Question about HP Scanjet 5470c Flatbed Scanner
Is there a cable available to connect my HP 5470c scanner to my Toshiba laptop. What and where can it be purchased? My computer will take USB cables but the cable with the scanner is obviously not the one. Thanks for your help.
  • HP Master
  • 32,281 Answers
This model HP5470C was supplied with a parallel and USB cables to connect to computers.
For PCs the manual recommends using the parallel cable and for Apple computers to use the USB cable.
If the Toshiba does not have a parallel printer port then try using the USB cable.
For a manual for your scanner go to this WEB site.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=15179&prodSeriesId=28456
Posted on Mar 31, 2011
What leads to connect scanjet 5470c scanner
First, a power adapter is required to connect your scanner. the power adapter must be supplied with the scanner. If your scanjet 5470c scanner is having USB interface or connectivity, then you need USB cable and if it is SCSI interface, then you need SCSi cable to connect to your PC. The cables are usually be supplied with the scanner. If lost, you may have purchase teh same. For further assistance, please visit the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=15179&prodSeriesId=28456&taskId=115
Hope the above information is helpful.
Thanks,
ScanCare
Jun 25, 2012 | HP Office Equipment & Supplies
Trying to connect HP Laserjet 2100 (works fine with XP) to Pavilion dv7 with Win7 64 bit Professional. I downloaded the PCL5 driver from HP but it will not print. I am using a Manhattan parallel to USB...
Did you download the Win 7 64 bit drivers for this printer. If not i suggest try downloading the drivers from the following link
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=14914&pr...
Check the USB connection
The icon on the USB cable (c01424575.gif ) faces up when the cable connects to the product correctly. Check the back of your product and the back of your computer to make sure the USB cable connects correctly and securely.
After you make sure the USB cable connects correctly and securely, review the following guidelines to check other potential USB-related problems:
  • USB ports on the keyboard. USB ports on the keyboard and in the front of some computers might not be powerful enough to support the product. If the USB cable connects to the USB port on the keyboard, try connecting it to another available USB port on the computer.
  • USB cable length. HP supports USB cables less than 5 m (16 feet, 5 inches) long. However, a USB cable that is 5 m (16 feet 5 inches) long must be of high quality. Otherwise, HP recommends using a USB cable that is less than 2 m (3 feet, 3 inches). Do not use patch cables to increase the length of an existing cable. Use a powered USB hub if you need more length.
  • Alternate USB ports. Connect the USB cable to another port on the computer to make sure that the USB port on the computer is not the cause of the problem.
  • Defective USB cable. Replace the USB cable to make sure that the existing cable is not defective.
  • Conflicting USB ports. Disconnect any other USB printers, USB scanners, USB cameras, and any other USB connected peripherals. Start reconnecting these devices one at a time to determine if one of the devices is using too much power. Consider purchasing and installing a powered USB hub if necessary. NOTE: A USB-powered hub is a device that increases the number of available USB ports on a computer and facilitates communication between the USB devices and the computer. A powered USB hub can resolve communication failures between some, but not all, USB chipsets and HP products.
Jun 23, 2011 | HP LaserJet 2100 Printer
Driver for 5470c scanner will not work with windows 7
Hi ,
Scanjet 5470c does'nt work under W 7 . No drivers available .
Here are a few hints :
1° hint :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
In any case , no slides or negatives scans possible but the rest works .
2° hint :
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Regards .
Jan 06, 2011 | HP Scanjet 5470c Flatbed Scanner
I can't find a driver to get my HP scanjet 5470c to work with windows 7
Hi ,
1° hint :
Reboot .
2° hint :
Sep 10, 2010 | HP Scanjet 5470c Flatbed Scanner
I purchased my Microtek ScanMaker 3800 many years ago. I still have the installation CD. Recently I purchased an HP laptop running Vista. My question: is it all right to plug in the scanner directly...
First connect your scanner to computer with usb cable.
Then insert disk in rom then install driver and software from disk.
It is not matter that first you connect scanner or install driver but if you connect scanner first your computer recognized it then you can install driver from disk.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 13, 2010 | Microtek Computers & Internet
My hp scanjet 5470c has worked fine in the past, now after wanting to use it again, it won't power up at all. I know my connections from the wall to my scanner are good?????
Dec 30, 2009 | HP Scanjet 5470c Flatbed Scanner
64 bit driver for HP 5470c scanner
Dear go to www.hp.com click on support and drivers then enter your product model now you choose your operating system and download driver free.
First install its software or driver only then you should attach your scanner (when your computer demand or required for its attachment).
Good Luck
Aug 13, 2009 | HP Scanjet 5470c Flatbed Scanner
Original hp scanjet 5470c software disc won't work; need new
have u contact hp in u'r region? maybe they have the cd..
Mar 30, 2009 | HP Scanjet 5470c Flatbed Scanner
HOW TO CONNECT SCANJET 5470c to computer
Hope you have a hp 5400 software CD which will install the programme of the scanner to your PC. Once this is done then you will be able to connect and operate your scanner with PC.Your PC should have a USB port to connect the scanner with it.
Ajit bhutani
May 20, 2008 | HP Scanjet 5470c Flatbed Scanner
HP Scanjet 5470c Flatbed Scanner Logo
191 people viewed this question
Seeker5211
Seeker5211
