Question about Sony PlayStation 2 (PS2) Console
PS2 slim, Bad Power switch is there a bypass to turn the unit on ?
I opened up my slim ps2 to clean the lens and I tore the ribbon...Next the the small white piece came off that utilizes the on/off switch. I tried to solder it back on, but no success...So now I have a PS2 with no way to turn it on.
I've got her opened and 8 pins are exposed where the ribbon went in..I've tried to use a small screw driver to make them connect, but I can't get her to power up....
Is there anyway around the power switch on the motherboard to get the unit running ?
Thanks in advance....
Gary
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
Ouch you got good news and bad..
Bad first. Your PS2 will not work without that ........
But The Good news im sure you might know somebody that has a junk ps2 if you can get your hands on it there is your fix... Sadly Sony wont send you one . try turning the cable around and useing the good end.. ill shoot you a vid that might help
Posted on Nov 19, 2008
  • Anthony Armstrong
    Anthony Armstrong Nov 20, 2008
    i just opend a ps2 slim ..found some little tricks im going to make a vid the other vid i posted is for the large case types
Model 50001 fat ps2 cleaned the lens adjusted the arm...
If your lens is not moving up and down the track at all even in bootup then sounds like your motor is fried. What i'm referring to is this:
You can find similar parts like this .::HERE::.
To verify this, open your dvdrom tray. Power off the PS2 via the swtich on the back of the PS2 (thus leaving the dvdrom tray open) Tare down your PS2 and remove the four screws on the top of your DVD-ROM unit (if this is a fat model, if it's a slimline model you'll have to remove that whole platic piece covering the unit itself) You may have to do some research on this next part (via google) but remove your DVD-ROM tray so you can see the guts of the DVD-ROM. Then power on your PS2. And ask yourself the following questions as you observe.
1.) Does the lens move at all even right after bootup?
2.) Is the siver bar part of the motor(pictured above) turning at all to make it move?
If it doesn't turn at all then there is your problem. If it does turn, and the lens doesn't move at all then the ribbon cable that connects the lens to the board maybe damaged or the lens itself is damaged.
Hope that helps
9x|
Nov 08, 2008 | Sony PlayStation 2 (PS2) Console
Disc wont work
Hi AdalVI,
Your PS2 probably has a dirty laser lens. Below is a procedure for cleaning the lens on the big PS2. It does not work on the Slim PS2. Do not ever use alcohol on a slim PS2 laser lens.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you have trouble you can send your PS2 to a Repair shop. Click on "Repair Directory" at the bottom of this screen. then choose "Video Game Consoles". Then you pick a Good Repair shop. My shop is listed, but I cannot divulge the name in this forum. Cost will be $25 plus shipping. Shipping is usually $8.95 to the USA
Dec 04, 2007 | Sony PlayStation 2 (PS2) Console
Playstatiion 2 repair
Hi Jaybs,
The disc will not spin if the laser canot read the disc. you may have a dead laser or bad ribbon cable that runs from the Laser to the motherboard. I am posting a procedure to clean the lasers lens. I hope you do not have the Slim model, as this procedure is for the older Big size PS2. You do not use Alcohol on the lens of a Slim PS2 ,it tends to haze over the lens.
Dec 02, 2007 | Sony PlayStation 2 (PS2) Console
Won't read disc.
Hi Crashley41 and Von281,
Since you have the bid Phat mode; you will have better luck at fixing your PS2.
This is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
If you still have trouble reading discs. Click on " Repair Directory" at the bottom of this screen. Then on the next page click on "Video Game Consoles". Pick a Repair shop to get your PS2 repaired. Fixya has some good ones dedicated to Playstations.
Nov 23, 2007 | Sony PlayStation 2 Slimline Console
Sony PS2
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Nov 07, 2007 | Sony PlayStation 2 (PS2) Console
Disk reading error
Hi Tyrell,
What kind of disc is it? The PS2 can sometimes have a dirty lens and not read discs. It does not matter if the Disc is new and unscratched.
  4. REmove the Warranty sticker to the right edge of the power socket.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  10. REmove the little white disc from the Cd tray lid.
  13. Put it back together, and your in business.
Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
My PS2 will not play PS2 games, but it will play PS1 games
Hi
If it will play DVD's this is a good sign. You will only need to clean the lens of the laser. Also clean the hub that the Disc rides on.
PS2 Read Error
Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Nov 01, 2007 | Sony PlayStation 2 Slimline Console
PS2 Wont Play
Oct 30, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
1,041 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
