Question about Plantronics - Usb Multimedia Headset Headset
No sound in lift side - Plantronics - Usb Multimedia Headset Headset
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
If the cord going into the headset or the headset itself has not been damaged, check the settings for the audio device on your computer to make sure the sound is still equally balanced between the left and right channels.
Good luck from Headsets Direct!
Posted on Dec 30, 2011
2000 Mercury Villager, third row bench stuck
you will have to take the mechanism apart and reseat the spring or replace the broken part.
May 29, 2014 | 2000 Mercury Villager
How to clean glass on samsung clx-3160fn
Ok to clean glass get tough and do not wreck the machine, sounds bad but damage could occure if your not careful but forceful.
1)down load any faxes not printed or sent to your computer
2)turn unit off with power button
3)inside of paper exit opening in the upper left hand side push green slide lever towards the back of the machine,,this locks the scanner carage(you can also see the green lock through the scanner glass to the left of the scanning carage as you move the lock). I did this not to disturbe the scanning carage while cleaning the glass.
4)the lid to the scanning bed has to be removed by lifting the complete tray to it's limit and unplugging the data cable,,it is in the middle between the hinges(pinch the cable connector plug locks on both sides and pull out the connector. To release the rectangular hinges lift and tilt the complete unit further back toward the rear of the printer/fax machine. It should lift out and REMEMBER that rear tilt when replacing the fax/printer feed unit as the hinges don't just slide back in to the respective holes.
5)there are two screws near where the hing holes are on eather side of the scanner cover they must be removed.
6)NOW this is the tricky part with only your hands no tools,,,with a large amout of force lift the back corner of the scanner cover(this does not seem possable but lifting at the side of the machine the cover does have a slight lip to lift with and it makes tearable sounds of distruction BUT IF you lift each side near the rear upward for about 1/2inch at a time(side to side)"2 INCHES ONLY" total the cover will give enough room to CAREFULLY reach your hand under the scanner cover with a damp rag to clean the glass and dry with a lint free rag(micro fiber rags work). I used no cleaners at all but lint free is the ticket. DO REALIZE THE TRAY ONLY LIFTS UP ABOUT 2 INCHES from the rear and it should stay up at the 2 inch hight. The removal of the scanning cover would mean more dissasembly of the unit and I saw no need to go that far.
6)NOW to replace the scanner cover (hopefully you were carefull enough not to crack or break the glass as lifting unevenly or pulling upward more than 2 inches could be the end to your scanner. The trick to get the cover back down with the registration tabs into thier respective holes,,it helps to pull outward on the sides of the plastic body where the tabs have to drop down into,,the large taps at the rear are a little less co-operative but with a bit more force the back body will seperate slightly and the read pins fall into place.
7)put the screws back in, then the scanner cover hinges first and snap the data cable into place,,Don't forget to slide the scanner lock (green tap)towards you to unlock the scanning tray.
Good Luck, it sounds difficult and it might be but it can be done without damage. I'm sure a true service repair man would not like the method but my machine is near it's final useful days.
May 27, 2014 | Samsung CLX 3160fn All-In-One Printer
Our aquabug will not sit entirely on the bottom. It keeps lifting up on one side & doesnt move' What is going on? It seems like we have plenty of suction.
This sounds like a problem with the pool cleaners shoes being worn. If the shoes become worn, it can cause the seal to the pool to become loose, even if you have enough suction. Try replacing the shoe on the side that is lifting (and both sides if they appear worn) and see if that corrects the problem.
Sep 20, 2011 | Hayward Aquabug Above Ground Pool Cleaner...
How do you change the fuel filter
The fuel filter is located in the tank. Lift the rear seat,lift left side sound insulation,unclip and remove 3 fuel pipes,remove electrical connection,undo nuts holding fuel pump,lift out complete unit be carefull!!!,On the pump you will see a gold colored tin cup,remove and filter is inside
Aug 28, 2010 | 2004 Subaru Outback
Yamaha 200HP, HPDI lifts out of the water when shifting
sounds like something got put together backward . most motors will lift when put in reverse if not locked down . this is to prevent getting swamped by the rush of water going backward .
Mar 13, 2010 | Boating
How to replace battery for Tomy Thomas engine, which has steam and sound, using blue plastic tracks? thanks
Take the screw out of the bottom front remove red plastic panel by lifting up on the front, this will allow you to lift front wheels up and to the rear, remove center wheels press the tabs on the left and right side in and remove the cab. One AA battery, reverse steps taken and begin playing.
Oct 18, 2009 | Tomy Thomas The Tank and Friends Track
Yamaha Diversion Seat removal
There is a key lock on one side just below the side fairing. The ignition key fits it, unlock the seat and then lift from the back.
Apr 24, 2009 | 1993 Yamaha XJ 600 Diversion S
One windshield wiper won't lift when turned on
Sounds like possibly the R/S armis loose or stripped . Also check linkage. With car and wipers off, carefully attempt to manually move R/S wiper arm. There should be little or no movement.
Mar 29, 2009 | 2003 GMC Yukon XL
Plantronics - Usb Multimedia Headset Headset Logo
75 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
