Question about Acer (56.04145.901) (5604145901) Power Supply
Not charging regularly from power cord - Acer (56.04145.901) (5604145901) Power Supply
    Problem Solver:
  • 11 Answers
Do you have to hold the charger in with force for it to charge properly? if so then it means the hole that you insert the charger in has become damaged, this is common with acer machines unfortunatly, you will have to have it repaired, but it should only cost a maximum of £5, however you should check that the charger works properly with another machine, perhaps a friend could help you out, that way you know it definantly is the charge port
Posted on Mar 30, 2011
Testimonial: "absolutely correct actually made a manual adjustment and so far it is working "
My Canon SX120 suddenly stopped working after about ten months of regular use. I was uploading abpout 50 photos and ten videos to Picasa as usual and even freshly charged battteris do not work now. It...
Ten months ur camera still under warrenty,call and talk to the Canon customer services.Ten months the camera litum battery should not have ben in trouble already,could be the transformer or the power A/C cord adaptor itself it is not functions properly for the battery to be charging or it could be damages to the A/c power cord itself than it is not taking in the A/C power juices to charges the litium battery.Litium Ion battery last at least a 1 1/2 or 2 years by of 8 hrs of charging and able to used the equipments for the battery juices like 2 1/2 to 3 hrs of battery power to be used.
Oct 28, 2011 | Canon PowerShot SX120 IS Digital Camera
Have a Sunrise Aspire chair w/new batterie, charged by the repairman. Want to keep it charged regularly (not let it run down). DO I NEED TO TOTALLY DISCONNECT THE POWER HOOKUPS IN THE BACK when I...
You do not need to unplug the large 9 pin beau plug in the rear or the smaller 3 pin molex plug when you charge the chair. Do not unplug them or you will not charge the chair.
Use your charging cord as you describe "plug it into the front, plug it into the wall and charge, then unplug the charger cord and GO". Hope this helps.
Jan 05, 2011 | Quickie Wheelchairs Quickie Aspire Power...
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
How to charge ups for pc's
Your PC connection must always come via UPS, and your UPS will always keep charging.
UPS Power cable should be connected to DC, and your PC power cable should be connected to UPS.
And this way your PC will always be safe.
Nov 06, 2009 | QVS NetStar (UPS650A) UPS System
My eee pc 4G surf won't turn on. It started having problems when the power cord was bumped - causing it to immediately shut down. Then it just stopped booting all together. I replaced the power cord and...
Most likely, either the power jack inside the machine (jack itself or solder joints) or the plug on the power cord was damaged; obviously the plug is only a few dollars to replace, the jack also only a few dollars, but much more labor intensive. My experience tells me it's probably the power jack. If you have any way to externally charge your battery and, using it, find the machine operational, that pins it down pretty well. When the external supply is used, the internal battery is supposed to be switched out of the load circuit and into charging mode.
Aug 06, 2009 | ASUS Eee 4G Notebook
My MPC t2300 laptop wom't turn on.
The Transport T2300 has an internal battery that will run the laptop for several minutes after the main battery goes dead. This feature allows you to save your work and shut down safely. If you run the laptop until both batteries are dead, even a brand new battery can't start the unit again. You have to follow this procedure:
1.Unplug power cord
2. Remove any attached periphal components including the cd rom and/or floppy disk module if you have one. Both remove with a push button switch located on the bottom of the unit.
3. Plug in power cord and charge the unit for a minimum of 24 hours straight. 30 hours is better. This whole time will be spent slowly recharging the internal back up battery.
4. Once that is done, unplug power cord again and reinstall any floppy/cd drives. Plug power cord back in now and charge for at least 24 hours again.
If your backup battery is dead, you can't charge the main battery or turn the unit on. The longer you charge, the better. We had one unit here that had to be on the initial battery backup for 72 hours before it finally took hold. Then, one overnight recharge on the regular battery and all was well.
If you need drivers or manuals for the 2300, all are available on cd at mpcsupport@cox.net for around $9.50 including shipping, handling, and owners manual
Apr 11, 2009 | MPC Computers TransPort T2300 Notebook
Computers & Internet Logo
327 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
