Question about Audiovox VM-9021TSX Car Video Player
Please, I need user instructions for Jensen VM9021TSX Thanks
Need users manual for SMPV-4GBEB
Hi mylakers101...
Go to the following website and download your FREE user manual
Please take time to rate me
http://safemanuals.com/user-guide-instructions-owner-manual/JENSEN/SMPV-4GBEB-_E
Aug 28, 2011 | Jensen Audio Players & Recorders
I need programming instructions for Jensen remote control Jer 321 and codes for a Sharp tv I need programming instructions for Jensen Remote Jer 321 and codes for Sharp tv
Here you go...it took a while but I found the user manual cause I ROCK....that's right say it with me....He...Rocks...hehe...but anyway here is the link address if the link doesn't work...
http://safemanuals.com/user-guide-instructions-owner-manual/JENSEN/JER-321-_E
I hope this helps...good luck and thanks for rating my effort....the Fang
Download the completeuser guide (3257 Ko)
May 15, 2009 | Jensen JER-321 Remote Control
I HAVE A PROBLEM WITH THIS CONTROL JER321 I LOST MY USER GUIDE
Download the complete user guide (3257 Ko)
Sep 10, 2008 | Jensen JER-321 Remote Control
Bypass parking brake on vm9021tsx
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Aug 17, 2008 | Jensen Car Audio & Video
REMOTE CONTROL
Here you go...it took a while but I found the user manual cause I ROCK....that'sright say it with me....He...Rocks...hehe...but anyway here is the linkaddress if the link doesn't work...
Jul 30, 2008 | Jensen JER-321 Remote Control
Owner's manual
go to www.jensen.com and download it is free.
Jun 12, 2008 | Jensen JMC-350 CD Shelf System
Manuals
Here you go...it took a while but I found it cause I ROCK....that's right say it with me....He...Rocks...hehe...but anyway here is the link address if the link doesn't work...
Nov 21, 2007 | Jensen JER-321 Remote Control
Audiovox VM-9021TSX Car Video Player Logo
49 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
