Question about Home
I have a HoMedics p-12-3 twist lamp, and its missing the bulb i was hoping to find a diagram of the electonic part of the lamp so i can see how a bulb would go in, because right now its just a metal hoop that does'nt make sense.
Email me at Morris042@ymail.com and i can send you a PDF diagram of the solution. All you need is a 12V 20W flood light bulb. You can pick it up at any hardware store. It's about 1.3 inchs wide. The metal hoop and springs are what holds the bulb in place due to the vibrations from the pump.
Posted on Apr 27, 2011
WHAT SHOULD I DO TO FIX THE PASSANGER'S SIDE FOG LIGHT, AFTER TRYING TO REPLACE THE BULB, AND STILL NOT WORKING?
What is the condition of the bulb socket? Contacts show signs of corrosion or overheating? Use a meter to find out if it's missing the 12 volts to the bulb or if the ground is missing (open/high resistance). With the fog lamps powered on, connect the black meter lead to a good solid ground on the body of the car. Touch the red meter lead to each contact in the socket which the bulb plugs into. One of the contacts should measure about 12 volts. If no 12 volts then you will need to check fuses and wiring to find the open circuit causing the no voltage situation. If you measure 12 volts, then you know you have power to the bulb. The problem will then be with the ground. Turn off the fog lamps, set the meter to measure resistance (ohms). Leave the black meter lead connected where it was. Connect the red meter lead to the contact in the bulb socket that you did NOT measure the 12 volts at. The meter should read no/low/minimal resistance. If you measure high resistance, then you will need to locate the corrosion or open/broken wire between the bulb connector and grounding point on the car. Good luck!
Oct 18, 2014 | 2004 Hyundai Santa Fe
I have a Dometic DM2652. The refrigerator light bulb is missing. what size bulb do I need to get
I have a parts manual and it says on page 5 of the PDF location 43 in photo of the manual that 43 2007290006 A B Lamp, 10W, 12VDC. You need to scroll to the next page and line 43 is part number 2007290006 is the Lamp, 10 watt and 12 Volts DC Here is a link to the parts Manual=> Refrigerator_Parts_List.pdf Now that does not tell much about the socket but you may see that it is common. Or ask one of the major sites like GasRefrigeration.net Hope that is helpful, Thanks, Sea Breeze11_21_2011_7_26_21_am.jpg
Nov 21, 2011 | Dometic RM2652 Refrigerator
How to replace the left front turn signal bulb?
Remove the front fender liner to gain access to the front side marker lamp. Remove 3 screws from park lamp and pull out lamp. Twist the bulb socket and pull inward to replace the bulb...Here is a picture of it....Hope this helped you ?michael_cass_316.jpg
Jul 14, 2011 | 2006 Buick LaCrosse
Rear turn signal b ulb burned out - How to replace
Rear Turn Signal, Brake and Parking Lights
  1. Remove the tail light assembly screws, then the assembly.
  2. Disconnect the twist lock socket from the lens housing. NOTE: To remove the bulb, turn the twist lock socket (at the rear of the housing) counterclockwise 1?4 turn, then remove the socket with the bulb; replace the bulb if defective. Fig. 7: Remove the tail light assembly screws, then the assembly - wagon shown 86816223.jpg Fig. 8: Twist the socket counterclockwise to remove from the housing 86816225.jpg Fig. 9: This type of bulb simply can be pulled out of the socket for replacement 86816226.jpg To install:
  3. Attach the socket assemblies to the back of the lamp unit.
  4. Install the lamp assembly to the vehicle with the mounting screws.
License Plate Light
  1. Remove the lens screws.
  2. Once the lens is removed you, can access the bulb and replace if needed. To install:
  3. Install the new bulb, then attach the lens to the body of the vehicle.
Center High Mount Stop Lamp
  1. Remove the screws securing the lamp cover.
  2. Remove the mounting nuts, then unplug the electrical harness to the lamp assembly.
  3. The lamp now should come out. To install:
  4. Position the lamp assembly to the vehicle, then attach the electrical harness to the lamp.
  5. Install the mounting nut, tighten to 62 inch lbs. (7 Nm).
  6. Attach the lamp cover. Fig. 10: Exploded view of the center high mount stop lamp assembly - wagon shown 86816230.gif
    Fig. 11: Light bulb application chart for all models with non-European headlamps 86816237.gif
    Fig. 12: Light bulb application chart for Buicks with European headlamps 86816235.gif
    Fig. 13: Light bulb application chart for Oldsmobiles with European headlamps 86816236.gif
Dec 19, 2010 | 1994 Buick Century
Replace a brake light
COUPE The side marker lights for the SC and SC2 are part of the turn signal/parking light assembly. Refer to the procedure in this section for lamp removal and bulb replacement. Rear Turn Signal, Brake and Parking Lights EXCEPT WAGON
  1. Disconnect the negative battery cable. Fig. 5: Remove the trim panel fasteners - except wagon 84196109.jpg
    Fig. 6: Carefully remove the trim panel - except wagon 84196110.jpg
    Fig. 7: Pull the lamp assembly straight back and out of the opening 84196111.jpg
  2. Remove the trim panel fasteners, then carefully remove the trim panel.
  3. Remove the 2 retaining screws from the side of the lamp assembly, then pull the lamp assembly straight back and out of the opening.
  4. Tilt the assembly downward for access to the sockets, then twist and remove the socket(s) from the lamp assembly. Replace the bulb(s), as necessary.
  5. Installation is the reverse of removal. Fig. 8: Tilt the assembly downward for access to the sockets 84196112.jpg
    Fig. 9: Twist and remove the socket and bulb from the lamp assembly 84196113.jpg
WAGON
  2. Remove the retaining screws from the side of the lamp assembly, then pull the lamp assembly straight back and out of the opening.
