Question about Clark Forklift Horn Button Switch , Cat Etc
I'm looking for the horn on a Cat GP25K forklift
I have a toyota 5fbe15 forklift set at 36 volts. The problem i'm having is that every now and then, it will shift at normal speed, 5-6 mph and slow to 1 mph. Usually happens if it's shifted from foward...
Good morning.... sorry I have a Toyota forklift 5fbe15, which has problems with the left engine, since that does not work correctly...
If both are connected do not respond correctly...
I did not mark code can help me I have no manual... or diagrams
Sep 13, 2010 | Clark Forklift Horn Button Switch , Cat...
Tm 20 clark forklift error code -46 what does it
sounds like the #1 rectifier is shorted or the insulator gasket is shorted through -also the 1A contactor may be welded shut -usually caused by a weak battery or running a discharged battery too long. -Troy from A-Lift Services
Jun 21, 2010 | Clark Forklift Horn Button Switch , Cat...
Problem with Clark forklift TMX12-25 TMX250, red spanner warning lights come up. whats that mean, how to reset it
It means it's time for your periodic maintenance, the reset button should be close to hour meter
Feb 01, 2010 | Clark Forklift Horn Button Switch , Cat...
Why does my clark forklift lower by it self
it has bypass in the cylinders you need to rebuild it[put new seals in it].
Dec 21, 2009 | Clark Forklift Horn Button Switch , Cat...
Clark Forklift GPX25 will not shift into reverse. Unit was working fine a month ago. Do not use the forklift that often about once or twice a month. Unit will work in forward, but not reverse. Even when...
I got the same problem and same model, what's going on with Clark forklift, I look for the new transmission all over internet but can't find any. if any body know what wrong please tell us what to do. thanks a lot. TMV
Oct 03, 2009 | Clark Forklift Horn Button Switch , Cat...
Leaky Linde
Is it comming out of the pump? if it is it's a Bear to get to.
Apr 12, 2009 | Clark Forklift Horn Button Switch , Cat...
No brake pressure Cat t50d forklift.
thottle linkage on t50d catipiller forklift anyone know how it goes on
Mar 25, 2009 | Caterpillar American Construction...
Clark Forklift Horn Button Switch  , Cat Etc Logo
29 people viewed this question
Top Clark Electrical Supplies Experts
Bill Boyd
Fred Sops
Are you a Clark Electrical Supply Expert? Answer questions, earn points and help others
