,Some months ago my computer stop lighting up, turning on and nothing is going on in the system, i think it is the fuse that blow,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
  • 374 Answers
If your computer does absolutely nothing when you power it up - the fans don't turn on, no lights turn on and the the monitor screen stays dark, some component inside your personal computer has failed. Unfortunately, there are no visible fuses that you can replace. There's a good chance the power supply has failed however you need a PC power supply tester to test it. However, there are other components in your computer which could have failed and cause the computer to do nothing when you power it up. If you have the required tools, test equipment and understand how these components work you can test them and determined which component has failed. Otherwise, you need to have a computer technician determine what your problem is.
I'm sorry that I can't help you more, but repairing computers is similar to repairing automobiles . If my car will "turn over" when I turn the key on but will not start, I could replace the fuel filter, fuel pump, coil, ignition computer etc. until I found the problem, but I don't have the parts/tools, I don't know how to test automotive problems and I don't want to waste money and possibly cause more damage by just guessing. I take the car to my mechanic for repair.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Posted on Mar 30, 2011
    President:
  • 1,623 Answers
Change the power supply if that doesnt fix it then your motherboard has blown, there are no fuses in the power supply, you have probably blown diodes inside it. You have tried another power lead, that you know is working?
2 Suggested Answers
nadereleraki
  • 433 Answers
SOURCE: ,Some months ago my computer
think about power supply
battery
bios
Help me please : I have a 2002 toyota corolla that stalled and now it won't start
When you had engine light on you should go to auto zone,they do for free to check what codes you have then fix.Could be fuse or fuel pump try to check this first and try get scan for codes...
Oct 26, 2015 | 2002 Toyota Corolla
Radio quit working
Sounds like someone shorted the wires...you need to look into the entire butcher job and see what wires were touched. Disconnect everything the butcher did and then see if your battery is still drainning power.
Dec 03, 2013 | 2006 Chevrolet Malibu
Audi A6 Brake Light & Beeping
think its a computer system issue-its all connectd these days-even with the steering--disconnect batt then put it back after a minute-may clear up--------if not pull plug at computer clean it and replug a few times-----these reboots at times work------but u mite need to run a thuro diagnostic to see different voltages-go to a good mechanic not a dealer--a hand held scanner will not do this
Nov 11, 2013 | 2005 Audi A6 3.2
Saturn 2002 L200 Air conditioner problem
The compressor clutch has a relay that energizes the A/C comperssor clutch an The PCM / ECM - engine computer energizes the relay . what you have posted here ( I did reset the battery thinking it was a computer error but still no fix) . Will do nothing ,you people think resetting the computer can fix anything ????? Take it to a qualified repair shop that knows how the system works . There are high an low pressure cut off switches ,maybe the clutch coil is bad . Could have DTC'S - diagnostic trouble codes . Hooking up A/C gauges is also a must , you do not want to add refrigerant if it doesn't need it . Checking Automotive Pressures updated How to Diagnose and Recharge Your AC System with Refrigerant Using an...
Mar 07, 2017 | 2002 Saturn L-Series
I have a Bosch Nexxt 500 andjust replaced the heating element less than 6 months ago. A week ago it stopped heating up again. Took the back panel off, pushed the reset button but now when I turn it on, the...
Sounds like a bad thermal fuse or thermostat, check all of them with a multi meter for continuity. as for the heater going out I would check ur venting inside and out the machine. the fuses and heater blow out for a reason? Usually due to overheating issues? I suspect ur lint build up is the problem?
Aug 16, 2012 | Bosch Nexxt 500 Dryer
Onkyo TX8211
The most likely problem is shorted output transistors. This is a straightfoward repair for any shop that works on audio gear. Expect a parts cost in the $40-$50 range.
Dan
Aug 12, 2009 | Onkyo TX-8211 Receiver
Ignition sys
Blown fuse...this happened to me about a month ago...check under the hood...go into the fuse box replace fuse...its a "20" on the side closest to engine...
Oct 19, 2008 | 2002 Mercury Cougar
LED Power light turns on, but nothing happens
If you've only had it 6 months then I would suggest you contact the manufacturer for a warranty replacement. Their warranty period is 1 year so see what they can do.
Mar 15, 2008 | Disney Pix Max Digital Camera
Computer stopped responding ! Nothing appears.
Try replacing the Power Supply next.It sounds like it is on its way out.
Please let me know how this works for you.
Thanks
Dec 18, 2007 | Gigabyte GA-8ID533 Motherboard
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
