Question about Chicago Pneumatic CP772H - 6 3/4" Heavy Duty Air Impact Wrench
Spins fine free.when coupled to bolt there's no hammer action.just stalls. Thanks
    Problem Solver:
  • 9 Answers
Sometimes on most impact wrenches, the air motor drive gear cracks off inside where it couples to the impact mechonisum, causes it (air motor) to spin off center and drag. if this is the case you need an air motor. clean it thoroughly before the final re build. use alot of air tool oil, and grease the impact driver anvels
Posted on Oct 28, 2012
    President:
  • Chicago Pneu... Master
  • 1,388 Answers
If debris has been entering tool over time, the vaines will not make good contact to cyl. wall. Flush out gun with kerosine or diesel fuel to clean interior of the gun. If dirty, the first flush will be very dark and every flush after that will become more clear. After good cleaning/flush, add tool oil and retest tool. If tool begins to hit but not full power, you may have to open tool and remove scratches from the vaines. Make sure that you use the largest quick connect fitting possible. Sometimes the tool will loose power if you are using 1/4 inch connections and the vanes are not in good shape. Good luck
Posted on Mar 30, 2011
When hammer or hammer drill action is selected hammer action is not working
The ring of the impact bolt in front inside the locking sleeve where the chisel is driven on can be blocked (also broken part ) but not to see until you remove the parts .
Jan 11, 2016 | Hammer Drills
How to fix Hammer drill which does not "hammer" in Hammer mode, but rotates normally in rotary but NO hammer action in this mode also?
then the broken hammerpiston or the impact bolt ring in front of the locking sleeve can be broken
Oct 22, 2015 | Rotary Drills
I'M wondering if I should bolt the pully back on and hold it with a strap wrench, then turn that big coupling nut off.I allready have belt off.
If you're referring to removing the fan/fan clutch. Put the bolts in the pulley back in, put the belt back on. Get a long chisel and give the nut one good shot with a hammer. (it's reverse thread) And then spin it off.
Dec 16, 2010 | 2001 Chevrolet S-10
+whirlpool LSQ8243HQ0 water valve works. wont wash or spin. new motor coupling and timer.
Under the agitator you have what is called (agitating dogs). The agitator will have to be removed. The top should spin off, you will be able to look down into the agitator and see a bolt. Remove this bolt and the agitator can be pulled out. The agitators are small pieces of plastic with small teeth. These teeth get worn out over time or if the washer is overloaded. When the agitator free spins one way the teeth grab a (gear) on agitator and this is how you get the washing action (agitating). These dogs are easy to replace and cost about $5. If you need more info check out *how to replace agitating dogs)
Dec 15, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Demolition tool or breaker
The shaft from the motor to the drive gear is likely not working the action of the hammer. There is a gear which spins the gears to achieve the hammer action, suspect the gear is either stripped, broken or both.
Jan 17, 2010 | Dewalt D25330K 2KG Sds Plus Demolition...
How do the rear drums come apart
I am guessing that you need to know how the drums come off. Befor you can get the drums off you need to check a couple of things. Check the automatic adjuster inside the drum it can usually be accessed through the backing plate. Make sure that it is run in the dirrection thet will move the brake shoes closser together causing them to make less connection with the drum. Then look for any drum locks on the lug bolts.
Dec 19, 2009 | 1992 Ford Bronco
Washer won't agitate or spin. inglis il42000 can here motor running but no spin or agitating
You have a broken motor/trans coupling . Have to remove the case (not the back panel !) , pump , motor , and lastly , the coupling .Hammer new coupling on both motor and trans (hammer easily ) and reasemble .
Jul 10, 2009 | Washing Machines
SPEED QUEEN TOP LOAD WASHER HA4011W. Motor trips at SPIN start
I would call whoever repaired the washer back out and have them diagnose.
Jan 23, 2009 | Speed Queen AWS52NW Top Load Washer
Kenmore 60 series 110 model wont agitate or spin,hear motor
Likely the drive belt/coupling or transmission has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Chicago Pneumatic CP772H - 6 3/4" Heavy Duty Air Impact Wrench Logo
331 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
