Question about Fargo HDP5000 Thermal Printer
RIBBON MISCUE - Fargo HDP5000 Thermal Printer
Calibrate Ribbon Now
Posted on Jun 06, 2011
What/where is the ribbon gear drive, My BrotherSX4000 ribbon will not advance, I can do it manually
Ribbon does not advance
    1. Lift the ribbon cartridge out of the typewriter.
    2. Inspect the ribbon for damage.
    3. If the ribbon is silver, it is at the end of the spool and must be replaced.
    4. Turn the colored knob on the left side of the ribbon cartridge counter-clockwise to advance the ribbon a small amount. Replace the ribbon if it will not advance or the knob will not turn.
    5. Reinstall the ribbon.
    6. Try typing a few characters. If the ribbon still does not advance, the machine will need service.
Jun 01, 2018 | The Office Equipment & Supplies
Printer given barcode missing install new ribbon
There are two styles of P7000 a spool ribbon style and a cartridge ribbon style. You are getting a barcode error then your printer is looking for a ribbon spool not a ribbon cartridge.
Cartridge Ribbon:
PRINTRONIX 255048 402 P7000 EXT LIFE CARTRIDGE RIBBON New
Spool Ribbon:
PRINTRONIX 179499 001 ULTRA CAPACITY RIBBON 6 PACK New
Jan 03, 2016 | Printronix Office Equipment & Supplies
Ribbon miscue on cyan fargo hdp5000
There are a few things which could lead to a ribbon miscue. The most obvious would be your firmware. Go to Fargo's site and download the latest firmware patch. Your printer may driver be corrupted, so uninstall and then re-install it. One other possibility is that your printer has a faulty ribbon sensor which would need replacing. I hope this helps
Aug 11, 2012 | Fargo "HDP5000 Single Sided Card Printer,...
In billiards, what is a miscue?
A miscue happens when you strike the cue ball and the tip slips by during time of impact causing the side of the stick to swipe the ball. Essentially the ball goes nowhere.
Jul 25, 2012 | Sport & Outdoor - Others
Fargo DTC300, prints yellow and magenta, stops at cayn
is a printer thermal head dirty on same position. clean with a clean dry cloth, and special cleaner (see on manual)
Jul 15, 2010 | Fargo DTC-300 Thermal Card Printer
Panel Searching
Common problem with the DTC300, C30, DTC400. Upgrade the firmware and printer driver from Fargosupport.com. Then calibrate the ribbon sensor through the printer driver calibrate tab.
OnlineIdTech
Feb 06, 2010 | Fargo DTC-300 Thermal Card Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Need a manual for a Bosch CC220 Trumagraph CNC Control
Hi There,
Our company specialises in these machines, and we have a big library of manuals and lots of experience with this control.
Contact us via our website at http://www.lasercare.net or on (+1) 803 831 1516.
Regards!
Mar 26, 2009 | Computers & Internet
GX-6750
The ribbon doesn't advance at all? Try turning the ribbon by hand. If it is really hard to turn, or doesn't advance when you turn the knob (make sure you turn it in the direction of the arrow), then the ribbon is defective and you just need to get a good one.
If the ribbon turns easily, the leave the ribbon off, type and watch to see if the black knob on the left of the ribbon plate (the place where you put the ribbon), that turns the ribbon, is moving.
Also I have found that some brands of ribbons simply do not work on this machine. If the ribbon and the ribbon drive is working, try a different brand of ribbon.
Oct 22, 2008 | Brother GX-6750 Typewriter
Error code 754
It's very possible you are not installing the ribbon properly.
When loading a new ribbon on a Monarch printer, you must save the plastic ribbon core (it's butter yellow in color) from the previous roll of ribbon. The core is what the ribbon is wound up on.
Do not throw away this plastic core - you need it for the next roll of ribbon you load!
You have to move this now empty core from the back ribbon spindle and slide it on the front ribbon spindle. You then load the new ribbon on the back spindle and attach the ribbon end to the empty plastic ribbon core on the front spindle.
You CAN NOT just tape the ribbon to the front spindle. You must have an empty ribbon core to attach the new ribbon to. The printer will give a 754 error unless you have two plastic cores on the two spindles. It can also give a 754 error if the ribbon is not loaded properly, and also if you have a bad motherboard. There are no ribbon sensors, so that's never going to be a problem...
Jul 28, 2008 | Paxar Monarch 9850 Thermal Printer
Fargo HDP5000 Thermal Printer Logo
244 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
