Question about Makita DPC7311 73cc 14Inch Gas Powered Power Cutter
Can I check my makita dpc 7311 coil with a meter
  • 396 Answers
You can check the coil to see if it is open with a multi meter set for Ohms. However, If the insulation of the coil is breaking down your meter may not be sensitive enough to detect this failure. You would need a Z meter to Identify problems and the value of the coil. I believe it would be in you better interest to go to an auto parts store and buy a test plug which is no more than a spark plug with a ground clip on it. You can remove the plug wire on your saw and connect it to the test plug. When you try to start the saw you should visually see a spark from the test plug. If you do then your plug should ignite the fuel. If you do not then you will need to check the plug wire and the input to the coil.
Posted on Mar 30, 2011
MaKita DPC 7311 Saw, how do I get a piston in cylinder when replacing with a new one & ring ?
Provided the cylinder is sized for the piston and you have the correct rings, you need a ring compressor. If the cylinder slides over the piston/rings be sure to get a ring compressor that allows you to get the compressor off when the rings go into the cylinder. You can't use too much force to get the rings into the cylinder or you'll break the rings and have to start over. An auto parts or small engine shop will be able to get you the tool.
Dec 27, 2017 | Makita Garden
I have a Makita DPC 7311 saw with 80 lb compression and good spark, but it won't fire - not even a pop. What's my problem?
Give a squirt of starter fluid into the carb after you've taken off the air filter. If it runs for even a second or two, it's carb/fuel related.
Dec 21, 2017 | Makita Garden
My makita dpc7311 has no spark, replaced plug, coil, flywheel, what else can it be
Check the ground wire from the coil all the way to and including the contact point at the choke switch. I've encountered a couple where insulation was worn off or the wire was pinched and making contact with the head, carb or other metal part and grounding out the coil.
Sep 02, 2013 | Makita Dpc 7311 Concrete Saws
Spark plug gap for makita dpc 7311
take the cover of a pack of cigarette paper then its most of the times right.
Feb 24, 2012 | Makita Saws
Ive got a Makita concrete saw DPC 7311,it says a mix of 100:1 but thats alot ?
The manual says to mix it 100:1 if using Makita high performance oil or 50:1 using regular Makita 2 stroke oil. I'd go 50:1 with non Makita oil too.
Here is a site to download a pdf manual if you need it.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Feb 18, 2011 | Makita DPC7311 73cc 14Inch Gas Powered...
Whats the mix for a two cycle dpc 7311
50:1 synthetic... one 2.8fl oz bottle per gallon of regular gas
Nov 27, 2010 | Makita DPC7311 73cc 14Inch Gas Powered...
No operators manual for makita dpc 6410 petrol disc cutter
Come on, it tooks me 20 seconds to find it...Web search is all about keywords. makita dpc 6410 manual leads to the answer. Adding pdf would have been even better...
Aug 01, 2009 | Makita DPC6410 64cc 12" Power Cutter
Makita DPC7311 73cc 14Inch Gas Powered Power Cutter Logo
722 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
