rror code 0201 on the HiTi C290 printer indicates a problem with the ribbon. Here are some steps to troubleshoot the issue:
Open the printer cover and remove the ribbon cassette.
Check the ribbon for any damage or wrinkles. If there is any damage, replace the ribbon with a new one.
Ensure that the ribbon is installed correctly in the cassette and that the cassette is inserted properly into the printer.
Check the ribbon sensor to ensure it is clean and free from any dirt or debris. You can clean the sensor using a soft cloth or cotton swab.
If the problem persists, try resetting the printer by turning it off, unplugging it from the power source for 5-10 minutes, and then plugging it back in and turning it on again.
If none of these steps work, contact HiTi customer support for further assistance.
The correction tape clips to the bottom of the ribbon, The ribbon has two small feet that hook into the front of the ribbon deck then just snap it into place the blue latch holds it in place.
A manual is available at LEXMARK>COM click on support.
Move the blue lever on the R. side of the ribbon to the rear and lift the ribbon out unsnap the correction tape from the bottom, reattach the correction tape to the new ribbon. Insert the the two small tabs on the rear of the ribbon into the slots in the ribbon deck and snap ribbon into place. For apicture go to lexmark.com, click your way to publications and you will find a manual.
The correction tape cartridge "piggybacks" under the ribbon cartridge. Flip your black ribbon over, line up the front dges of the two ribbons and gently press down on the correction ribbon 'till the two wing tabs at the top are attached to the slots at the top of the black ribbon. Be sure to take up any slack in the ribbons BEFORE re- installing.
The Ribbon can only be installed correctly as you have to lower a bar after to allow the printer to start if it was in incorrectly this arm would not lower and you would get no printing.
The correction tape which should be a yellow spool and the correction ribbon cartridge should be a yellow also, sometimes orange, first. The correction tape has to in front of the black correction ribbon. in othe words this is the order. Platen, paper, correction tape, correctable film ribbon, printwheel. Also make sure correction tape is dull side toward paper. Shinny side should face operator...
1 - Is the dailsy whell properly installed ? (Has the lever been pressed firmnly ?) is the correct daisy wheel installed?
2 - Have you run out of ribbon ?
3 - Have you pressed the 'spider web' key with + // keys after replacing cassette ribbon, correction tape or daisy wheel?
I have the instruction manual if that helps..
Pleas feel free to advise your email, and I will gladly forward :
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
