Question about Imation SuperDisk External LS120 Drive
I have an Imation SuperDisk drive that I just powered up after years. I'm trying to transfer data from disks onto my macbook. It's working but taking 30 minutes to transfer 2.6 MB. I've got about 10 discs to transfer. Is there a driver I need that would speed this up?
  • 6,993 Answers
You don't need a driver to speed it up. Basically the Imation SuperDisk drive is usually very slow while operating.
The system speed/configuration of your Mac-book or computer would be the only thing that can boost up the speed a bit.
You have no choice than just to be patient still it finish transferring, even though it is going to take a very long period of time.
I hope you understand the above.
Good luck.
Posted on Mar 30, 2011
Imation 11795 driver WindowsXP
IMATION stopped making the "LS-120" (Laser Servo) drive many years ago, when USB-interface memory-sticks became cheaper & faster. Imation did have parallel-port device-driver software for Windows 95/98/ME, but never updated them for Windows NT/2000/XP.
Instead, disassemble the case, and you will find an IDE-interface Imation LS-120 drive inside. Connect the same "smaller" 4-pin power-connector that used to connect to a 1.44 Mbyte 3.5-inch diskette, set the "master/slave" jumper, and connect an 80-pin IDE ribbon-cable, and connect the other end of the ribbon-cable to an IDE socket on the motherboard.
Jul 06, 2014 | Imation Superdisk Drive 120mb Parallel...
I need a driver for Windows XP and Windows 7. I have the parallel port version of the LS120 drive, brand: Imation It seems that nowadays this is almost impossible. I found one site that asks me to pay...
You might consider downloading a Linux LiveCD (such as Knoppix), boot to it, and see if Knoppix detects the LS-120 when connected to the legacy computer via parallel port. Make sure that the parallel port is enabled in the BIOS. From there, you can transfer the content from the disks to a flashdrive or external hard drive. My assumption is that you want to retrieve the data that are on these disks. In most cases this ancient hardware should be deprecated once data retrieval is complete. From my experience, the Knoppix DVD is more compatible than the CD version.
Paul Ronco
Jan 29, 2018 | Imation (11762) LS-120 (SuperDisk) Storage...
I have recently a product called imation. I have no idea what function it performs on my iMac. I want to back up some stories I have written onto either a disc or whatever you can recommend. I have recent...
well, you can get a external hard drive. if your looking at up to 32 gigs of data, it can be as small as a usb key. if its anything more, i reccomend a terabyte harddrive such as the passport by western digital. every mac has a time machine capability which will automaticcally back up your data good luck!
Jul 24, 2011 | Apple Imation SuperDisk Drive
I have a very old Imation superdisk drive, 9" by 6" size. And I can't find a driver to download
If it is the "internal" Imation SuperDisk drive, then set the drive's "master/slave" jumper (just like you would set the jumper on a disk-drive or CD/DVD drive), and connect it to one of the IDE ribbon-cable connectors (which usually connect disk/CD/DVD drives to the motherboard).
No additional drivers are required, in the above configuration.
Jan 23, 2010 | IBM SuperDisk (05K9235) Internal LS-120...
imation super disk SD-USB-M2.Solution to run under Vista service pack 1.Works for me
boot up your puter then plug in the imation super disk into your puter's usb port then into your power sulpply socket.Then if you have a reset button on your puter Press it
the puter then shuts down and resets itself when the screen appears it asks "Start up normally" Press enter.The drive is recognised and works.Its a bit of a ball ache but works for me.Hope this helps others with the same problem
JM.
Jul 12, 2008 | Imation (01946) External Floppy Drive
LS 120 Super Disk 120 MB Imation
hey there,
all i can say You make it a point to stay on the cutting edge of IT, so it's only fitting that your next support call is for a cantankerous old floppy drive. You're as far from the cutting edge as you can get, but can you still find the fix?The floppy drive is...
Feb 04, 2008 | Imation (11762) LS-120 (SuperDisk) Storage...
Data transfer
Usually your local Fry's, Staples, Office Depot could do the job for you (or even a local PC Tech).
Oct 17, 2007 | Imation (01946) External Floppy Drive
Imation LS120
My computer has such a drive (120 Mbytes/disk).
As a "random act of kindness", I will read them, and burn the files onto a CD-R. Reply to this message, if you wish to proceed.
Oct 17, 2007 | Imation (11762) LS-120 (SuperDisk) Storage...
Main advantages
* Super high capacity storage/ floppy disk compatible The Panasonic PV-SD4090 and PV-SD5000 digital cameras offer super high capacity storage on a 120MB SuperDisk™ Diskette for up to 1500 shots on the PV-SD4090 (Up to 1000 on PV-SD5000). Also, both cameras are floppy disk compatible. * USB Port/External SuperDisk™ Drive Both cameras come equipped with a USB port so you can quickly and easily transfer images from either a SuperDisk™ Diskette or floppy disk (using the included USB cable) to your computer, even if your computer does not come equipped with either a SuperDisk™ Drive or floppy disk drive. In addition, images and data can be transferred from your computer to the camera using the included USB cable*. This lets both the PV-SD4090 and the PV-SD5000 digital cameras function as an external SuperDisk™ Drive so you can easily archive your images or backup all your data (i.e. Excel, PowerPoint files). * Inexpensive media Panasonic SuperDisk™ digital cameras use SuperDisk™ Diskettes or 1.44MB floppy disks. SuperDisk™ Diskettes cost approximately $10.00 each (suggested retail price), which is far less expensive than comparable CompactFlash or SmartMedia cards. * Motion image recording with audio The PV-SD5000 can record up to 12 seconds of motion images with audio (the PV-SD4090 stores up to 10 seconds) using the popular QuickTime™** format, so you can easily send motion image files to friends and family. * TIFF recording (PV-SD5000 only) TIFF format recording allows you to take uncompressed images with greater clarity and detail. * Comes with a complete package of accessories, including: 1. 120MB Panasonic SuperDisk™ Diskette 2. Rechargeable lithium ion battery pack 3. AC adapter charger 4. DC cable 5. A/V cable 6. USB cable 7. Camera strap 8. Software CD-ROM including Adobe® PhotoDeluxe® editing software *Requires Microsoft™ Windows® 98 preinstalled PC with USB port, Windows® 2000 PC with USB port, iMac® or Power Macintosh® G3 or G4 with USB port and Mac OS version 8.1 or later. Windows® 2000 driver for the PV-SD4090 is currently available on this website. Software for the PV-SD5000 will be available in the near future. **QuickTime and the QuickTime logo are trademarks used under license. QuickTime is registered in the U.S. and other countries.
Sep 04, 2005 | Panasonic Palmcam PV-SD5000 Digital Camera
Main advantages
Sep 04, 2005 | Panasonic Palmcam PV-SD4090 Digital Camera
Imation SuperDisk External LS120 Drive Logo
79 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
Jax Planet
Jax Planet
carey w mason
carey w mason
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
