Question about Samsung HT-TZ312 Theater System
Machine shuts down. - Samsung HT-TZ312 Theater System
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 30, 2011
When the screen is white instead of taking out the battery and putting it back in can I do something else?
Not sure why your removing the battery?
If you are shuting down the machine. Close all running programs before shuting down otherwise the machine has to close each program in turn before thr machine can shut down all together. Depending on how the settings are for the power button. The shut down process can be forced by holding down the power button until the machine has shut down. Black screen instead of white. Hope this helps answer your question.
Regards
Bob from OZ
Jun 15, 2015 | ProntoTec ntoTec 7 Inch Android Tablet Pc,...
WHEN WE PUSH THE BREW BUTTON ON THE SAECO VENUS COFFEE MAKER IT JUST SHUTS OFF AFTER A FEW SECONDS
The machine shut down usually when ther is a problem with the load to the grup moter.This is usually a board problem.You can check if the machine shut down when the grup is trying to move.
Apr 16, 2014 | Saeco Odea Go
LG wm1832CW Front load washer , error code OE and shut down, drain cleaned pump ok, ?
Yes, could be that the pump has dropped down on the efficiency.
check this link for tips to reset or rework the pump
Click on Pump
Jan 15, 2013 | Washing Machines
My Nextbook shut down and won't come back on
If the temperature is hot in your place then the PC Laptop may shut down due to overheated system.The machine automatically shuts down to prevent any internal damage. However in some cases you can prevent the shut down if you can control the speed of the CPU fan which can be done by the following software called "Speed Fan 4.42".
Download it from here.
http://www.almico.com/sfdownload.php
If the weather is not hot around you and the system still shuts down then at least cleaning service is required from a good repair shop or a tech. There must be a lot of dust and the ventilation system might be choking with dust and unwanted atmospheric objects so proper air flow can be maintained in the machine.
Good Luck!
Jan 14, 2011 | Computers & Internet
I just opened my laptop to use it and it is froze up on me and will not shut off
to shut down press and hold the start button until the machine shuts down, can take up to 10 seconds for the machine to shut down. If this does not work remove the power lead and drop the battery out of the system. You access the battery from underneath - there will be a slider you need to push to eject the battery.
Dec 18, 2010 | ASUS Computers & Internet
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
Shuts down during warm up
the fuser unit is not warming up, so the machine shut down
Mar 21, 2009 | Xerox Office Equipment & Supplies
Machine just shut down and will not light back up.
It sounds the like DC Power supply has failed. Recheck the on/off switch on the side if the machine.
Jan 20, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
E-machine computer will not shut down
When you say "it will not shut down", are you referring to clicking on start and then shut down?
You could try forcing a shut down by holding the power switch down for about 5 seconds.
Jan 18, 2009 | E-Machines eMachines Desktop PC
Samsung HT-TZ312 Theater System Logo
60 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
