Question about RCA Televison & Video
I have an older model rca universal remote #xx15212-33 How do I program it? It has no indicator lights or code buttons.
josh1856
  • 105 Answers
SOURCE: Need programming codes
try this...
http://wiki.answers.com/Q/How_do_you_use_an_RCA_d770_to_program_your_DVD_player
hope that helps.
Posted on Jan 28, 2008
SOURCE: code numbers to set up iLo tv
Checked on line for any code there was that someone used for iLo t.v.'s, found two codes on your site that someone had used & used those & one of them worked. Thanks again!
Posted on Apr 02, 2008
Highdefjeff
  • 124 Answers
Remote code for ilo: 1286
Posted on Apr 08, 2008
  • 21 Answers
SOURCE: Programing Code for RCA Universal Remote Control
It does not have any code.
Posted on Oct 22, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Directv Tivo recorder no remote programming code for Visio 37''
If it were a Tivo series 3 you might have better luck with it.
http://www.tivo.com/setupandsupport/technicalsupport/compatibilityhelp/Using_the_Learning_Feature_of_the_TiVo_Glo_or_Series3_Remote.html
I've had my series 2 Tivo for about 2 1/2 years and never found the correct codes for it. I think it works off of a list of TVs manufactures about 3 years ago.
Posted on Nov 22, 2008
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
What to use a rca universal remote butdont know the code
3 Ways to Program an RCA Universal Remote - wikiHow
wikiHowJump to Remotes Without "Code Search" Button - Using Brand Code Search ... (for example, many stereos don't support remotes). ... in this article to program the remote,but ... If you know the exact code that you need ...
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a "code ...Don't let go of the TV button. ... Please tell us everything you know about.
Programming the RCA RCRN04GR Universal Remote
Dec 25, 2015 | RCA Televison & Video
What to use a rca universal remote but i dont know the code
2 Easy Ways to Program an RCA Universal Remote Us
How do I program a universal remote to an RCA Model L32HD31R
This is the general setup proceedings to a universal remote control.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the dropdown list by the 'Sidebar' of the display window. It will make search easy.
Mar 12, 2013 | RCA Televison & Video
How to program older universal remote for tv
Direct Code Entry
May 05, 2012 | RCA Universal Remote Control
I have a universal remote systemlink 3 RCA. I need the code to program it. I have Goldstar TV. Thanks.
1.Use one of the following three digit codes for your TV set:
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, or 1722. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV. set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
8. If none of the codes work, you will want to use the following to go through the codes manually (this will take some time):
Code Search for the right TV code on a Universal Remote (systemlink 3 RCA)
1. Turn on the TV.
2. Press and hold the CODE SEARCH button until the indicator light lights. Then release the CODE SEARCH button.
3. Press and release TV button. The indicator light will blink once.
4. Repeatdly press and release the OFF/ON button until the TV turns off. It may be necessary to press the OFF/ON button up to 200 times before the TV turns off.
5. When the TV turns off, press the ENTER button. Now the Device is programmed for the TV set.
Aug 05, 2011 | RCA 3-dev Universal Remote Remote Control
What is the code to use for universal remotes
i found that your brand is not RCA universal remote code list..
if your are using RCA controller follow the steps below
1. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE
SEARCH.
2. Press and release the device button for the device’s code you are retrieving (TV,VCR or
DBS•CABLE). The INDICATOR LIGHT will blink once then remain lit.
Note: For AUX, press DVD•AUX
then the device button for the
code you are retrieving.
3. Press and release CODE SEARCH. The INDICATOR LIGHT will turn off.
4. Starting with 0 on the keypad, press the number buttons in order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the INDICATOR LIGHT to blink is the first digit of your code.
6. Repeat step 4 until you have retrieved all three numbers in code
if you are not having RCA controller or the method above is not works then buy new GE universal remote
solution using GE controller
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
i hope this will work
regards,
cseian
May 01, 2010 | Vivitek V37655 56" DLP TV
Lost remote control. have universal RCA and
i found that your brand is not listed RCA code list,
your G&E remote is good one and easy to detect code for your tv.
solution
using your GE remote :
1. Turn on the device(TV) you wish to program.
3. Press and release the device(TV) button for the device you are programming . The INDICATOR LIGHT will
using your RCA controller:
SEARCH.
i hope this will solve your problem
regards,
cseian
Apr 22, 2010 | Durabrand DWT2704 TV
RCA Universal Remote Programming Instructions RC800L-C 1239
if u do not have the code most universal remotes will allow you do it manually and you will have to follow these steps and insted of putting the code you can turn the tv on then press the on/off button on the remote till the tv shuts off then press enter
Aug 21, 2009 | Technics SA-EX140 Receiver
Old RCA Universal Remote
The remote model number is CRK93J1
you can download the manual at:
http://www.replacementremotes.com/store/downloadpdf.cfm?productid=55977
May 26, 2007 | RCA Universal Remote Control
Televison & Video Logo
120 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
