Question about NetMedia iViewHD 2M SurveillanceNetwork Camera Color CMOS Cable
I have a number of netmedia IviewHD-2M cameras that have the same problem as their D! version. The lower the ambient light gos (200 Lumens and lower) the cameras connectivity is lost or locks up. I have tried it with 5 different Software capture Apps. , Same problem. (FPS varies between 3FPS and 10FPS) I have upgraded the cameras with the software from them, Same problem. I have tried different Platforms, Win 7, XP and MAC 10.2 to no avail.!!!!!!!!!!!!!!!!!!!! Help R. Czomba Instant Replay Co.
  • 11,800 Answers
This camera is not designed to work in really dark environments : when the ambient light goes below a threshold the camera simply goes in stand-by - shuts down. 200 lumens is not the best threshold for that, but it's something to be expected from an strictly indoor camera like it.
All you can do is to make sure you have selected the Best for Night setting, the White Balance is set to Cloudy and the Exposure is set to the max , at +2.0EV.
Posted on Mar 30, 2011
Technical data
lumens is a measure of light intensity
the lower the number the duller the light, the higher the number the brighter the light average shops have a level of limens around 750 as this is the safe light level for eyes
Wattage is current flow ( amps) and was used as a measure to show the intensity of the light
12 watt bulb is dull in 240 volts situation where a 500 watt bulb as in ( quartz halogen bulbs) is something that will blind you
You will notice a change in readings from incandescent bulbs-- the old units that had a filament in them--20 watt, 40 watt,60 watt, 100 watt to fluorescent lighting where the power saver bulbs have a rating of 12 watts is equal to 60 watts of the old bulb ( a rough attempt to show the lumens ratings )
this was an attempt to compare the light intensity so that customers could see how bright the new bulb would be
Now that there are LCD units , the wattage is so low that a comparison cannot be made so the shift is to lumens as a measure of light intensity ---in reality the results are the same
for example a torch with 3 X aaa batteries as a low lumen rating as you can see by the brightness of the light and if you compare that with the lumens rating of driving lights that light up the road for miles
the wattage(amps)for the big lumens rated lights will still be low compared to the head light s in current use
Mar 10, 2016 | Televison & Video
When my E2d. Ed defender. 200 lumens flash light is turn on it act like an strob light how to stop it or is it a weak batteries
No, that is a 'feature'. It is for signalling or blinding an attacker.
This is the instructions for the 500 lumen version but it will be the same. Nice light, I run Fenix Tactical. Strobe is usually gained by switching on and then half depressing the button and holding. If this doesn't work, contact Surefire direct.
The E2D LED Defender® Ultra is a compact 500-lumen flashlight featuring dual-output capability and self-defense enhancements. Utilizing a virtually indestructible high-performance LED and a Total Internal Reflection (TIR) lens, the E2DL Ultra is activated with a pushbutton tailcap click switch that also selects output levels: press or click once for a high-intensity 500-lumen white-light beam-ten times the light needed to overwhelm the night-adapted vision of an aggressor. Return to off and press or click again within two seconds for a 5-lumen ultra-long runtime low beam that's suitable for navigating at night or performing close-up tasks for hours. The Defender's crenellated Strike Bezel® provides further defensive options should the need arise. Slender and powerful, the E2DL Ultra is an ideal everyday-carry light.
Jan 08, 2016 | Surefire E2D LED Defender Flashlight Max-...
There are some white dots on the projection
The DLP chip of the projector has gone bad, which require to be replaced.
Aug 17, 2015 | LG HS200 SVGA 200 lumens LED Projector;...
Mitsubishi xd520u projector has white dots
http://youtu.be/V_uUH-xHKkU
It will need a new dmd chip 200-500$ here is a video of a similar model. You would need to verify the chip number.
Jun 27, 2012 | Mitsubishi XD520U DLP Proj XGA 2000:1 3000...
What numbers on camera screens corner that's f3.0 1/30 ISO 200
f3.0 is the size of the lens opening. The larger the number, the smaller the opening.1/30 is the shutter speed.ISO 200 is the sensitivity speed of the sensor. The higher the number, the less light you need for a good picture. For example, 400 is twice as fast as 200...800 is 4 times faster, etc.
Nov 13, 2011 | General Electric W1200 Digital Camera
Proxima DT 5800 works but picture is much brighter with the lights out ,what could cause to be not as bright with lights on?
The Proxima DP5800 projector is a small format low powered projector at only 650 lumens (brightness measurement). It simply doesn't have enough lumens to cut through ambient light and display a clean image. It is best used in a dark room.
Also bulb age will play a factor in overall brightness. The lamps for that projector are only rated for 700 hours, and as they near the life expectancy they can lose up to 50% of their lumens.
Mar 09, 2011 | Office Equipment & Supplies
How can I use Metz 45 CL-1 with Nikon D3000 and what should be my setting on Flash and on Camera
First you need a hotshoe adapter to connect flash Sync cable to camera. You have to pay your attention about the following settings. Set the same ISO speed on flash gun and camera.( 100 or 200) White balance to Auto or Flash on camera. Mode dial to M (manual) and shutter speed to 1/200 or slower on camera. Aperture setting to 5.6 or 8 (both on camera and on flash) Now take some trial photos and check on the LCD display and histogram and do fine tuning to your exposure. Change the aperture value on camera to control the exposure of flash as well as the ambient light Change the shutter speed to control the exposure of ambient light. (!/200 or slower speed) I hope you got the solution to your problem. I also have the same set of equipments to do my photography.
H.D.Shirantha.
Sep 10, 2010 | Metz 45 CL-1 Flash
My olympus stylus 770 SW digital camera pictures during day time are so bright..what should i do?
Lower the ISO sensitivity to around 200 or 400.
That's like film speed... the lower the ISO the less sensitive it is to light.
[Menu]
[Sensitivity]
(down arrow) to 200 or 400...
What is is set on? 3200??
Sep 30, 2009 | Olympus Stylus 770 SW Digital Camera
NEED TO CHANGE PHOTO RESOLUTION
■ Number of pixels
Select a higher number of pixels for clearer
pictures when printing.
Select a lower number of pixels [ ] (0.3M
EZ) to store more pictures. Fewer pixels also
means it is easier to send pictures by e-mail
or use them on a homepage.
■ When the aspect ratio setting is
[h]
DMC-LS75/DMC-LS70
(7M)
3072 × 2304 pixels
DMC-LS60 only
(6M)
2816 × 2112 pixels
DMC-LS75/DMC-LS70
(5M EZ)
2560 × 1920 pixels
(3M EZ) 2048 × 1536 pixels
(2M EZ) 1600 × 1200 pixels
(1M EZ) 1280 × 960 pixels
(0.3M EZ) 640 × 480 pixels
on the menu I believe the Panasonic calls it aspect ratio
Mar 06, 2008 | Panasonic Lumix DMC-LS75 Digital Camera
NetMedia iViewHD 2M SurveillanceNetwork Camera Color CMOS Cable Logo
21 people viewed this question
Top Netmedia Home Security Experts
Lawrence Oravetz
Are you a Netmedia Home Security Expert? Answer questions, earn points and help others
