Question about Northern Tool Air Tools & Compressors
I am looking for a 2mm nozzle for a central pneumatic hvlp spray gun. I order to spray flakes.
4 Suggested Answers
  • 35 Answers
SOURCE: Spray painting operation advice for Binks mach 1 hvlp spray gun
Hey paul its paul. I posted on here so hopefully you will give me some feedback. That is a very nice gun. One of my favorite. I'm guessing you know how to use a HVLP gun but if not here are a few tips. Make sure it is clean. Very clean. Your gun probably came with a manual, you should read it. It will help you greatly. First off, you want to have a regulator, about 40 psi is what i start with. You need a space you can practice some painting before laying down a new coat on the corvette. Haha. So next you will have a pressure adjustment knob, you want to start with this all the way closed and with the trigger pulled, just half way so just air is coming out adjust the air until it sounds even. Next you can try to spray. If it seems like the Fan, like the width is not enough you can adjust the fan, another knob, closer to the back of the gun, you ussually want about 5-6 inches of fan, if you are spraying at the normal 6-8 inches back from the piece. Last adjustment is the fluid adjustment, you want to put on a decent amount of paint, clear or primer, and not cause runs. This is going to take some practice because everyone moves at a different speed.
So you are going to have to play with your gun and figure out which knob does what. After that these instructions should get you a bit further, with some practice you will be laying down a nice paint job in no time.
Paul.
Posted on Feb 26, 2009
SOURCE: operating instructions for central pneumatic
My #91011 One Quart is not a gravity feed, it is air compressor fee fed. My problem is the nozzle will not fan out . It only blows a round spray mist. ?
Posted on Aug 02, 2010
  • 15188 Answers
SOURCE: My Central Pneumatic HVLP spray gun did not come with a wrench to take the front of the gun apart. Any suggestions?
go to a store and buy one
Posted on Oct 11, 2016
Can not adjust fan on sata jet 3000 hvlp
mine did the same thing,there was a plastic part in the body that was broken,my paint store said they had never taken that part out,i sent mine to sata they fixed it for free.
Oct 30, 2013 | Sata 133223 SATAjet 3000 HVLP Digital...
We are having trouble getting the spray gun to pull the paint through. It will spray air but does not spray paint.
when you pull the trigger can u see the needle moving backward? if so, then it's either the paint is too thick compare to the nozzle size or the passage for paint is blocked. try to take the nozzle, needle and the cup off and give it a good clean!
Sep 05, 2011 | Campbell Hausfeld Husky Gravity Feed HVLP...
Air bubbling up in cup when air trigger is pulled this is a gravity fed hvlp spray gun
it means the air holes in the nozzle are blocked the air couldn't get out in the front so instead it went back to the cup makes it bubble
Aug 20, 2011 | Campbell Hausfeld Husky Gravity Feed HVLP...
How to adjust the controles on my hvlp spray gun
your top adjuster is for the air (or to adjust the fan of the gun) turn it to make the fan wide or small.
the next one right below the top is for the material (paint, stain, etc) turn it in for less material or out for more. if you unscrew this one all the way you will be able to access the needle.
these is the two mane adjusters on a hvlp gun. you may have another adjuster on the bottom of the handle. this is your air presser regulator and will control the amount air going through the gun but i always use my own.
hope this helps
Dec 07, 2009 | HVLP 2.5mm Hvlp Spray Gun-auto Paint...
Operating instructions for central pneumatic industrial paint spray gun md 91011
Oct 26, 2009 | RTO Central Pneumatic Gravity Feed Spray...
I tried to adjust the regulator and the back just screwed off of the body - any ideas on how to prevent that?
Possibly you were trying to adjust the regulator without having air flowing through it. You must squeeze the trigger on the gun and have air constantly flowing through it otherwise the regulator knob is very hard to turn against the pressure inside it. To set an accurate pressure, squeeze gun trigger (while connected to air hose) to get air flowing... then twist regulator knob out (or in the "-" direction) until air flow reads 0 on the regulator gauge. Then start twisting regulator knob the other way until you reach the desired pressure on the regulator gauge. Also make sure the regulator is attached with air flowing the correct way through it. There should be an arrow somewhere on the regulator body which should be pointing toward your spray gun.
Oct 05, 2009 | HVLP 2.5mm Hvlp Spray Gun-auto Paint...
What are the controls of a gravity fee spray gun
most spray guns are basically the same gravity feed is no different, air pressure into gun and out nozzle,spray pattern fan to spot and last the amount of fluid comin out of cup to the nozzle.
Aug 28, 2009 | Ingersoll Rand 1.4MM HVLP GRAV FEED SPRAY...
Air Tools & Compressors Logo
332 people viewed this question
Top Northern Tool Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Northern Tool Air Tool and Compressor Expert? Answer questions, earn points and help others
