Question about Brother MFC-7220 All-In-One Laser Printer
I have a Brother MFC-7220 Laser printer. I have replaced the ink cartridge and still get a message that ink cartridge is empty and needs to be replaced. I removed it and took it over to another exact brother printer and it works fine with the same cartridge. Can you please assist me on fixing this problem...your help is greatly appreciated. Thank you in advance. Regards, Josh
Open front cover. Press Options button. Display reads," Reset Drum? 1=Yes 2=No" Press Start > 1 > 0 This resets the toner life counter within the machine when it fails to on its own at the time the cartridge is repalced.
Posted on Jun 07, 2011
  • 52 Answers
Try purging/cleaning the printhead. Instructions are in the operators malual
Posted on Mar 30, 2011
I have to print out a paper right away, could you help me?
If it still prints ignore it.
if you rather call the vendor. Ifyou're under warranty. They may replace or repair it.
Apr 18, 2015 | Brother MFC-7220 All-In-One Laser Printer
My Brother MFC-7220 shows the error message "Dust
Try cleaning the drum in the toner cartridge with a soft cloth. If this does not work then a replace toner cartridge is the other solution.
Nov 26, 2010 | Brother MFC-7220 All-In-One Laser Printer
MFC-7220 All-In-One Laser Printer: the back cover open message will not go away...
There is a paper jam in the machine which is blocking the sensor for the back cover.
Remoev the drum and toner (cartridge) from printer and look inside, there should be a piece of paper there, you need to remove it slowly
May 16, 2010 | Brother MFC-7220 All-In-One Laser Printer
I have an MFC-3240C which was showing "Ink Empty Yellow Replace Ink". No matter what I tried (including new brother yellow cartridge) the problem remained. I bought a second-hand MFC-620N. Hooked it up -...
You must be reset your ink cartridge by printer maintenance software.Or originally cartridge is damage.If you can not fix this problem.Please go to a service center in your area.
Dec 27, 2009 | Brother DCP-7030 Digital All-in-One Laser...
Brother MFC 7220 prints vertical line from top to
The photosensitive drum needs to be cleaned or replaced. If after cleaning it the vertical line continues, the printer may need maintenance.
Sep 17, 2009 | Brother MFC-7220 All-In-One Laser Printer
Not detecting ink cartridge - or saying empty - Brother MFC 240c
Is it an ORIGINAL BROTHER cartridge ? ?
OR
A cheaper version ? ?
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Replace ink toner message
Is it refill? if not then try leveling powder in cartridge by gently shaking, Take back as faulty, or reset new toner lever on left front of cartridge. Check toner is seated correctly in drum and drum seated correctly in machine.
Nov 08, 2007 | Brother MFC-7220 All-In-One Laser Printer
Mfc-7220 replaced starter cartridge, new Brother one gives error no cartridge
there is a new toner detect sensor left front upper inside of printer, when a new toner is put in reset lever on cart hits sensor then fall back to front of cart, remove gear asst and put lever in new position, 3/4 the way back. reinsert toner into drum and insert.
Nov 03, 2007 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC-7220 All-In-One Laser Printer Logo
196 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
