Question about Dryers
It will not spin. It heats up and runs but does not spin
    President:
  • 3,074 Answers
Http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Posted on Mar 30, 2011
Lgdle2516w spins but no heat
That's an electric. Sounds like one of the two circuit breakers has popped. They should be tied together. Check breaker box.
I think the unit is too new to need a new heating element. Could be wiring to the element. There normally around 5600 w. and run on 220 v.
Apr 13, 2014 | Dryers
Fan on outside heat pump wouldn't spin put in new cap and started working when got off work it wasn't spinning again
I have a ruud gas pack, the blower fan wont come on. If we go out there we can spin it and she will run, but when the time shut off, so does the fan.. and it wont restart
Jan 28, 2010 | Ruud UBHC Air Conditioner
My roper dryer is spinning my electric meter like a top I replaced the heating unit but problem is still there on fluff dry no heat the meter crawls but low or high heat and the meter spins like atop
I am assuming that your talking about how much energy your using. When the unit runs on full heat, your electric meter will spin as you say like a top, this is quite normal. Electric dryers use tremendous amount of energy. Going on fluff your using just the normal 120v and not pulling many amps to run the dryer. However with the unit on high your pulling more amps and are now drawing 240v to operate your unit.
If your clothes are drying than it is not the heating unit.
If your concern is the amount of energy expended, there is always the old clothes line, which is energy efficient and if you live in a part of the world where the air is clean your clothes will smell fresher than if it came from a dryer.
Oct 11, 2009 | Roper REX4634KQ Electric Dryer
My dryer will spin but will not heat up.
You have a bad element. This is the only thing that is in the heating system that when it goes out, the dryer will continue to run.
Please rate solution
Sep 05, 2009 | Roper REX4634KQ Electric Dryer
Should the radiator fan on 95 JGC run at ALL times that the engine is running?
What happens is the fan run constantly and the temerature of the engine is what determines how fast or slow it goes.
When the engine heats up, so does the thermostatic fan clutch. When the fan clutch heats up it expands, making it tighter to move and when your vehicle cools down. so does the clutch, making it looser. Test it out. Before you turn on your vehicle, move the fan. You'll notice that you can spin it without much effort. Then turn on the vehicle and let it heat up. Once you turn it off, attempt to spin it. You'll see that it's much harder and if the clutch is good, it won't spin at all. Rather, it will just move a bit.
When you vehicle (and the clutch) heats up, it blows "gusts" of cool air at the engine but when it is cool, it blows more of a breeze. Hope all this helped.
Aug 11, 2009 | 1995 Jeep Grand Cherokee
Whirlpool Dryer, Heats up, but will not spin.
Thermal fuse , is the small white plastic piece on the blower box . That , keeps the dryer from running . Thermal cut-off , is the small thermostat on the burner (element) box , which would keep the dryer from heating .
Jul 31, 2009 | Whirlpool LER5636P Electric Dryer
Tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 07, 2009 | GE DVL223GB Gas Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryer heats but quit spinning
Your belt has come off or has broken. Do you hear the motor running? If so, then the belt is broke or off.
Feb 03, 2009 | Whirlpool LER5636P Electric Dryer
Dryer wont spin
Doe the motor running ? if run w/out spinning the beltis the problem / bring sample to appliances center.
Aug 25, 2007 | Kenmore 45081 Front Load Washer / Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
