Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman twin cylinder 19.5HP, no spark on plugs with switch interlock wire removed from the ignition module. Cleaned magnet and set gap to .010 (recommended setting on coil) wrapped wire on threads of plug and attached to ground. What should resistance reading be on coil contacts. Joe
I was able to solve the problem after I scanned several answers that were given on your site. The ignition module was defective and I purchased a new one, set the gap and it fired right over. Thanks for a great site. You saved me a $100.00 service call.
Thanks again,
Joe from Austin, IN
Posted on Aug 05, 2008
No spark with Huskvarna Rancher 55. New coil
anon re connect the kill switch. If this fail try connecting the two ends of the wire to the kill switch together.
Aug 27, 2014 | Garden
Saw will not start.
Check for spark by removing the plug, connect the plug wire, and lay the base on engine metal. Pull the starter through several times which should result in blue, snappy sparks. If weak or nothing, try a fresh plug (gapped 0.020"). If still nothing or weak, remove the left side cover to expose the flywheel and ignition module. Turn the flywheel til the magnets are under the module poles. Insert a thin business card into the pole gaps, loosen the module screws, and allow the module to contact the magnets. Tighten the screws and turn the flywheel somewhat to remove the card. Turn the flywheel one full turn to make sure the gaps don't close up any further. Remove the ignition switch wire from the module body, then try for spark again. If ok, reconnect the ignition switch wire and try for spark again. If now get nothing, check the switch/wire for a grounding short. If you still get nothing after the above test, replace the module using the above procedure. If the first test produced good spark, pour a little fuel mix into the hole and try for start, If you get several pops, you have a fuel delivery problem--check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor is tight to the engine. Make sure to have fresh fuel mix in the tank. Hope some of this helps!
Dec 06, 2010 | Craftsman sears 18" Chain Saw Chain (...
5200 no spark
Remove the left side cover to expose the flywheel and ignition module. Set the module pole gap by turning the flywheel magnets under the module, insert a thin business card into the pole gaps, loosen the module screws to allow the module to contact the magnets. Tighten the screws and turn the flywheel somewhat to remove the card. Turn the flywheel one full turn to make sure the gaps do not close up at any point. Remove the ignition switch wire from the coil connection (not the pole ground), and install a fresh spark plug gapped at 0.020". Try again for spark. If nothing, replace the module. Hope this helps!
Nov 25, 2010 | Poulan Garden
25" /1.5 cu.in. 2-cycle 17" cutting
Easy way to test plug is to remove it from cylinder head, then ground its hex base to side of engine..reattatch plug wire and pull starter cord...Do this is dim light...need to see a nice blue spark. So, do that...check the plug gap and plug condition (even if new)...if it's NOT firing...try another plug...if same...you will need to pull the engine covers off and check the "air gap" of the flywheel magnets to the pickup legs on the ignition coil module. You can gap it the thickness of a regular business card (.010"-.014"). The gap has to be present for the spark plug to produce a spark.
Jul 16, 2010 | Craftsman 25cc Gas Line Trimmer
CS-670 . Cleaned fuel tank , lines , carb. New
Check for blue, snappy spark at the plug (gapped at 0.020"). If weak or nothing, remove the flywheel cover to expose the ignition module. Check the module gap with a thin business card--turn the flywheel magnets under the module poles, insert the card into the gap, loosen the module screws, and allow the module to contact the magnets, then tighten the screws. Turn the flywheel somewhat to remove the card. Recheck for spark--if ok, try for engine start. If still no spark, remove the ignition switch wire from the module and retry for spark. If still nothing, replace the module. Install per the above instructions. Hope this helps!
Jul 06, 2010 | Echo Garden
Craftsman chainsaw 18" 42cc doesn't start
Remove the spark plug and test for spark. If nothing, try a new plug set to 0.020" gap. If ok, put a small mount of fuel mix in the plug hole and try to start. If you get several pops, then check the fuel filter, air cleaner and muffler for plugging. Check the fuel lines for rot or damage. Make sure to use fresh fuel premix (40:1) using modern synthetic saw oil in it's own can and shake thoroughly just before filling each time. If you got no spark in the first test, expose the flywheel and ignition module. Remove the wire from the module that goes to the ignition switch and check for spark. If still nothing, replace the module using a thin business card for a gap gauge between the module poles and the flywheel magnets. If you did get spark, then investigate the ignition switch and wire for possible grounding. Hope some of this helps!
Jun 24, 2010 | Ryobi Factory Reconditioned 18" 40cc...
No spark when pulling cord even tried holding plug machine is not producing any electric current
Remove the left side cover from the machine to expose the flywheel and ignition module. Remove the ignition switch wire from the module and try to obtain spark. IF now ok, check the ignition switch and the connection wire which may be grounding out. If still nothing, replace the ignition module. To install the new module, turn the flywheel magnets under the module, use a thin business card for a gap gauge, place the module and allow it to stick to the magnets. Set the screws tight, rotate the flywheel to remove the card, then turn the flywheel one complete revolution to make sure the gap doesn't close up at any point. Attach the ignition wire and try to obtain spark. Place a small amount of fuel mix into the plug hole and see if you get several pops. If it still won't start, then check the air cleaner, fuel filter, and muffler for plugging. Check all fuel lies for decay or damage. Make sure the carburetor fasteners are tight including those holding the carburetor to the cylinder. Hope this helps!
Jun 19, 2010 | Garden
Poulan 295 model chainsaw/ won't start, no spark
Start first with a fresh spark plug set at 0.020" gap. Make sure ignition switch is on. If still nothing, remove the cover from the flywheel. Set the ignition module gap by using a thin business card between the module poles and the flywheel magnets. Loosen the mounting screws, let the module contact the magnets, and re-tighten the screws. Turn the flywheel to remove the card, then rotate the flywheel on full turn checking that the gap doesn't close-up any further. Check for spark again--if still nothing, remove the ignition switch wire from the ignition module. Check for spark--if spark now occurs, check the condition of the ignition switch or the connecting wire may be grounding out somewhere in between. If still nothing, replace the ignition module. Hope this helps!
Jun 10, 2010 | Poulan Pro Chain Saw 46cc 20"
25 cc craftsman weed trimmer.\r\nNot getting spark
If you're sure it's not getting spark, the first thing to check would be the "air-gap" setting between the magnets on the flywheel and the ignition coil module . The correct setting basically only requires the use of a regular business card and is around .010"-.014" If there is an air gap present, check it and then you can move on to diagnose the coil module ( they don't go bad very often) if necessary.
Jun 08, 2010 | Craftsman Garden
Craftsman 16'' chainsaw would not start even applying starting fluidand full choke.
The first thing to check for is spark at the plug. Remove it and reconnect the wire--lay the plug body on the cylinder head or other metal part. Pull the engine through--the spark should be blue and snappy. If nothing, make sure the ignition switch is set to run and try a new clean plug. If still nothing, you need to check the ignition system. Go to: searspartsdirect.com and enter the complete model number of the saw (minus the decimal point). A series of drawings will appear, select the ignition layout. If this is a newer saw, the ignition will be a self-contained module mounted just outside of the flywheel. The first check before buying a new module is to remove the grounding wire that goes to the switch, and try to get spark again. If still nothing, and the pole gap between the module and the flywheel magnets (set with a thin business card for a clearance gauge) appears to be correct, order a new ignition module. Once you get spark, the other major problem is usually the fuel system. Hope this helps!
Apr 17, 2010 | Garden
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
