Question about Dell 1704FPVt 17" TFT LCD Flat Panel Monitor
Broken power button board (under bezel) need a replacement board/cable
Need part. Dell does not stock it.
    Champion:
  • 232 Answers
CHECK WITH SOME COMPUTER RECYCLE PROGRAMS
Posted on Aug 04, 2008
SOURCE:
No LCD Display on Dell Vostro 1700 - 17"
It sounds like you have been pretty thorough trying to resolve the lcd problem
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 13, 2012 | Dell Vostro 1700 Notebook
Dell unstick power button on PC desktop
It sounds like either the push button assembly is broken on the front bezel cover, or the power switch is broken. Follow these steps to take the covers off.
Front Bezel: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/bezel.htm#wp1181855
Side access cover: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/cover_re.htm#wp1193123
Now look for either a broken piece on the bezel push button assembly or a broken power switch inside the computer case.
Dec 02, 2012 | Dell Inspiron 620 ST Desktop Computer...
How to replace keyboard dell 1558
Relativily easy, Pry out the black bezel that surrond that keyboard pad. Open the Lcd screen all the way, slide your finger between the gap where the dell logo on the screen and the front of the bezel on the laptop. There is a slight gap there and you want to tryint to power that open. Then slowly pry and pop the connection around the bezel until the bezel come off. You will see 3 screws that hold the keyboard that located on top of the keyboard, unscrew those and then slowly lift the keyboard up from top to bottom. There is a cable connection under the keypad and you want to disconnect this cable by lifting the flap that hold the end of the cable on the mothboard. Then after that, take your keyboard out and replace with the new one and install the cable and close the flap, Installation is the reversal. Hope this help. there are also youtube video of this if you want a visual of it, maybe not the same model but close.
Jan 13, 2011 | Dell Studio 1558 Notebook
I have a Dell Inspiron 2200 and need to replace the motherboard....how do i disassemble the laptop to get to the system board?
if you are now a computer technician, it is advisable to take your laptop to one to avoid demage of some components. Anyway, carefully open the laptop disconnecting the screen, remove your key pad and unskoll the motherboard to be replace. replace and carefully transfer component ensuring none is demage
Sep 28, 2010 | Dell Inspiron 2200 Notebook
Dell Dimension B110 will not power on when front button is pushed. Plugged it into another outlet without using power strip....still didn't start...purchased New power supply and installed still nothing...
check the bezel/power button
try to open the tower but you have to make sure that its unplugged/ after unplugging the power cable press the power button for about 5 secs to drain the flea power then check the power button maybe its broken or the cable connected to the power button to the main board is damaged or loose.
Sep 03, 2010 | Dell Dimension™ B110 PC Desktop
How do you open the case of a E153FPc Dell monitor? I need to get at the electronics to try to fix a ''screen going blank after a few seconds'' problem.
Hello
Under the the pedestal mount there are four screws. Once you've removed all the screws and the attached devices and cable (most importantly the power cable must be removed). Now you'll need a couple of flat diddle sticks (Radio Shack). Use these under the front bezel in between the the plastic front bezel and the metal rim of the internal screen. You'll actually be prying these two apart until the front plastic bezel snaps away from the rear plastic container. This won't happen if there are any screws left in it. Once you have all the plastic off, it's time to put on your anti static wrist strap and open up the metal containers.
Jul 29, 2009 | Dell Computers & Internet
The green plastic harness that supports the power button on the front bezel of the Dell Optiplex 170L is broken. I am looking for several of these parts so that we can repair in our office.
Unfortunately the only way to get a replacement bezel for a Dell desktop is to contact technical support. If I remember correctly the cost is about 30 bucks for the kit unless youre under the service warranty still than it is free. Don't quote me on the price I'm going off of memory from about 2 years ago when I worked there so the price may have changed.
Jul 15, 2009 | Dell Computers & Internet
How to disassemble monitor Dell 1800fp ?
Remove the base by the button release or 4 screws on the back. On the bottom of the monitor near the corners you will find two thin slots where you can insert a thin wide blade screwdriver or pry tool. Very gently pry the back from the bezel toward the center from both of these slots until the bottom is seperated, then contilue from the slots around the corners and up the sides until you have seperated the entire back from the bezel. Lay the monitor on the bezel and remove the back ( do not try to remove the bezel, at least not yet). Lift the tape that secures the ribbon cable from the bezel buttons to the logic board. Unplug the ribbon cable from the logic board by pulling on the connector (not the cable). Remove the cable covers from the back of the case (one has a screw, the other has a lift tab) and disconnect the lamp connectors and ribbon cable connectors (do not pull on the wires). remove four screws and lift the metal back from the screen.
May 15, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Trouble Turning on my labtop
The power button is simply a push stick to the circuit board underneath. Remove the bezel by prising it up on the right hand side. You can then press the button underneath to determine if the problem is with the bezel or the circuit board. Usually the problem is that the bezel button is broken or has lost is springyness. A new bezel can be purchased on Ebay for around £5.
Jan 11, 2009 | Dell Latitude D610 Notebook
Dell Monitor 152FPC POWER BUT DIMMED SCREEN
connection could be loose ,loose pin on pinout plug, dirty connection,broken wire in cord,make sure connection is tight,bad ground in plug or wire
Sep 06, 2007 | Dell E152FP 15" Flat Panel LCD Monitor
Open Questions:
SBCglobal MAil TecH SuPPoRt %%%{1=855=536=5666}#[email protected]@# TOLL FREE This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 22, 2019 | AOL Computers & Internet
See all Dell 1704FPVt 17" TFT LCD Flat Panel Monitor Questions
Dell 1704FPVt 17" TFT LCD Flat Panel Monitor Logo
183 people viewed this question
Ekse
Clive
Clive
Alun Cox
