Question about Philips 42PFL5332D 42 in. LCD Television
No sound when connected to cable box. - Philips 42PFL5332D 42 in. LCD Television
    Problem Solver:
  • 6 Answers
Are you using composite cables(red, yellow, white?) or the red, blue, green? you might have the red and white switched.
Posted on Mar 31, 2011
Precision TV - PTV2548 no sound when your watching cable but there is sound forvideo input
may be the source itself(i.e. cable box) also check cables between cable box & TV. If you are connecting the DVD to the same input the cable box is installed, You know that input on the TV is OK. If you get no audio when the DVD is connected to the same input as cable box, then issue is the MAIN PCB.
May 21, 2014 | Televison & Video
I have a 19 " sansul cant get my ilive sound bar
I hope this helps. You have to connect your sound bar to your cable box/satellite tv receiver. If you are connecting with composite or component cables you connect the video cables (either the yellow or the green blue and red cables) between the television and the cable box /satellite tv receiver. Then you connect the red and white audio portion of the cable between the cable box/satellite tv receiver and the sound bar. You are going from the OUTPUT of the cable box/satellite tv receiver to the INPUT on the television and sound bar. You use the function/source/input button on the sound bar to choose the space you plugged the cables into on it or listen to the radio or listen to your IPOD and etc.
Jun 10, 2011 | Sansui HDLCD-1900 19 in. LCD Television
How to connect a sabrent external tv tuner box
simply
1- vedio connection
connect the monitor data cable to the the external tv box and take the out data cable from external tv
connect to your pc
2- sound connection
take sound cable from tv sound out to line in pc ( don't forget to open line in , in the sound properties )
3- finally connect the the adaptor to the tv box and play all
best regards
if you see that is helpful plz dont forget to vote me
Apr 02, 2011 | Computers & Internet
I have the bd230 5.1 system hooked up the speakers, attached the power cord and hdmi cable from receiver to the tv what else do I need to get sound from my tv I have a hd cable.box do I need to run a cable...
The home theater box performs the production of the sound generation. Also, the theater box, distributes the sound to any display devices like TVs, Music MIxers, DVDR, VCRs, ext. The theater box also has connection ports that are recognisable as receptacle area from speakers, woofers, and twitters that combined to form the home theater of devices acquired. First, start by connecting the component parts of the theater system to the box. For example, speakers to an area on the box, twitters, woofers. At which point, the box would require a power cable to an electrican circuit to display functionality mode. The next step is deciding on which display reciver would be providing sound to the theater setup of blasters. For example, choosing to acquire sound from a TV set is achieved by connection cables that derived sound out of the TV to the theater box. E.G. The TV audio output area provides the connectivity of any external audio blasters like with the theater setup. Using the appropiate audio input output connection cables to acquire sound transfer matters. The device may not have been provided with a TV audio input out cable of connections. Acquire from retail input output cables from TV to theater boxes. Remember that, the theater box may have come with a remote control that require separe operations than the TV. The theater system theraafter would require power on buttons if any separate remote controls were acquired as well. Also, the television set would require alteration settings with the remote control. Adjusting the TV sound settings to acquire or direct internal sound to an external setup infrusture is possible explanation also achievable with TV REMOte controller soon after every wireing cables have been established alos powered on to source of current. GOOdluck
Jan 11, 2011 | Panasonic Home Theater System System
I HOOKED UP THE AUDIO CONNECTIONS FROM MY CABLE BOX TO THE BOSE RECEIVER. THE SOUND DOESN'T SOUND MUCH BETTER THAN MY TV SPEAKERS. WOULD USING A FIBER OPTIC CABLE MAKE MUCH DIFFERENCE?
You don't state how you have connected it but even with an analogue cable the sound should be better than your TV speakers, unless you have fantastic TV speakers, so something else is wrong however yes it should be better with as the full stereo surround signal is (if supported by your cable box) is transmitted digitally over the cable, so any analogue problems such as bad connections etc will be eliminated. I would not however buy a cable until you figure out whether there is a problem with your cable box or the Bose, do you have access to another source and connecting cable you could try first? Also go into the cable box menu and check if the sound out is correctly configured. Please rate my reply. Thanks
Jan 03, 2011 | Bose 3 2 1 GSX System
This may be an impossible problem to solve..we just got a Hitachi 51m200 rear projection tv. it does not have an hdmi slot although the tv says it is dvi-hdtv and our cable box is hdmi output. so if i get...
It isn't impossible at all. You may need a sound bar if you don't already have a Bose surround sound system or a boom box or something else you can use without purchasing anything. On the hdmi/dvi televisions and cable boxes of the recent past there would always be an accompanying white and red composite/RCA slot (output on the cable box, input on the television) to accommodate this. You would simply connect the hdmi to dvi cable from the television to the cable box and then the red and white audio cable. If your television and cable box does not have the red and white composite/RCA audio input and output you will need to connect the cable box to an external audio source. How to do it and what to connect it to depends on what audio output that is on the cable box (usually is on the back of it). You might need a fiber optic cable and a sound bar with a digital audio input if you have a newer cable box.
Sep 28, 2010 | Televison & Video
I want to hook up a higth def. cable box to asoround sound jvcTH-M505 with no hdmi,( the cable box does have it )and a samsung 46 in series 6 model 610 lcd. I can get soround sound from the movies from the...
There are a couple of different ways you can do this but this is the easiest.
Items needed - One set of RCA audio cables (Red/White)
1) On the back of your TV there should be RCA plugs marked as "Audio Out". Connect the RCA cable to these connections Red cable to Red connector and White cable to White connector.
2) Locate on the back of the surround sound system the connections marked "Audio in (VCR)". Connect the other end of the RCA cable to this connection Red cable to Red Connector and White cable to White connector.
Now to get the sound to play press the "VCR" button on the surround remote and you should get the cable box sound on the surround system.
Good Luck.....
Jan 19, 2010 | JVC TH-M505 System
Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Best picture and sound
connect coaxial cable connector from your cable service company to cable box-----in jack.
2-using coaxial cable connect cable box out to tv-vhf/uhf jack.
connect projection tv audio out (var-fix)jacks to avr 230 line in.
Aug 22, 2008 | Audio Players & Recorders
Philips 42PFL5332D 42 in. LCD Television Logo
16 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
