Question about Toshiba Satellite L305-S5907 Laptop
My wireless network connection disconnected. When I tried to reconnect (I have a secure wireless router connection), my network name wasn't listed in the list of options. I restarted my router and reinstalled it in my PC. However, it still doesn't show up in the options on my laptop. When I try to manually connect, the message I receive is that the network already exists. However, it's not listed. What now?
    Sergeant:
  • 236 Answers
1. Directly connect to the router with an ethernet cable from your PC.
2. On the browser, enter the router's IP address
3. Log into the router
4. Navigate to router's wireless setup
5. Change the SSID to something NEW and DISTINCTIVE - do not use a default SSID
6. Make sure SSID is being broadcast - click to set the check-box if it wasn't set before
7. Save and exit the router setup then disconnect the ethernet cable
8. On your PC, View Wireless Network Connections
9. Click Network Task to Refresh network list
10. Your router with new SSID should show on the refreshed network list
11. High light your router's new SSID and click the Connect button
12. On the pop-up requesting WEP or WPA key, enter the key you had set in the router before.
Posted on Mar 30, 2011
Can not connect to network
Connecting to a Wireless Network Using Linksys Wireless Manager Article ID: 17673
Follow these instructions to connect to a wireless network using the Linksys Wireless Manager.
Step 1:
Launch the Linksys Wireless Manager. To learn how to access the Linksys Wireless Manager, click here.
Step 2:
In the Connect to a Wireless Network screen, locate the name of your wireless network in the list.
NOTE: If your wireless network is not in the list, click here to learn How to Connect to a Hidden Wireless Network. If your wireless network supports Wi-Fi Protected Setup kb17673-005_en.png, click here to learn How to Connect Using Wi-Fi Protected Setup.
Step 3:
Select your network. Then click Connect.
Step 4:
If the wireless network uses wireless security, enter the security key or network. Then click Next.
Step 5:
The Checking Connection screen appears while the Wireless Manager establishes the wireless connection. When it is finished, click Next to continue.
Step 6:
The Connected to Your Network screen appears. If you want the Wireless Manager to remember your network settings select Remember this network. Click Finish to exit the Wireless Manager.
NOTE: Saving a network's settings will make it easier to reconnect to the network.
Nov 04, 2010 | Linksys WRT160N Wireless Router
Tip
Tips for Media state Media disconnected or Network cable Unplugged
Wired adapter or NIC Local Area connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a physical device or connections
Solutions: 1. Try with a different port on the switch or the router. It could be the fault with the Router/Switch port 2. Try a different Ethernet cable. It could be the fault with the Ethernet cable 3. Try with a different NIC or a different computer. It could be the fault with the NIC
Wireless adapter or NIC
Wireless network connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a some device issue or the wireless settings
Solutions:
1. Try scanning for wireless network and reconnect 2. Remove the profile or preferred networks from its list 3. Check and make sure the SSID and the Security KEY are correct 4. Restart the computer 5. Try with different security types like WEP,WPA or WPA26. Check if the MAC filter on Router/Access point is enabled
on Aug 21, 2010 | Computers & Internet
Web key wireless internet service
I think you meant WEP key. this is a wireless encryption security key. and it is normally required when you try to connect to a secured network. Your administrator should be able to provide you with this. because it varies. i.e you can set it to whatever you want if you have access to the wireless router. in your case Belkin 54g Wireless DSL/Cable Router
so please if you have access to it, log in to the router and check from wireless security settings.
Regards
May 20, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Can't Reconnect to Secure Wireless Network
there is a problem with your WEP key, means the password which is used to enter your router or network. simply delete the network from the network list and connect to the network again and insert the correct shared key.
May 03, 2010 | 2wire 2700HG-B Router (2700HGB)
I hooked up my wireless router to my modum but no internet is going out to my laptop
Open the router's GUI with 192.168.1.1 if it is a linksys/netgear router login with username - leave blank password - admin for linksys router
Click on wireless tab on top- Select Manual - Wireless n/w mode - mixed, Network name SSID(Remove linksys and type the name you want to give to wireless network), Radio band channel- Std.20Mhz. Wide Channel - Grayed out,Std.Channel-6.2.437GHz. , Broadcast of SSID - Enabled,Save settings, Click on wireless security (Under sub tab of wireless) - Security mode - WPA - Personal - Type the password you want to create for wireless. Try to search for wireless networks and try to connect. At times you not able to connect - So try to remove the preferred networks from list.
