No power. Will not turn on - Computers & Internet
  • 124 Answers
Not intended to offend;
1. If using A/C (house electrical power), please check if electrical wall outlet is active. Attempt to plug-in another electrical device such as a lamp, clock, radio, etc.. If the electrical wall outlet has top and bottom plugs, try the top and then the bottom plug to see which one works. Sometimes, the top outlet will not work, yet the bottom outlet does work. The wall outlet should be replaced by qualified technician.
2. If both outlets do NOT work, and the outlet is GFCI breaker protected, maybe pressing the RESET switch on the outlet will power-up the outlet.
3. If the outlet is NOT GFCI breaker protected, check your electrical fuse box for a tripped fuse. Sometimes, a tripped fuse is NOT visible. May have to trip the specific fuse or all fuses to off, then back on. Recheck the wall outlet.
4. Once your know the outlet is live, check the power cord (a/c adapter for laptops) to make sure they are securely plugged-in to both the wall outlet AND the PC or Laptop.
Will need more information once the above steps are taken:
Is it a Desktop or Laptop?
Make and Model (if known)?
Any lights (glowing) on the desktop or laptop?
Any lights on the A/C adapter if its a laptop?
Posted on Mar 30, 2011
  • stoetzel Apr 09, 2011
    generally if "the top outlet will not work, yet the bottom outlet does work", the wall outlet does not need to be changed by a qualified electrician, it's usually a switched receptacle, which means that mysterious switch in your house that you always thought did nothing at all, actually turns the top outlet on and off. it's for plugging in a lamp.
How do I disable power save mode
Press the Power key > Activate power saving. To deactivate power saving mode, press the Power key > Deactivate power saving.
When activated, the power saving mode turns off some functions automatically. Radio configuration in power saving mode include the cellular radio (it is set to 2G/GSM only mode), the Bluetooth radio (it is turned off) and the Wi-Fi/WLAN radio (scanning for new networks in turned off but existing networks keep functioning). The power saving mode also reduces display power consumption by minimizingscreen brightness and by turning off touch screen feedback and theme effects. In addition the vibra alerts are turned off in a power saving mode. Hope that helps Anomy.
Mar 16, 2015 | Nokia N8
Tip
HP Office Jet All in One : Resetting Steps
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards,
Rizwan
on Jan 19, 2010 | Office Equipment & Supplies
Can't turn on power to desktop
Simple power hack, to do this, kind of like hot wiring your computer.
Turn the power on at the wall, Flick the switch on the back of the computer (if there is one on the back) to the on position, make sure the cable is plugged in, and turn the power off at the wall, hold the power switch on the front and turn the power on at the wall.
This will cause the power to jump across the switch, causing the computer so sound a bit like a motorbike being started.
The power will come on it will turn over click and go off. After this turn the switch of at the back of the computer, and turn it back on, and the computer will boot up.
The first bit of this is just charging the capacitors in the power supply, the second bit is turning your computer on.
Oct 15, 2012 | Dell Computers & Internet
How can i reboot my PC without keyboard?
Here are some of the steps to you can reboot your pc without using a keyboard:
1) Long press the power button
- Press the power button for about 3-5 seconds. If the power LED or power supply fan shuts off, that means you have successfully turn off your pc. Press it again to turn on.
2) Unplug the power cord from the power supply
- Force your pc to shutdown by unplugging the power cord from the power supply of your pc. Put it back again and press power button to turn on.
Note: Please make sure you have saved important activities before doing this as this will immediately turn off your pc.
Hope it helps.
Thanks!
Feb 22, 2011 | Computers & Internet
Photosmart c6180 repeatedly turns off about every 10 seconds
Solution one: Press and quickly release the Power button Follow these steps to turn on the product correctly.
  1. Remove any memory cards or USB drives from the HP product.
  2. Press, and then quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button . Figure 1: Press and quickly release the Power button c01941590.gif Illustration of pressing and releasing the power button
c01733891.gif If you press and hold the Power button too long, the product might turn on and then turn off without restarting. The product might also appear to be turned off in Powersave mode. In either case, press, and then quickly release the Power button (c01602202.gif ) to turn on the product. Solution two: Check the electrical connections and outlet Follow these steps to make sure that all the power systems work correctly.
  1. Unplug the power cord from the electrical outlet, or the power strip or surge suppressor. Power module Power cord c00745315.gif Illustration: Power module c00057913.jpg Illustration: Power cord
    NOTE: The power cord detaches from the power module. The term power supply refers to both the power module and the power cord.
  2. Carefully inspect the power supply for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  3. Disconnect the power supply from the back of the product.
  4. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  5. Reconnect the power supply to the product.
  6. Press and quickly release the Power button (c01602202.gif ) to turn on the product.
  7. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on , the electrical outlet in the original room caused the issue.
    • If the product still does not turn on , continue with the next solution.
Solution three: Make sure that other devices are not causing the issue Follow these steps to make sure that devices plugged into the HP product are not causing the problem
  1. If the parallel and universal serial bus (USB) ports of the HP product have other devices plugged into them, unplug those devices.
  2. Press the Power button (c00636182.gif ) to turn on the HP product.
  3. Monitor the HP product to see if it turns off again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | HP Photosmart C6180 All-In-One InkJet...
When I turn my hp g85 on,I get the following message:initializing,then a sound then press enter to allign cartridges then the printer flashes off &on and turned off by its self.
Please try below resets
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
  • Press and hold "Enter" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
Oct 30, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
Officejet 5610 All-In-One InkJet Printer: error 0xd0620130 reset power...
Please try the below resetting steps
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Rizwan
May 07, 2010 | HP Officejet 5610 All-In-One InkJet...
Epson r290 no power after i turn off because 2 red light appears
while printing the two red lights turn on and stop printing,i press the power to off.. i turn it on so many times but still no power.. in the morning, i press the power to on and the 2 red lights appears again, then i turn it off, ..i try to turn it on many times but still no power. help me pls...
Aug 07, 2009 | Epson Stylus R290 InkJet Printer
HP Media Center Power Up Problem
replace the power supply-from a computer store, should be no more than 30 dollars
Nov 02, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
Computers & Internet Logo
187 people viewed this question
David Payne
David Payne
