Question about Singer 2273 Mechanical Sewing Machine
How do adjust the timing? 2273 singer esteem 2. the take up leaver hits the cowling?
5 Suggested Answers
  • 3422 Answers
SOURCE: Singer 1120 timing
h,
Timing" is the alignment of the needle at its lowest point and the hook on the bobbin case. The point of the hook must pass directly behind the "scarf" of the needle fo the interlocking loop of a "single needle lockstitch" machine to occur. Look closely at the needle. You will see the long groove along the front of it. This is where the thread rides as the needle goes up and down. If you look at the back of the needle you will see a flattened area just above the point. This is the "scarf"; it's flattened to permit the hook of the bobbin case to run right by it and catch the loop.
When a machine is out of "time", the hook is either too early or too late, OR to far away from the scarf to make the connection. You can send a machine out of time by hitting a pin, or breaking a needle "hard" (too fast through too many layers, etc.). You can usually identify a machine that is out of time by multiple skipped stitches at high speeds, or by stitching fast and then quickly putting it into reverse. Sometimes, you can scrape by if you rotate the insertion of your needle a little bit, this can help compensate for minor timing issues.
Posted on Sep 07, 2008
bargainbox
  • 1388 Answers
SOURCE: singer 7426 timing off
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Posted on Aug 27, 2009
Testimonial: "very helpful...thank you"
  • 980 Answers
SOURCE: Where do I oil this machine?
You can only oil modern machines on the moving parts that you can see.
Posted on Jul 23, 2010
  • 980 Answers
SOURCE: what is the denim tension setting on the singer
Just adjust the tension so you ger a perfect stitch top and bottom
Posted on Aug 08, 2011
On singer esteem ii 2273 model. My problem is the hand spinner sticks only when the needle is all the way down.It doesnt get stuck juststicky slightly. I cantfigure out where at its sticking. Any idea
In order to solve your problem, you may have to take the machine apart. The gears may have to be looked at and oiled. I would oil every joint.
Apr 25, 2017 | Singer Sewing Machines
How can I get the handheld unstuck on my Singer Esteem 2273? I have lubricated the bobbin case.
could you explain more about the problem your having and may be some one can help you
May 09, 2016 | Singer Sewing Machines
Thread is bunching under fabric and I've rethreaded both the bobbin and the thread from the top multiple times.
Be sure your bobbin is inserted the correct way (this varies from machine to machine, so check the owner's manual). Bobbin tension is dependent upon this in most Singer machines.
Apr 03, 2015 | Singer Esteem II Sewing Machine - 2273
Singer Esteem II Model 2273 - Why is my Needle is always REVERSE mode !!
Ah... a plastic Singer. I'm sorry for you. It's likely something broke, take it in for repair.
Mar 19, 2013 | Singer Sewing Machines
I am looking for a free manual for a singer 2273 esteem II
Singer has the manuals for the 2273 on their support site: . The direct link to the English version of the manual for the 2273 is http://www.singerco.com/uploads/download/1181_2273.pdf . The oiling diagram is available separately: http://www.singerco.com/uploads/download/1235_oiling-2263.pdf . You will need Adobe Reader or a similar program to read the manual.
You can also buy the manual from Singer for $15. Many Singer sewing machine manuals are available here: http://www.singerco.com/accessories/instruction-manuals .
I hope this helps.
Jan 09, 2012 | Sewing Machines
What is the denim tension setting on the singer esteem 2?
Aug 07, 2011 | Singer Sewing Machines
How to set the settings for stitching zigzac on singer 2273 model
Go to www.singerco.com and download a copy of your manual for free under customer support, instruction manual and put 2273 in the box, it will tell you everything you need to know. You can save a copy on your computer plus enlarge the diagrams for easy viewing. Good luck
Dec 24, 2010 | Singer 2273 Mechanical Sewing Machine
I have a Singer Esteem II Sewing Machine model 2273. I ordered the ruffler foot 086742-P as listed on the website. I can get it to fit on the machine...i think...however when i lower the needle it hits...
Are there other needle positions on your machine that will allow the needle to pass without hitting? Otherwise, I suspect the accessory you have is not installed correctly or is not correct for your machine.
Jan 14, 2018 | Singer Sewing Machines
Jul 22, 2010 | Singer 2273 Mechanical Sewing Machine
Singer 2273 Mechanical Sewing Machine Logo
310 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