Synario for win xp -
Start - Control Panel-Network and internet- Network Connections - Rt. click on w/l n/w connection - View available w/l n/w - Click on Changed Adv. settings - Click on w/l n/w tab in btwn the general and advance - Remove the prefrerred networks from list. And now click ok - come out from ever y window and click on the pop up whuich says network detected/One or more n/w found in range- Click on the w/l name belongs to you - And hit connect - Type you security key and all set.
At times you not able to see w/l tab btween general and advance -
Thn Click on start - type services.msc in run - Rt. click on Wireless Zero Configuration (Myt be last or second last option from list) Click on start- And now try to connect to w/l after removing the preferred networks from list.
Apr 01, 2010 | NetGear WGT624 Wireless Router
XP PC connects/Vista PC doesn't/Connectivity issues
On the Vista Computer
Goto
Start>Control Panel > Network and internet > Network and Sharing center
On the Left Hand Side Click on Manage Wireless Networks
Remove your network From the List
then
Start > Connect to> Click on ur Network > Click Connect
Dec 22, 2009 | Belkin F5D7234-4 Router
I think another user on my computer clicked "do not trust" for my wireless router. i cannot connect to my router, only to the ones around me, how can i determine if i am connected to my wireless router and...
You need to customize your wireless router:
Here's how to do it.
1. On your main computer, open Internet Explorer and type http://192.168.1.1
2. It will ask you for username and password. No username and the password is admin
3. Go to Wireless tab. Change the Wireless Network Name (SSID) to your own name or any name. Click Save Settings on the bottom
4. Now go to Wireless Security sub-tab. Choose WPA-Personal for the Security Mode. Type a password on the WPA-Shared Key box. That will be your wireless security key. Click Save Settings.
Then you can try to reconnect to wireless network, you should see your new network name there with security.
Jan 20, 2009 | Linksys Wireless-G WRT54GS Router...
Getting wireless computor and router back on line with desk top computor
1. Disconnect power from your modem and router
2. Connect an ethernet cord from your modem's ethernet port to your router's Internet or WAN port.
3. Connect another ethernet cord from a port on your router (labeled with a "1" above it).
4. Connect power to your modem and router.
5. I'm a little unsure about how you plan to connect your wireless computer to the router. The router you selected when you created this question is not wireless-capable.
If your router is wireless-capable, go to the wireless computer. Follow the instructions for your operating system below.
Windows XP
1. Right-click on the My Network Places icon on your desktop, and select Properties.
2. Right-click on Wireless Network Connection.
3. Right-click on View Available Wireless Networks.
4. Double-click on your network from the list that appears (it should be called "linksys" if you didn't change the name).
Windows Vista
1. Click on the network icon on the lower-right of your screen (it should look like two computers with one behind another. It might have a red "X" over it.)
2. Click "Connect to a network" (it also might be labeled "Connect or disconnect")
3. Double-click on your network from the list (it should be called "linksys" if you didn't change the name.
Mac OS X
1. Click on the AirPort menu in the upper right of your screen (it looks like "("s turned on their side).
2. Click on your network in the list that appears (it should be called "linksys" if you didn't change the name).
Sep 30, 2008 | Linksys EtherFast Cable/DSL Router
WRT54G3G router (Mobile)
Try this steps.
Go to Network Connections
Properties of Wireless Network Connection
Click Wireless Network Tab on the top
At the bottom, clear the Preferred Network box. Make sure delete all names that are listed.
Click OK all the way out
Enable the WEP on the router.
Now try to connect to the wireless network again with WEP enabled.
Make sure you enter the 10-digit code and not the Passphrase.
If it doesn't connect, try to power cycle the router. Just unplug the power for 30 seconds then reconnect to the wireless network.
That should do it.
Jul 31, 2008 | Linksys WRT54G3G Wireless Router...
Problem securing belkin wireless g plus router
you must enter the WEP key because if type in the pass-phrase it won't connect(don't know why)
Jul 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Toshiba Satellite L305-S5907 Laptop Logo
215 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
