Question about Dishwashers
Need to know the discharge rate is? - Dishwashers
  • kdh3125 Mar 30, 2011
    I just need to know the rating of the washer. Jackson Mod # ES2000
  • Dishwashers Master
  • 2,605 Answers
Hi, Welcome to FixYa. Can you elaborate on the "rate" you're inquiring about, i.e. drain flow rate, fill rate, energy consumption etc ? Regards, Macmarkus :)
Posted on Mar 31, 2011
  • 4,323 Answers
Hi
Please elaborate your issue and post back with the manufacturers name and model no. for further assistance.
Daniel
Posted on Mar 30, 2011
I purchased a house that the pool filter was stolen and I purchased a used filter with a side mount valve. I need to know how to plumb itto my pool. there are 3 ports.
Thank you for posting your question here on Fixya.com.
If it is a Hayward valve like your post suggests there will be a word cast into the black plastic area near all three ports you need to connect. One will say pump, another return and the last one waste.
Pipe the pump port to the pumps discharge. Pipe the return to a heater if one is present or back to the pool. Pipe the waste to an area where you can safely discharge water as you backwash the filter.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Feb 04, 2011 | Hayward Pro Series Side Mount Sand Filter...
How to discharge capacitor?
Use a multimeter, connect the connectors to negative and positive sides and then it will discharge, just check online for the discharging rate to be set on the meter.
Thanks
Sep 21, 2010 | Car Audio & Video
I need the instruction manual for a Sears submersible pump model M4D02B-01. I would like to use it to pull water from a lake and about 25 feet in elevation. It is rated at 230 volts but I currently only...
Assuming that your Sears submersible pump Model
M4DO2B-01 can pump water at more than 25 feet
elevation. You can run it even without a manual. Just connect your discharge hose up to the point of discharge. Use a 220/110 volts transformer with a rating of at least 3KVA. Connect your 110 volt line to 110 outlet of the transformer and the submersible pump to 220 outlet of the transformer. This 3KVA transformer can handle up to 1HP pump.Send your
e-mail for further assistance.
Jul 07, 2009 | Plumbing
Battrey fast discharges
dear, there are two possible reasons of battery down.. 1st is that your battery is not ok and the other is your phone's charging IC is going to drain it.. so check the battery with other set or try with new battery in your phone.. regards, hope it will fix the issue so dont forget to rate it...
Jun 04, 2009 | Samsung Cell Phones
Error SC 411 appears
SC411: Separation bias error
-Definition- [B] A separation bias leak signal is detected. - Possible causes - · High voltage supply board defective · Poor connection of the PCU · Discharge brush defective You need the service manual or have a technician fix it. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 15, 2009 | Ricoh (R) Aficio CL3000 Color Laser...
New BN-V428U battery
BATTERY TIPS
Now a days in LITHIUM BATTERIES are used no memory effect
always charge battery for 16 hours when first use new
never keep ur battery fully discharged for long time when u store ur camera always keep it half charged or fully charged when storing for longer period
it is good to fully discharge once in a month but dont make it ur habit
pls rate me FIXYA for help
Apr 13, 2009 | JVC GR-D50 Mini DV Digital Camcorder
I would like to find info on the capacitors for my 27gal powermate air compressor
? should be printed on them careful as they bite when discharging if you need replacement try mastertoolrepair.com they have them
not sure on best way to discharge them hope this helps
Jan 18, 2009 | Coleman Powermate 27 Gallon Air Compressor
Fly back discharge
not sure what the device is called but there is a small probe you can get for discharging tvs etc,check maplin electronics or micro shack,
Jun 10, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Clothes washer
I could not find a definite answer for you, but I know that the wash tub holds roughly 35 gallons on a full load. You can calculate the time it takes the washer to completely empty a full load to see how long it takes. If it takes 1 minute for the wash tub to empty on a full load, then you know the GPM for the drain pump is about 35 gallons per minute. If it takes a minute and a half, the rate is about 23 gallons per minute. If it takes 2 minutes, then the rate drops to about 17.5 gallons per minute. Get the idea? I hope this gives you the information you were looking for. Let me know if you have any further questions.
Feb 20, 2008 | Kenmore 24032\24036 Top Load Washer
Dishwashers Logo
Top Dishwashers Experts
