Question about Polycom VoiceStation 300 (2200-17910-001) Wireless Audio Conference
My polycom is flashing and beeping even after being turned off and back on. wha't up?
    Scholar:
  • 146 Answers
It might be power supply they are common to go bad
try different one and see if that helps
Posted on Mar 31, 2011
Polycom voicestation 300
are you sure this feature is not blocked on your line? check with another phone connected to the same socket if you can dial the same numbers
Jul 30, 2014 | Polycom Lands Phones
Tv will not turn on green light comes on then flashing red light it wont turn on
Parents Sony flat screen did the Same thing. I pulled the plug on the back of the TV for a minute plugged back in wha la! Problem solved
Nov 19, 2013 | Philips Magnavox 27MS343S 27" TV
Message NO ID message followed by beep beep...
ACTUALLY MAY POLYCOM SOUND STSTION ARE NOT DAMMAGE WHEN I BUY IT.WHEN THE TYPOON IS COMING SINCE ONDOY.MY POLYCOM SOUND STSTION ARE WET COZ OF TYPOON. JUST TELL ME WHERE IS THE SERVICE CENTER OF POLYCOM
Jan 07, 2011 | Polycom SoundStation
How to reboot soundstation 2w polycom if you forgot the password
egistering Base Station on Polycom SoundStation 2W
Hold down 1,4 and 9 until green & red lights flash. Then hold down the page on the base station.
OR
You can register the base station to the console by:
1. press menu key
2. Select Admin Setup
3. Select Registration
4. You will see "Register with Base Station" in display. Press the Register softkey.
5. You will see "Power cycle base station then press ok". Unplug base and plug back in and press OK softkey.
6. You will see "Press and hold the paging button on the base for 10 seconds"
7. You will see Registering in the display on the console and then it should go to ready mode.
Mar 05, 2010 | Polycom SoundStation 2W (2200-07800-001)...
Error loading 0004f220429c.cfg
This means the phone cannot find its <mac>.cfg file on the boot server, and does not have one loaded in its own flash memory.
You will need to configure a boot server to host the SIP software, BootROM, and all the config files (these are included in with the SIP software).
You can download these from Polycom's product support page:
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Aug 18, 2009 | Polycom SoundPoint 330 IP Phone
Polycom VSX 7000 will not turn on
Hopefully the problem was resolved. Call Polycom to see if it under warranty. Call me at 415.659-8178 if it is not. Maybe I can help. David
Feb 17, 2009 | Polycom VSX 7000 Video Conference
Connecting a polycom
No, i don't think si. The polycom needs an ethernet connection to a router. You might get this working by putting the 3g card into a PC and enabling connection sharing, however even if you got it work itsd a bad solution in terms of:
- Cost
- Reliability
- Security.
ADSL would be better.
Jun 18, 2008 | Polycom ViewStation ISDN (pcy220011323001)...
Flash timing setting for polycom sound station
You need to update the flash timing on your Soundstation to match what is on your PBX.
Check out http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10964&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605 and http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=11208&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605
Jun 06, 2008 | Polycom SoundStation Premier EX Audio...
Conference call with a Polycom SoundStation EX
The conferencing capability to bridge 2 (or more) external stations comes from the telephone equipment/service that you have purchased. Either you are behind a PABX or Electronic KSU, which provides multiple phone service to your office, or you purchase conferencing capability from your local telephone provider (Verizon, AT&T, etc). In either case, the way to initiate a conference call would be the same as when you would have a desktop/office phone and establish a conference/bridged call to external parties. Usually this occurs by having one party on the line, flashing the disconnect button momentarily, getting a new dial tone, dialing and connecting to a second party, then flashing the disconnect button again, which signals the equipment to bridge those two calls to your station.  On the SoundStation EX there is a Flash button that provides that capability of momentarily flashing the disconnect button.  Try and see if that works. If not, then you will need to make arrangements to purchase the external equipment or service from your provider.  If you have the PABX or electronic KSU, it may also be a configuration option that you will need to have your support person for your telephone system, activate for that station connected to the SoundStation EX. Hope that helps.
Oct 22, 2007 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Unkown Beeping During Calls
It is hard to tell if this conference phone is installed on a PBX or not? "At meetings" tends to make me believe that it is. Beeping can come from a few sources. If a call is being recorded it is necessary to provide a beep tone so that the parties on the line know that they are being recorded. This is a FCC requirement. You can ask the other party if they are recording the call. Beeping can come from call waiting. It is recommended to turn call waiting off unless you are bridging incoming calls. If a call is on hold you will get a beeping tone. You can check by pressing the flash button and see if there is a second call. If so hangup and your original call should return normally.
Mar 21, 2007 | Polycom SoundStation 2W (2200-07800-001)...
Polycom VoiceStation 300 (2200-17910-001) Wireless Audio Conference Logo
256 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
Sandeep Kamat
Sandeep Kamat
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
