Question about Roper RAS8445KQ Top Load Washer
Roper ras7133pqo My machine will fill and nothing else. Is this an easy fix or should I look into getting a new washer? Thanks, Charlotte
  • 1 more comment
  • chanel08 Nov 04, 2008
    my washing machine fills and wont drain or go on wash cycle. i need help on how to fix this....
  • ahpi2746 Feb 03, 2009
    The washer will fill up with water. When it comes to the spin cycle the drum will not turn. Sounds like the gears are trying to engage? The water will drain ok.
  • sheilaseebec Mar 27, 2009
  • 126 Answers
IT DOESNT SOUND LIKE A EASY FIX.BEST YOU GET A EXPERT TO HAVE A LOOK AT THE APPLIANCE BEFORE YOU GO OUT AND OURCHASE A NEW ONE IT MIGHT BE A SMALL FAULT ON THE TIMER THAT CAN BE REPAIRED AT A CHEAPER PRICE.GOODLUCK. MOHAMED
Posted on Sep 12, 2008
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
I have a Roper Washer Model RTW4340SQD that
The lid switch is on the top left side of the top cover. If it is bad the machine will fill and stop. The lid switch must be good for the machine to agitate and spin.
Nov 01, 2009 | Roper RTW4300SQ Top Load Washer
Roper model RAS7133PQO everyting works except it
Gee it could be anything from something in the pump to a bad main transmission gear. Here is some repair pictures and a few good manuals
Sep 09, 2009 | Roper Washing Machines
Roper washing model number ras7133pqo leaking
lean it back look st the pump if water on it take it off 2 clips hold it on and check seal looks bad? ...replace thumbs up
VE6GAR 73 88 99
Aug 10, 2009 | Roper RAS8445KQ Top Load Washer
Roper washer fills with water continuously
Your inlet valve is defective, can be easily changed. Approach your dealer with your model number he will direct you to the spares shop, or tell you where you can get it. Or google 'roper washing machine spares'
Feb 23, 2009 | Roper RAS8445KQ Top Load Washer
Roper model #RAS7133pqo
I'm having the same problem. The noise we hear is the water pump, does your washer have a belt?
Please forward to me any tips you may get, I'll do same
Lew
Feb 03, 2009 | Roper RAS8445KQ Top Load Washer
Model RAS7133pqo
If it agitates, you probably need a new gearcase. If not, check the coupling between the gearcase and motor. Hope this helps!
I have a Roper brand top loader washer and it fills up but it won't drain or spin.
If the motor doesnt run during the spin cycle and the tub stays full of water. You need to replace the lid switch. This is very common problem. The part should be around 35 bucks. Easy fix.
Jan 30, 2009 | Roper RAK2751WWH Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
148 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
