What is the ram capacity of the board - Computers & Internet
  • 61 Answers
Whats the board.... serial/make/model.....
Posted on Mar 31, 2011
System has got 512 DDR 400. Can I increase the ram capacity, as the system is working very slow. Upto what capacity the ram can be increased. Ravi
Depends which version of their board you have, I will list them here so you can just check your board and reference the right one:
Intel Desktop Board D865GLC - 4GB maximum Ram
Intel Desktop Board D865GSA - 2GB maximum Ram
Intel Desktop Board D865GLCLK - 4GB maximum Ram
If you only have 512MB Ram at this point then you definately will see huge performance increases if you take it up to at least 2GB and if you can take it to 4GB (especially since these boards only have onboard video instead of graphics card)
** If you found this information helpfuil please leave feedback to help us help others **
Feb 19, 2011 | Intel 865G Motherboard
How can I upgrade ram?
check for the clock speed of your old ram.... check for the type(DDR/DDR2/DDR3).. check your motherboard for capability to adapt greater capacity of new RAM.... buy a new one with same specifications but of greater capacity.... replace it with the old one or you can plug it to the empty slot if found any on the board....
Apr 20, 2010 | Medion M3 Composer 5200 PC Desktop
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
Maximum ram capacity for the board
You can look it up at this site: http://support.intel.com/support/motherboards/desktop/d865gvhz/sb/cs-010872.htm
but I believe it will be max. 2 GB per slot(DIMM)'s, so depending on the no. of slots on your MB x 2 will be the max. RAM capacity................sodeep
Jul 26, 2009 | Intel Motherboard
Upgrading ram
Well with this type of motherboard yes you can put 1gb into it however you can put up to 2gb on it and be just fine. Hope this helps you out.
Apr 11, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
RAM SUPPORT FOR D 845 GVSR MOTHER BOARD OF 2004
Greetings
Memory support for your d845gvsr board is as follows:
Memory speed - 333MHZ, 266MHZ and 200MHz.
Memory type - DDR SDRAM
Max Memory - Capacity of up to 2 GB
Memory Slots - 2
Memory module size is 1GB (1024MB) for slot.
Thank you,
Let me know if you need anything else.
Ekse
Mar 02, 2009 | Intel Motherboard
Upgrade ram
hiya
this board is ddr so you will need ddr400 or pc3200 and a maximum capacity of 2gb so be carefull with 1 gb sticks as sometimes this causes system crashes
hope this helps
Regard Rik
Feb 26, 2009 | Intel D101GGC Motherboard
I want to upgrade my HP BA 600 Mother Board`s RAM Capacity
Most likely your MB is too old for this upgrade although there is a chance you could flash your bios (reprogram your computer's brain to accept the new memory providing hp has a flash for it).
here is a link for the latest bios flash for your computer, use at your own risk.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=32895&swItem=vc3903en&prodNameId=20305&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0
good luck.
Thank you,
agadycom
Nov 27, 2008 | HP Computers & Internet
My PC won't work with 3Gb of RAM
THE RAM CAPACITY OF THIS BOARD IS
DDR266/200, Max. capacity of system memory: 3GB
- DDR333, Max. capacity of system memory: 2GB
- DDR400, Max. capacity of system memory: 1GB
Oct 03, 2008 | Asrock K7S8X-R3 Motherboard
About RAM
From the manual:
Memory
Supports two 184-pin DDR DIMM maximum size up to 2GB
Sep 29, 2008 | Matsonic MS9158EP (DSMTSMS9158EP)...
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
