Question about Sony Car Audio & Video
Have hooked up a sonycdx-gt290 radio into a1993 hyundai excel using hyundai and sony harness ,( plus speakers front and rear), radio working fine, my problem is the colour coding seems to be different to existing wiring on speakers .what are the colours for front right front left and rear right and left positive -negative coming from radio or what is best way of hooking up thanks Darrill
  • 2,418 Answers
The code for the wiring colors should be on the back of the radio. But, you can figure this out with one extra speaker on the bench (or floor board) The colors are in pairs = "gray - gray with stripe" The stripe will be the negative side of your speaker. So you will have a Gray pair, white pair, blue pair and green. Using one speaker on the floor or already mounted, hook it up to one pair of colored wires, lets start with gray. Now run the radio balance right then left, then fade front to back, to see which your speaker is hooked to. Make a note of which, then the next color run the balance right then left, then fade front to back, then the next so on and so forth. This way you will know which is which and you will have it written down for future reference when you move the radio into a new car. So if your gray pair has no sound on the left balance you know it is a right side speaker, then if it has no sound when faded to the front you know it is a rear speaker, so in that case Gray would be "right rear", Hope this helps Fixya up.
Posted on Mar 30, 2011
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
I need to find the wiring codes for my radio so i know which color goes to what?
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: Green/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Yellow
Car Stereo Dimmer Wire: Black/Orange
Car Stereo Antenna Trigger: Green
Left Front Speaker Positive Wire (+): Black
Left Front Speaker Negative Wire (-): White
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): Red
Right Rear Speaker Positive Wire (+): Green
Right Rear Speaker Negative Wire (-): Orange
Oct 15, 2012 | 2008 Hyundai Veracruz
When I got my car there was no radio what i didn't notice was there was no radio harness at all. Long story short I went to the store and the ones they have don't fit the stock or after stock decks I have....
2003 Hyundai Elantra Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red
Radio Switched 12V+ Wire: Yellow
Radio Illumination Wire: Pink
Radio Power Antenna Trigger Wire: Gray/Orange
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): White
Left Front Speaker Wire (-): Brown
Right Front Speaker Wire (+): Green
Right Front Speaker Wire (-): Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Yellow
Left Rear Speaker Wire (-): Black
Right Rear Speaker Wire (+): Orange
Right Rear Speaker Wire (-): Blue
hope this helps out!
May 01, 2011 | Hyundai Motor 2003 Elantra
I want uninstall the audio of my hyundai 1996, I need knowing that color is the positive and negative
Car Radio Constant 12V+ Wire: Red/Yellow
Car Radio Ignition Switched 12V+ Wire: Blue/White
Car Stereo Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4?
Front Speakers Location: Doors
Left Front Speaker Wire (+): White/Red
Left Front Speaker Wire (-): Black/Red
Right Front Speaker Wire (+): White/Blue
Right Front Speaker Wire (-): Black/Blue
Rear Speakers Size: 6 1/2?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): White/Red
Left Rear Speaker Wire (-): Black/Red
Right Rear Speaker Wire (+): White/Blue
Right Rear Speaker Wire (-): Black/Blue hope this helps
Feb 11, 2011 | Hyundai 1991-2002 Wire Harness
Which 2 wiers are the power wiers to the car radio
Hello ruben
These color codes are for the factory radio harness. there are 3 +power wires if you have a pwr antenna, this wire is pink. The ign/acc +pwr. wire is blue with black stripe, the radio memory +pwr.
wire is orange with a black stripe. Hope this helps.
Dec 06, 2010 | 2002 Hyundai Accent
Hyundai excel wiring diagram
are you talking about the radio if so here it is
Car Radio Battery Constant 12v+ Wire: Red/Yellow
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Brown/Red
Right Front Speaker Negative Wire (-): Black/Red
Car Audio Rear Speakers Size: 4′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Black/Yellow
Right Rear Speaker Positive Wire (+): Brown/Green
Right Rear Speaker Negative Wire (-): Black/Green
Jul 26, 2010 | 1994 Hyundai Excel
Need a wiring diagram for 2002 chev, caviler stereo hooking up aftermarket stereo
ARE YOU AWARE THEY MAKE A VERY INEXPENSIVE ADAPTER HARNESS THAT HOOKS UP TO THE FACTORY HARNESS, NO WIRE CUTING,CAR AUDIO SHOP CAN GET THE ONE U NEED, ABOUT $12. HERE IS THE WIRING COLOR BREAKDOWN OF THE DASH HARNESS.
2002 Chevrolet Cavalier Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Ignition Switch (The radio harness does not provide a switched power source. Run a wire from the Ignition Switch.)
Car Radio Illumination Wire: Gray
Car Stereo Antenna Trigger: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Negative Wire (-): Dark Green
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 13, 2010 | 2002 Chevrolet Cavalier Coupe
Need a wiring diagram for a 99 hyundai accent tape deck
1999 Hyundai Accent Car Stereo Radio Wiring Diagram Car Radio Constant 12V+ Wire: Red/Yellow Car Radio Ignition Switched 12V+ Wire: Blue/White Car Radio Ground Wire: Black Car Stereo Illumination Wire: N/A Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amplifier Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): White/Red Left Front Speaker Wire (-): Black/Red Right Front Speaker Wire (+): White/Blue Right Front Speaker Wire (-): Black/Blue Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): White/Red Left Rear Speaker Wire (-): Black/Red Right Rear Speaker Wire (+): White/Blue Right Rear Speaker Wire (-): Black/Blue
Jan 02, 2010 | 1999 Hyundai Accent
Im trying to connect my pioneer radio to my hyundai tiburon GT 2003, and i need to know what color wires on the radio go to what color wires on the cars wiring harness
Radio Constant Wire 12V+: Red
Radio Ignition Switched Wire 12V+: Yellow
Radio Illumination Wire: Pink/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: n/a
Factory Amplifier Turn On Wire: n/a
Right Front Speaker Wire (+): Black
Right Front Speaker Wire (-): Yellow
Left Rear Speaker Wire (+): Blue
Left Rear Speaker Wire (-): Red
Right Rear Speaker Wire (+): Green
Right Rear Speaker Wire (-): Orange
Oct 06, 2009 | 2003 Hyundai Tiburon
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Car Audio & Video Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
