Question about Whirlpool Washing Machines
- Stops after approx 5 minutes "prewash" from the
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
FA is "aquastop failure- check aquastop switch", (aquastop switch is flood switch located in base of machine)
Remove rear panel and check base for any water, which would indicate a leak.
If OK, next step would be to remove front panel (remove wire and spring from around door seal, remove 2 screws holding door lock, remove 3 screws along base- front panel comes off by pulling down and out towards you-can be a bit tight)
Pressure switch is located just above door lock-it has the black tube going to it- remove tube and blow into switch-you should hear it click.
Also check the chamber that the other end of the tube connects to on the bottom front of tub- this chamber can get blocked up and cause overfill problems.
Please note- always disconnect from power supply before attempting any repairs.
Posted on Mar 30, 2011
Alternator not working
What is year--make--model of vehicle? I'd check alternator connections to and from alternator. Check battery and battery connections. Check for charging system trouble codes, see if any?
Nov 20, 2015 | Cars & Trucks
6 y/o E381T fridge. Last 6 mths, started making knocking sound. Motor not running. Occurs when room temp cool - at night etc. If power off then on, it stops and motor starts. Else continues a minute.
from your description of the problem it is impossible to accurately diagnose the fault
Best advice is to get a technician out to check it out as it could be a failing compressor or compressor mounts
get a quote for any major repairs as a compressor replacement generally costs more than a new unit
Oct 26, 2015 | Refrigerators
MIELE W412 PREWASH INDICATOR FLASHING
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
INGROUND pOOL 8.0M X 4.5M sAND fILTER onga psf25 1.5 pUMP / 1100 hP aUTO CLORINATOR yOU PRESS A BUTTON AND MOTOR STARTS UP AND FILTERS FOR APPROX 5 MINUTES THEN STOPS
Its either clogged or overheating or internal fault . Do you have to press the red reset button each time.If so there is a fault with the motor and will need to go to electric motor specialist.
Feb 24, 2010 | RTO Safety Vacuum Release System - SR-500...
A/C works in 5-7 minute intervals
compresser usually has low charge when this happens make sure its not leaking refrigerant get r134 with uv dye to locate leak
Jul 15, 2009 | 1999 Dodge Ram
Motor starts but no water entering dishwasher
TRy priming by putting a jug of water in bottom of inside of dishwasher
Mar 04, 2009 | Westinghouse Dishwashers
Whirlpool calypso clothes washer stuck on the "FL" for overfill code - will not reset after hitting stop/cancel or after unpluging - one year ago the customer service for whirlpool gave us the...
Try pressing the following key pad buttons within 5 seconds - PREWASH OPTIONS - WASH TIME, PREWASH OPTIONS - WASH TIME, in this sequence and allow the washer to run. The LED display will start counting down as the washer begins a sequence of short diagnostics tests. If no error is present, the washer will return to standby. If the error persists, you may have a blockage in your drain pump. Please run the test and let me know the results. Total test time is about 1 minute 40 seconds. I hope this helps you.
Jul 24, 2008 | Whirlpool Washing Machines
Washing Machines Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal De
