like shopjimmy.com, ebay and other sites.
The board will look something like this;
Posted on Mar 31, 2011
NEGATIVE COLOUR DISPLAYED
Sounds like T'Con fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 20, 2014 | Samsung LA40A450 40 in. LCD TV
Picture Clarity- Seeing like a negative image
Negative image denotes a fault to its T'Con board. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 17, 2013 | Samsung LA40A550 40 in. HD-Ready LCD TV
I have a samsung lcd tv mod LN46A550P3F that the pix is so bright ,you can see the image but it is like negative , some help is welcome . thanks.
Initially try to enter a factory settings if not helped try to play a dvd movies etc on your TV,,if the problem is still there you have bad T-con board..Just replace it to fix the problem,,
Aug 28, 2012 | Acer Televison & Video
I have a Samsung LN37550A LCD TV (full HD 1080) that is 2 years old. 2 days back the images got washed out. All I see is mostly very bright images and negative images. I am told that the TCON card needs to...
U can't buy the T-CON board in any stores in anywhere in the world because this T-CON board it is not buy able it new u only can buy it as a salvage tv PCB board only.This T-CON board u can buy it as refurbish board only.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Sep 22, 2011 | Samsung LN37A550P LCD TV
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
I took some photos that appeared in negative. please show me how i can repair those photos. thanks
Many image viewing/editing programs will let you change between negative and positive images, but the simplest thing in Microsoft windows is to just use the built in Paint program. Open the image and select "Invert Colors" from the "Image" menu. You may want to save it out with a different name so you don't erase the original.
Feb 27, 2011 | Samsung S760 Digital Camera
5-year old 32 in. Samsung which only displays a fuzzy gray image
It sounds like the T-CON board problem, you can try reseating the connector first, the board is mounted under the metal shield which sometime can be difficult to get to.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 07, 2010 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Snowy with blue and black squares
your va and vs need to be adjusted and if that doesnt fix it then you have a board going bad but still requiers repair or service tech to find out
Jan 14, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Negative image and then black and won't turn off!
The negative image on the screen is the DMD board (Digital Mirror Board). The cycle sound is the color wheel trying to spin but if the DMD board is going bad, it will effect the color wheel and not spin. There for your image will freeze.
Mar 26, 2008 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
1,030 people viewed this question
Jerry Greenberg
Jerry Greenberg