  3. Tilt the assembly for access to the sockets, then twist and remove the socket(s) from the lamp assembly. Replace the bulb(s), as necessary.
  4. Installation is the reverse of removal. Fig. 10: Exploded view of the tail lamp assembly - wagon 84196114.gif
High-Mount Brake Light EXCEPT WAGON
  2. Open the trunk for access to the lamps.
  3. Locate the bulbs at the rear underside of the trunk lid. Remove the bulb(s) by twisting, then pulling straight out.
  4. Installation is the reverse of the removal. Fig. 11: Remove the high-mount brake light by twisting its socket 1?4 turn counterclockwise - except wagon 84196115.jpg
WAGON
  2. Raise the liftgate, then remove the wedge blocks from each side of the liftgate assembly.
  3. Remove the lower fasteners from the liftgate lower trim panel, by pushing in the center of each pin approximately 1?8 in. until it clicks, then remove the fastener.
  4. Insert a screwdriver or small prybar into the hole in the lower trim panel (located near the wiper pivot on the pivot hump) so that the tool sits on top of the pivot. Lift up on the tool handle to disengage the trim panel upper clips, then remove the lower trim panel from the vehicle.
  5. Unplug the high-mount brake light wiring harness.
  6. Remove the brake light fasteners, then remove the lamp assembly from the liftgate.
  7. To remove the bulb(s), push slightly on the top edge of the lens and rotate it away from the housing. Remove the bulb(s) from the housing. To install:
  8. In order to prevent the possibility of water leaks into the liftgate, inspect the lamp gasket for damage and replace, if necessary.
  9. If removed, install the bulb(s) by inserting the bottom edge of the lens into the housing and snapping it into place.
  10. Position the lamp into the liftgate and tighten the fasteners to 35 inch lbs. (4 Nm).
  11. Connect the wiring harness to the lamp assembly.
  12. Align the upper clips on the lower trim panel to the liftgate slots, then install the panel by pushing at the clip locations.
  13. Reset the trim panel push-in fasteners by spreading the center pin tabs and moving the pin so that it sits approximately 1?4 in. out of the fastener. Insert the fasteners into the bottom of the trim panel and push the center pin until flush.
  14. Install the liftgate wedge blocks.
  15. Connect the negative battery cable and check for proper lamp operation. Fig. 12: Removing the liftgate lower trim panel assembly - wagon 84196116.gif
    Fig. 13: Exploded view of the high-mount brake light bulb and lens assembly - wagon 84196117.gif
Nov 04, 2010 | 1998 Saturn SL
I need to replace rear tail light bulbs on 1996 Saturn SL1
WAGON
WAGON
Reverse Light EXCEPT 1991-96 COUPE For the Saturn wagons and sedans, the reverse lamp is part of the rear turn signal, brake and parking light assembly. Refer to the procedure in this section for lamp removal and bulb replacement. 1991-96 COUPE
  2. Reach behind the bumper bar and disconnect the harness and socket from the reverse lamp. Remove the bulb from the socket.
  3. If necessary, unfasten the retaining nuts and remove the lamp from the bumper bar.
  4. Installation is the reverse of the removal. Fig. 14: Exploded view of the reverse lamp mounting - 1991-96 coupe 84196118.gif
Oct 23, 2010 | 1996 Saturn SL
Parking lights,instramental panel tail lights do not come on. I checked the fuse and bought a new headlight switch
Before you replace a part make sure that the part is faulty by a confirmed test. Here what you can do is to use a multimeter or a 12 volt bulb ( park lamp) one side connected to ground and the other side searching for the missing voltage for the circuit. When you turn on the cluster switch of the park lamp check the voltage coming to the dash board cluster or the park lamps. Proceed backward to the point where the voltage was missed out, could be a loose connection or an open harness wiring, If so you can use a loop to the cluster swtich for the +12 supply. It will become easier if you identify the colour of the wire of the testing circuit and trace. I am sure you will locate the missing link and find the fault. I hope thie advice helps you. Good day
Jul 24, 2010 | 2000 Ford F350 Super Duty Super Cab
Remove and replace rear turn signal light
open up trunk and pull back any inside cloth trim to expose wing nuts. twist off wings nuts and the rear lamp assembly will then pull out from body. on the back of the lamp assembly is the connector / bulb assembly. this just twists off to unlock and remove from the lamp. replace bulb, lock bulb / connector back into place and the re-install the lamp assembly.
Apr 30, 2010 | 2002 Chevrolet Cavalier Coupe
I need new air pump for Homedics Aquascape twist lamp. Pum is Model:P-12-3
I have an older & slightly different 4 sided tapered Homedics aquarium, but it has the same pump. I used a meter to determine that the proper voltage was coming out of the transformer, measured at the plug. I took the base apart & bypassed the female connector switch the transformer plug, plugs into. Everything worked fine, meaning the fail was in the female connector, as the wires were solidly soldered on. With a magnifying glass, I could see that a rectangular "C" type copper flange, had the side that touches the side of the plug when inserted, had broken off, therefore making no connection. Using an insulated screw driver, I temporarily completed the circuit & confirmed the problem. Cut out the old female connector & take that & with the transformer (& its plug) to an electronic components store & find a suitable replacement. You will need additional heat shrink tubing & to solder the connections.
If your pump is truly not working even if it is getting power, I don't know the answer the full answer to that. A privately owned aquarium store may test the pump for you, & offer to feel or replace the diaphragm & check valves if the motor works. I see the screws are painted with locktite after re-assembly so the parts don't vibrate loose. Good Luck.
Sep 11, 2009 | Homedics EnviraScape Mariposa Illuminated...
WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Sep 17, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Home Logo
120 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
