Question about Pilot Pen Frixion Erasable Gel
I have a Pilot FriXion Erasable Gel Ink Pen. I want to know how to insert the refill. Please assist. Thank you.
  • 40 Answers
Hi... Slightly above the rubber finger grip (about 1/8 of an inch) is where the pen unscrews. Once you have it unscrewed remove the old ink cartridge & place in the new one, there is no spring to deal with, so it just drops in.
Posted on Apr 01, 2011
When was the whiteboard marker invented?
Jerry Woolf invented the whiteboard pen, or marker, while working at Techform Technologies. Pilot Pen would patent the whiteboard marker in 1975.
Feb 20, 2013 | Office Equipment & Supplies
My 3yr old daughter used permanent marker to write on our toshiba regza flat screen tv.. how do i remove the ink from the marker?
there is a liquid called stoko slig which is used to remove permanent marker they are on the web i think they based in stafford hopes this helps
Oct 18, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
How to refill ricoh gelsprinter gx2500 ink cartridges
I using gelprinter recoh gx 3050, how i can refill this cartage
any branch in India give me gel ink & refillable cartage
pl. give advice abou
sujitgajre@gmail.com
Nov 08, 2011 | Ricoh Aficio GX3050 GelSprinter
I don't know how to refill?
Refilling HP color printer ink cartridges saves money and time spent running to the store to find the right ink cartridge, which sometimes is out of stock. By having the refill kits for the HP ink cartridge, you can just refill the cartridge when the ink runs out. The refilling process is easy to do and anyone can do it in a few minutes. The ink kits come with directions and all the colors one will need to refill the ink cartridge.
1.Place a piece of paper towel on a flat surface. Remove the empty ink cartridge from the printer. To do this, open the cover and wait for the ink dispenser to move the ink to the open door. Lift up the tap that holds the ink cartridge in place and pull out the cartridge. Push the tap holder back down and close the cover.
2.Place the ink cartridge on the paper towel. Gather the ink refilling kit together with directions and place the ink jars on the paper towel along with the syringe needle.
3.Find the indents on the top of the empty ink cartridge. Poke these holes open with the pen. Sit the cartridge down and open the ink containers. The colors are yellow, cyan and magenta.
4.Read the directions to see where each color goes in the ink cartridge. Insert the syringe needle into the ink container and raise the stopper up until you have the recommended amount of ink to fill into the particular hole.
5.Insert the needle into the hole on the ink cartridge and slowly dispense it into the cartridge. Remember to go slow with this step. If you see the ink oozing out, stop filling and wipe with a paper towel.
6.Cover the holes with the tabs that come in the refill kit or you can use tape. Make sure the hole is sealed to prevent spilling or the ink drying up. Then replace the ink cartridge back into the holder in the printer.
I hope you find it very helpful. Thank you for using fixya.
Aug 22, 2011 | HP PSC 1315 All-In-One InkJet Printer
Pen won't write though plenty of ink
There are a couple reasons a pen refill won't start writing right away. The first thing to check is the tip--often there is a bit of glue or plastic over it in order to prevent leaking.
If that doesn't work, then try one (or both) of the following two methods:
1) Place the refill (but not the tip) in some warm water. Heat will allow the liquid in the gel pen to become thinner and flow more naturally.
2) Hook a rubber band around the middle of the pen, using tape to ensure safety, and wind the pen while holding the rubber band on either side of the pen. Make sure the cap is on the pen. When the rubber band is tight, when you pull straight out on the rubber band from both sides of the pen, it should spin very quickly. The centripetal force will cause the liquid in the pen (at least half of it) to move toward the tip.
Make sure you fasten the rubber band to the pen with tape or something similar; otherwise the pen may go flying off at someone nearby. Also, again, make sure the cap is on to prevent any ink spraying out--this is unlikely in a gel pen, but it could happen.
Jun 13, 2011 | Sanford UniBall Gel Impact Rt Retractable...
I need to know how to reset printer after inserting a tricolour and black printer cartridges please.
Thank you I don't need assistance now as I have solved this problem by buying some new print cartridges as the ones we had refilled were not accepted by the printer.
thank you
Oct 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
How do I insert the refill ink cartridge?
according to all information i can find you have got the correct cartridges
nip to canon.com and download the user guide that shows you how yo install your cartriges
Regards AL "alstech"
May 25, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Pilot Pen Frixion Erasable Gel Logo
317 people viewed this question
Top Pilot Pen Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Pilot Pen Office Equipment and Supply Expert? Answer questions, earn points and help others
