Question about Everex StepNote VA2000T Notebook PC
I have an older Everex StepNote VA250W with 2-512 MB DIMMS (or whatever they are) and a 1.46GHz processor with 533 bus speed, and the processor went out. I would like to upgrade to a faster Processor and more memory if feasible and possible. Can you give me the part numbers of the options I can consider. I already have the Processor and Memory out and I just need to get the new parts before I forget how to put it back together. LOL Kind Regards, Carl Hatton 361-758-4051 cehatton@gmail.com
I NEED A USERS MANUAL FOR AN EVEREX STEPNOTE NOTEBOOK MODEL NUMBER VA250W
Try this http://gogot0.in/get.php?q=Everex+stepnote+va+250w+manual
Oct 06, 2012 | Computers & Internet
I dont have mother board driver for system model awrdacpi
The Intel® Desktop Board D915GAG supports one Intel processor in an LGA775 socket. See the table below for a complete list of supported processors.
Processors not specifically listed by type and rated speed can have requirements that are not supported by the design of the desktop board. Use of unsupported processors can result in improper operation, damage to the desktop board or processor, or reduced product life.
Processor Family System Bus Frequency L2 Cache Size BIOS Version Intel® Pentium® 4 800 MHz 2 MB 0391 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0477 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0475 or greater
533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater
DOWNLOAD LINK IS GIVEN BELOW...........
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22Intel+Desktop+Board+D915GAG%22
Sep 22, 2011 | Intel D915GAG Socket 775 Motherboard -...
Upgrade cpu
you can at most upgrade memory, rarely video, but I never seen ugrading a CPU on a laptop, most of the time the CPU is soldered and the MB does not support upgrade.
Sep 03, 2009 | Everex StepNote VA4103M Notebook
I have an Everex StepNote VA4300M Model# VA250W I am trying to find out everything i can about the motherboard but i cant find anything in the BIOS. I ran Belarc Advisor software and this is the info i...
The everex websites seem to be down or not working. The first thing you need to know is you model number. www.everex.com/support
The webpage at http://www.everex.com/support/lm7we/lm7we-support.htm might be temporarily down or it may have moved permanently to a new web address.Have questions regarding your Everex product? Contact our 24 Hour Technical SupportCenter (Toll-Free) at 866.850.8835, email techsupport@everex.com, ...
Dec 31, 2008 | Computers & Internet
Need to know bus speed of Trigem Cognac MB used in HP Pavilion 6730. Is it 100 MHz or 66 MHz?
it's 100 other info as follows:
Component Attributes RAM (standard) 64 MB SDRAM standard Maximum 256 MB (2 x 128 MB DIMM) Speed 100 MHz synchronous Sockets Two 168-pin DIMMs Size 16, 32, 64, and 128 MB DIMMs Type Supported SDRAM, 100 MHz, Intel PC SDRAM unbuffered DIMM specification, revision 1.0 compliant
Cache Level Quantity Level 1 (Primary) 32 KB (on processor) Level 2 128 KB (on processor) Upgrade Sockets None
Dec 09, 2008 | Computers & Internet
I have a 838gm gateway,Ive tried to install 4gb of ram ,when I install more than 2gb,it will not boot
Gateway's website says this motherboard will support 4GB of DDR333 or DDR400 memory. I would suggest testing each memory modules by plugging it into the board by itself, then rebooting. This way you can catch a bad DIMM that might be causing problems. If each one checks out then start adding one module at a time, rebooting after each one. If it still stops booting after you add a module, you probably have a bad system board, and only now that you are adding the extra memory are you finding that out. If that is the case, try contacting Gateway support. Maybe they would be kind enough to cover repair under warranty.
Nov 27, 2008 | Computers & Internet
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Everex StepNote VA2000T Notebook PC Logo
109 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
